09-07-2009, 10:48 PM | #51 | |
Re: All most on the ground! PB Style
Just my two cents.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
09-08-2009, 01:19 AM | #52 |
Hows your steering working setup like that? Any binding issues without the support holding the shaft? I love the direction this project is going keep up the progress!
Tony from Norcal |
09-08-2009, 10:51 AM | #53 |
Well I dont think I have any binding issues but this what I did; I made sure that I cut the D-Rod where it would not interfear when joints roll into the center. If the rod is to long it will be in the joints way and not allow it to perform to it's maximum capacity. Then I shave about 1/16 on the joints that move in and out of each other (the half round part) because it was slightly rubbing inside the joints inner walls. This is what made it possible, I will really test it when I get the steering wheel on (I had to use vise grips for the mean time).
09-08-2009, 01:10 PM | #54 | |
Keepin it old school
09-08-2009, 02:19 PM | #55 | |
09-08-2009, 03:39 PM | #56 |
Yes, I order this swaybar through Nate.
09-08-2009, 11:58 PM | #57 |
On the steering joints:
It looks like the angle of the joint on the column is approaching (if not at) it's maximum recommended angle. Most headers make it necessary to use three joints and an idler to begin with. Being that you shaved a little off the joint, I would think it would be best to use the third joint and idler to deminish the angles. I have seen plenty of vehicles running it at steep angles, but recommend against it. Steering and brakes are the two most important items on any vehicle. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
09-09-2009, 12:12 AM | #58 | |
I guess going 60 miles an hour would be a good time to lose steering abilities. Im sure this advice will be helpful to others aswell.
09-09-2009, 09:44 AM | #59 |
looks great, wish i were that far along, are the control arms porter built? what about the fuel tank thats where im at now, need a good idea or product to relocate my fuel tank out of the cab?
skeeterbug
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
09-09-2009, 11:21 AM | #60 | |
Yes, those are PB control arms and they look better in person. As for the gas tank I purchased it at Scotts Hot Rods.
09-09-2009, 12:36 PM | #61 |
Damage Inc
looks good..go with 24s all around
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
09-09-2009, 04:07 PM | #62 |
Thats what Im trying to aim for but I know things will be a little tricky.
09-10-2009, 03:17 PM | #63 |
Damage Inc
it can work,my buddy wished he went 24s all around. Let me know if u need any help, we have alot of c10s at da shop in Baytown
09-10-2009, 03:33 PM | #64 | |
09-10-2009, 03:35 PM | #65 |
trenz68
What size wheel does your friend have in the rear and how wide is the lip?
09-10-2009, 04:56 PM | #66 |
Damage Inc
their 24x10s with a 5in lip. shorten the rear end 2 3/4 on each side if i remember right
09-11-2009, 07:25 PM | #67 | |
Village Idiot....
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
09-12-2009, 02:31 PM | #68 |
Cheater! I had to use a die grinder than a disk grinder, than a punch... You get the picture and your right about no two frames are alike. I guess we'll just call them custom frame instead of defective.
09-21-2009, 09:36 PM | #69 |
Well Im trying to set the rear suspension and im going to take my time and measure and measure until I feel that everything is set in its proper position.
I dont know if its me but the rear pinion has a slight offset and is not centered? Correct me if im wrong. I squared the lower inner links to make sure that everything is straight. So far, good success! I cut the lower links to 29.5'' long plus the bushings. Im sure that I will be asking question as I proceed forward. Nate also built me a rear plate crossmember since my fuel cell requires to be all the way to the rear & he added his own spice to it.
09-22-2009, 12:09 AM | #70 |
VA72C10
Looking good.
Looking for a 67-72 swb or blazer project in or around VA. |
09-22-2009, 08:42 PM | #71 |
did that plate come with a jacket
09-22-2009, 08:54 PM | #72 |
Ya, but he said that I couldn't wear it until the frame was complete!
09-23-2009, 07:12 PM | #73 |
better get it done before it gets too cold then
10-03-2009, 08:39 AM | #74 |
that members only is dope
