03-21-2010, 12:16 PM | #51 |
Registerd User
Re: project lownslw64
Fantastic.
03-21-2010, 01:20 PM | #52 |
Shloooooong bed member #2
very slick, nice work
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
03-22-2010, 05:23 PM | #53 |
Lookin good lownslw64! Where did you end up getting the high hump trans cover? And how far are you from Faifeild, Ca.? I might have to come check this thing out some time!
Tony from Norcal |
03-22-2010, 05:43 PM | #54 |
Keepin it old school
Is that Griffen Radiator made for our trucks? or is it a universal fit? Looks freakin sweet
03-22-2010, 11:42 PM | #55 |
thanks, I bought the high hump from a board member lil red 66. I bought that and my radiator mounts from him. He is very knowledgable and has alot of parts. I live in brentwood, nor cal. I am about a hour from fairfield south east. off of hwy 4. pm me if you want to come and check it out.
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors 2007 chevy 2500 hd 4x4 duramax |
03-22-2010, 11:55 PM | #56 |
yes, the radiator is made for our trucks. It is a 4 core alum radiator with dual elec fans, transcooler and mine I set up for my ls1 ( both inlet and outlet are on the pass. side). If your truck did not come with a 4 core rad. you will need the upper and lower bracket from a stock 4 core truck and they will fit the radiator. The part # for mine is 6-563ar-jax so if you want to look at it on there website and you can fine tune it more for your application (motor,transcooler) thanks for the complements.
04-11-2010, 12:15 PM | #57 |
well I bought a couple of parts and i thought i would share. first is a art big red 3/8'' manifold valves and second is the ride pro e3 electronic management system for my air ride. The bonus of this kit for me was I don't have to run all of the air line and wiring into my cab. It all goes to an ecu in the frame and a small multi-conductor cabe is routed into the cab to the controller that tells me everything i need to know.
04-11-2010, 11:20 PM | #58 |
Member of the longbed union.
looks like a good set up you got there. only good things about he ridetech stuff.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
04-12-2010, 04:19 PM | #59 |
chevy only
Duuude nice work very cool!!
CHEVY ONLY... Nothin Else ! |
04-23-2010, 01:31 AM | #60 |
I've been off this week so i have been able to work on my truck a little more than usual. so I figure I would try to eliminate some loose ends. I got the brake lines in the rear up to the front x-member complete. not sure how i'm going to run the fronts yet. made a bracket off of the trailing for my e- brake cable. installed my air tank, manifold valve and started on plumbing in the 1/2tubing for the air ride.
04-23-2010, 02:23 PM | #61 |
Looks good!! Can't wait to see this thing rolling.
08-30-2010, 07:38 PM | #62 |
Any updates?
Tony from Norcal |
08-31-2010, 12:02 AM | #63 |
no updates really. bent a couple air lines, thats about it. been busy with the family and life..... hope to get back on it soon.
01-09-2011, 01:41 AM | #64 |
i've been able to work on my truck a little bit lately. I mounted my water seperator, finish bending and install all of the air lines to all four corners. i will hopefully soon get my fuel system taken care of and get started on cab repairs.
01-09-2011, 01:54 AM | #65 |
That plumbing is artwork!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-09-2011, 02:27 AM | #66 |
60-66 Nut
01-09-2011, 03:04 AM | #67 |
Wow! That's freakin' nice.
01-09-2011, 11:59 AM | #68 |
chevy only
lot a work looks killer!!
01-09-2011, 12:43 PM | #69 |
thanks everybody, been wanting to do this to one of my truck for a long time so it is nice to finally acomplish it.
porterbuilt: i am getting ready to have a driveline built. i have a dropmember with a ls1/4l60e tranny with 4 degrees on it and the stock 12 bolt trailing arm setup. what is the best way to figure out my 2 piece driveline needed. including angles . thanks
01-09-2011, 09:43 PM | #70 |
picked up a o1 camaro ls1 fuel tank today to use the fuel pump assembly in my fuel cell. I will have to modify my fuel cell for this to work. It would be awesome if i could use that whole tank and everything but it is to wide.
01-14-2011, 02:24 AM | #71 |
i unbolted my fuel cell tonight to figure out how i am going to mount my fuel pump into it and figured while i was back there i would mount my 67-72 fleet rear bumper.
01-14-2011, 10:48 AM | #72 |
SSN 706
Love the air lines. Looks way clean. You make it look to easy.
01-16-2011, 11:31 PM | #73 |
those lines are awesome!!
01-17-2011, 01:56 AM | #74 |
I know you've heard it a few times, but nice plumbing job!!! Couple questions though, could you show us the tool you used to fab such a large tube and are those all flared fittings, compression? Thanks in advance, this is a great post.
01-17-2011, 12:44 PM | #75 |
thank you for all the compliments
65 pickup: the tool i use to bend the tubing is a ridgid tubing bender for s.s. tubing. I used 1/2 s.s. x 036 (thickness)tubing for my lines. I used parker cpi s.s. single ferrull compression fittings for everything. I dont know max pressure rating but they are mainly used in process and instrumentation applications. the first pic is the bender and i put a piece of tubing in it to give you the idea and the second is the fitting i use opened up so you can see all the pieces.
