12-12-2009, 10:30 PM | #51 |
mini truck racer
Re: Some Assembly Required / build #2
Got the brakes freed up on the blue truck today . Also got the bed and hood off . Got 2 guys local interested in the frame . New 5 lug frame will be in the garage by monday and white truck home very soon after . Todays progress .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-13-2009, 01:41 AM | #52 |
VA72C10
good progress
Looking for a 67-72 swb or blazer project in or around VA. |
12-14-2009, 06:15 PM | #53 |
mini truck racer
Finished parting the blue truck today and it is off to its new owner . I got the frame inside and out of the weather . It has been foggy and rainy here for a week so not any outside work going on . I'll get some good progress pics after the gym tonight . If it quits raining i will bring home the white truck tommorow , but i got to do rear brakes on my powerstroke before i tow again .
12-25-2009, 08:37 AM | #54 |
mini truck racer
I finally got some work done . I've had a pile of parts waiting on me to get to work . Well the truck chassis came with a 3.07 open . i had a 3.40 on the shelf and had ordered a posi unit for it . I got the posi unit off Ebay out of Canada rebuilt for $250 shipped . This thing was spotless and you could tell someone took there time disassembling and cleaning it up .
Oh , and what would a 12 bolt gear change be without a broken center pin . Got lucky on this one . While i had the axles out i put new brake shoes and wheel cylinders in the rear . Painted both drum with chassis paint and cleaned everything up . Not as nice as a show truck , but this one will be a driver . My original 3.07 gear had a loose backlash of .020 and the pinion preload was very tight . I replaced the gear and the pinion preload ended up at 8 in#'s . The backlash I tightend up to .011 . The gear rolled through good and had a good contact pattern , so i feel comfortable with it . This one makes #7 i have done gear swaps on . Man gear lube stinks . I have the calipers , pads and hoses for the front . I entend to get the hardware kit for the calipers and new mount pins . I'll get the rotors painted and have them turn them to make sure there true . Talked to the machinist the other day and looks like i will be building a 383 . I have all the parts to build a nice forged piston 355 , but i think i want to try a 383 . as of now i plan to use the th400 out of the white truck . i will be hauling it home within the week and begin disassembly .
12-25-2009, 12:06 PM | #55 |
Still Learning
Looks like a nice install on the posi! Did you have any issues setting clearance between the pinion and ring? I have always steered away from changing ring and pinion sets because of lack of confidence. I have an old rear end for our project that has a ton of slack and needs rebuilt.
Keep the pics coming....and Merry Christmas! |
12-25-2009, 02:12 PM | #57 | |
mini truck racer
12-25-2009, 02:48 PM | #58 |
Under Construction
looking good Raland!
Merry Christmas.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
12-26-2009, 02:28 PM | #59 |
mini truck racer
Thanks , Merry christmas to you also .
This will be finishing the rear axle .
12-26-2009, 11:17 PM | #61 |
Damage Inc
looks good
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
01-01-2010, 08:42 PM | #62 |
mini truck racer
Got a few things done today . Back brakes are ready to go . Been working on the fronts . Got part of my "sound system " in also . Mostly picture update . Also worked on the plates for the 49' .
01-01-2010, 08:48 PM | #63 |
Under Construction
01-01-2010, 11:34 PM | #64 |
VA72C10
looking good. Going to be a nice truck!
01-03-2010, 12:06 AM | #65 |
mini truck racer
Finished collecting all the brake parts today and got these painted .
01-09-2010, 11:40 PM | #66 |
mini truck racer
Well all the hard lines up front are plugged? up , so i have been replacing them as i go . I got the driverside finished and i am working on the passengerside . Got the rear end completely buttoned up and ready to go . Bought the pistons for the motor and im looking for a block . I'll post some pics tommorow . I have been showered with problems as of late . Lots of overtime at work , silly door knob broke on the back door , driverside stub shaft and bearings failed on my powerstroke , it down waiting on parts . Trying to sell my Trans am , also got a super offer on the 68' Camaro that i don't think i can pass on . Just kinda been plain ol' busy .
01-10-2010, 12:04 AM | #67 |
Under Construction
What your selling the camaro.........
01-10-2010, 12:10 AM | #68 |
mini truck racer
Well I might . I have areally good offer on the table . Enough that Even if i spent the money to finish it i would break even . Haven't seen the cash yet . I am about to finish the 49' , i'll have the 67' to work on , I was thinking sell both cars and buy a newer C6 vette . Something like this
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 01-10-2010 at 12:27 AM. |
01-10-2010, 03:23 PM | #70 |
How much you asking for the camaro? I may have to make the trip
01-14-2010, 11:29 PM | #71 |
mini truck racer
Camaro sold , got what i wanted for it and it is going to a good home .
It is raining so i couldn't pick the motor up today . Found a 1991 1-ton crewcab with 350 . I'll see tommorow if it is 4 bolt . My intentions are to build a 383 . I have 350 forged pistons so if it has a forged crank it will be a 355 . I have heard it is hit and miss , could be 2 or 4 bolt , cast or forged crank 1-tons could be both . I will top it with a set of fastburn GM heads i have and RPM airgap that is port matched to them . XR288HR roller and either a HEI or my full MSD set up . I intend to put a looser converter in it , around 2500 . Going to try and wrap up the brake stuff tommorow . Will be moving parts over soon.
01-14-2010, 11:33 PM | #72 | |
Under Construction
01-15-2010, 01:01 AM | #73 | |
1971 Corvette convertible 454@ 525 hp 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
01-15-2010, 01:37 AM | #74 |
Still Learning
How much was the Camaro? Sorry I missed that one..I have a few old rusty Camaros sitting out back. It would be cool to buy one that is actually driveable.
01-15-2010, 10:05 AM | #75 | ||
mini truck racer
Wel id perfer not to say , but if i had the money in my hand i probaly would not have bought it , but they were happy with it so it worked out . It went to a good home . The car will be finished out nice . It will be nice lowering the number of projects im working on . I also find i enjoy the trucks more than the cars as far as projects go . They are just funner to me & everyone can connect with them and enjoy them .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 01-15-2010 at 10:08 AM. |
