#51 |
Re: 86 C10 Trailing Arm Conversion
Pics . . ....
#52 |
Thanks for the pics Scoti. I feel kinda dumb asking for them now. It was/is really obvious, but the only pics of them I had seen was installed on a truck.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#53 |
![]() Join Date: Dec 2008
I see that this has some new interest. I am home and started mocking things up. When I initially started researching this project I found the CPP kit and called on it and they said that it would work on long beds too.... It has been almost a year and I still have no part number for longs beds or further information. I started mocking up my truck with the 60s stock crossmember and the stock arms and I figured out that CPP informed me incorrectly. The kit will ONLY work on short beds. If you look at their install, the crossmember mounts under the cab where the frame starts to bend downward. You need a custom crossmember like the HRH truck to make anything work on a long bed. The crossmember cannot go between the frame rails because it puts way to much of an angle on the arms. It also cannot be mounted underneath because it is too low. Instead, you need to make a crossmember that mounts the arms so that the pivot point is even with the bottom flange of the frame. Also, I found that the frame widths are the same, so you can use the stock shock mount crossmember. In addition you could in theory use the stock style springs mounted to a bracket air ride part number A002E just mount them to the outside of the frame rails. It will give you the right width to use the coils since the coil frames flared out at that portion.
#54 |
I would have to disagree
the difference in wheelbase between long and short beds is 14" and that 14" difference is straight and horizontal frame, so it wouldn't change the relationship of the crossmember to the rear axle
#55 | |||||||
BTW, the more AS you have, the less front rise you will have.. IE the more squat, the more the front will come up. Quote:
Might I suggest starting here: http://67-72chevytrucks.com/vboard/s...d.php?t=326863 Then if you can find it, purchase Herb Adams Chassis Engineering. There is a lot of really good info in that book.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#56 |
![]() ![]() Last edited by joe231; 12-16-2009 at 03:28 PM. |
#57 | |
#58 |
and you can't do a decent drop because the arms will hit the frame
#59 |
i can post pictures of it mocked up with the crossmember between the rails and such if anybody is interested
#60 |
what is your definition of a decent drop?
you can get low enough that the diff hits the bed floor, if you wanna go lower you will need to modify the frame and bed anyway, so just make a bigger notch to to clear the arms or Z the frame..... pictures would be great
![]() ![]() Last edited by joe231; 12-16-2009 at 07:08 PM. |
#61 |
Porterbuilt can make'em lay frame with trailing arms... That should be more than low enough for most people
#62 | |
Post those pics.
#63 |
Yes, that is the book..
Scotti, good point on the spline count.. Interesting enough, mine had an aftermarket posi and axles in it when I bought it.. Didn't realize there was a difference. The trailing arms are wider than the frame where they meet the Rear on my 63.. I'd assume it's that way on all the 60-72's.. Also, the spring in stock location sits in between the LCA and frame rail. If you were to bag it or use coil overs, you could notch the frame and have no issues with the rear suspension.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 12-16-2009 at 08:14 PM. |
