Old 03-02-2010, 12:50 AM   #51
Kim57
Kim57's Avatar
Re: Project '57 2WD
Originally Posted by blackdiesel View Post
are shiney chrome wheels out of style? did i miss the memo??
I think those wheels are sweet.
Kim
Kim57 is offline   Reply With Quote
Old 03-04-2010, 09:13 PM   #52
frkennyg
Re: Project '57 2WD
The truck frame and suspension are looking awesome. Is that a mustang 2 front end? If so where did you get the kit from?
The truck color and rims look great....but i'm older.
frkennyg is offline   Reply With Quote
Old 03-04-2010, 09:27 PM   #53
blackdiesel
blackdiesel's Avatar
Re: Project '57 2WD
MII from speedway motors. Ended up costing me 1700 for the complete kit, power rack and all.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-07-2010, 05:40 PM   #54
blackdiesel
Re: Project '57 2WD
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-07-2010, 05:48 PM   #55
blackdiesel
Re: Project '57 2WD
took about 4-5 hours to tear the front end down, pull the computer wiring out of the cab, and pull the bed off. of course it was all the little things that take all the time. anyways dad and i just got it set over on the other frame. need to get a new (shallower) fuel tank. need to reposition the rear coil overs (they are too long).
It made me laugh at myself when i was tearing the wiring apart. It looked like some 12 year old kid wired this truck (haha). needless to say it will all be soldered and heat shrunk when it goes back together. need to order one of those 800 dollar gauge clusters (ouch!!) in order to keep an eye on the engine vitals.
i'm afraid the front coil springs are going to be to light. i sure hope not. i need my wiring harness back and installed, along with the power steering lines completed before i throw the front clip on.
Just a few odds and ends before the bed gets bolted down. need to tighten up my 4 link, fix my coil overs, run the rear light wires, and fuel tank/lines and the bed can go on.
going to have some clearance problems with those wide tires in the rear. they are a little wider than i thought they would be. looks like i will have around 1/2" of clearance on each side of each tire if i can get it tucked under there like i want.
to bad this one wont go together as quick as it came apart. lol
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-07-2010, 08:21 PM   #56
GRIMSS
GRIMSS's Avatar
Re: Project '57 2WD
Looks good Brian. So you got another body for the old frame?
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 03-07-2010, 08:47 PM   #57
blackdiesel
Re: Project '57 2WD
no sir, i've got the motor/tranny/t-case sold. Just need to find someone to sell the rolling chassis to.
dont have enough money to build another. and if i did it would be a model a
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-07-2010, 09:07 PM   #58
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Project '57 2WD
Looks GREAT!!! Hope you get it running soon.
ChuckDriver is offline   Reply With Quote
Old 03-07-2010, 09:48 PM   #59
JML55
JML55's Avatar
Re: Project '57 2WD
I like the new stance.
JML55 is offline   Reply With Quote
Old 03-07-2010, 11:43 PM   #60
blackdiesel
Re: Project '57 2WD
Back to waiting on the UPS man. Theres quite a few little things to do but no more body panels can be put on till i get some more parts. Cant wait to fire this bad boy up.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 04-10-2010, 12:39 PM   #61
OKGMC4
OKGMC4's Avatar
Re: Project '57 2WD
Are you putting AC in the truck? If so, are you using the stock compressor on the 5.3l? I'll have to move mine up high and the aftermarket bracket is too much. I'll try to make my own first. Also, are you making/ buying an engine cover or leaving it nekkid?
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 04-10-2010, 01:45 PM   #62
blackdiesel
Re: Project '57 2WD
Truck already had a/c from the first time around. vintage air i believe. (been several years) but yes, i'm going to use the stock compressor.
i have the vortec cover that comes stock with the pickups, i'll slap that on there just for giggles but i'm not putting any more money in it than that. i had to get block hugger headers to get the steering linkage to fit.
I was only a few weeks from being done till i pulled this 06 cummins into the shop. set me back a good little bit
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 04-11-2010, 01:23 AM   #63
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
Re: Project '57 2WD
Oh come on, Dodges don't set you back in time, they come apart easy..... yeah right, who am I kidding, Dodge still builds they're trucks right!
Cameron Gunlock
Project: ALTER-K-TION ('57 GMC Quad Cab) http://67-72chevytrucks.com/vboard/s...d.php?t=393750
addicted2dunes is offline   Reply With Quote
Old 05-14-2010, 11:45 PM   #64
blackdiesel
Re: Project '57 2WD
Took a long break (i was supposed to have this stupid thing done a month ago...) but have finally got motivated to work on it again. Got my fuel lines ran and secured, fuel tank is also in. Wiring harness came in (a long time ago) and got most of it all hooked up. just like a few main power wires and the gauge cluster. power steering lines and steering joints are on their way. May get the front clip set back on this weekend so i can mount the computer in order to hook up the rest of my harness. Hope to get it started soon...
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 05-16-2010, 10:19 AM   #65
GRIMSS
GRIMSS's Avatar
Re: Project '57 2WD
Glad to see it back on track.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-17-2010, 11:34 PM   #66
blackdiesel
Re: Project '57 2WD
Yessir. Looks like the weather is going to put my haying out of the equation for at least a week. Hope to make some headway.
Tonight i got the power steering lines done and the front brake lines done. Waiting on a double steering u joint to hook up my steering. then its on with the front clip. few little odds and ends and she's ready to go. (relatively speaking...)
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 05-17-2010, 11:55 PM   #67
blackdiesel
Re: Project '57 2WD
could i get my build thread moved with everyone else please???
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 05-21-2010, 12:29 AM   #68
blackdiesel
Re: Project '57 2WD
May be talking to the wind but here goes..
Got alotta crap done the last coupla days. Put her up on the lift and tighened/mounted/secured alot of loose ends. Fluids changed, yadda yadda yadda. Finished up the brake lines and such. Still have a few odds and ends to chase but did alot of wiring tonight on the engine harness. Have it wired up to where it will crank. however i still have to wire a relay to fire the fuel pump and a relay to fire the ignition coming from the computer.
Thought my fuel system was done... turns out i pulled a rookie move and assumed the second line coming out of the manifold was the return. turns out its some stupid emission crap. i need a fuel filter out of a 98-02 vette, its a filter/regulator all in one. being as how my 5.3 has a non-return fuel rail.
anyways, i hope to get it fired up tomorrow!!! going to get the filter in the morning along with a few other odds and ends i need. if all of my sensors are good theres no reason for it not to fire. everybody cross your fingers haha
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 05-21-2010, 10:23 PM   #69
blackdiesel
Re: Project '57 2WD
nuff said
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 05-21-2010, 10:46 PM   #70
T Hilde
Re: Project '57 2WD
Sweet music
T Hilde is offline   Reply With Quote
Old 05-21-2010, 10:57 PM   #71
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Project '57 2WD
Nice progress, sweet truck!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-22-2010, 12:38 AM   #72
JML55
JML55's Avatar
Re: Project '57 2WD
Great job , i like it.
Old 05-22-2010, 12:44 AM   #73
blackdiesel
Re: Project '57 2WD
In this vid it wouldn't rev up. Chased wires and re-pinned the throttle pedal harness and still no go. Turns out I had a ground on the drivers side near the back of the block that solely functions as a ground for the pedal harness/box. Grounded it and it works. Its the little crap that gets ya every time...
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 05-24-2010, 08:52 PM   #74
GRIMSS
GRIMSS's Avatar
Re: Project '57 2WD
Very nice.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-29-2010, 11:39 PM   #75
blackdiesel
Re: Project '57 2WD
FINALLY got the crap to hook up my steering linkage. should be driving in a few days... ohhhh yeahhhh
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
