01-10-2010, 09:57 PM | #51 |
GM Addicted
Re: 1979 Chevy build
went out to pick-n-pull today and found the deal of my life, found a clean tailgate band, the narrow one that mounts inside the groove on the tailgate, got it for 5 bucks. time to clean it up and mount it
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
01-10-2010, 10:20 PM | #52 |
6.0 powered square
looking good
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
01-10-2010, 10:23 PM | #53 |
GM Addicted
thanks man..
01-11-2010, 12:41 AM | #54 |
qwik fix for that bumper., get some on to pull on the edge while you use a 2x4 and hammer to bang the kinks out, did that to mine
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
01-11-2010, 07:04 PM | #55 | |
6.0L power.........
What ever the mind of man can conceive......... he can achieve! My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914 1979 GMC Sierra 6.0 L 4L60E 1995 Mustang GT 347 |
01-12-2010, 02:09 AM | #56 |
GM Addicted
hahaha i will post a link very soon, and i live in sacramento rite now dont know how close that is to you.. and i will have to try that because man that kink in the rear bumper bugs the hell out of me..
01-12-2010, 10:57 AM | #57 |
Truck looks great man. You have done a great job, and should be very proud. You seem to have a great outlook on life that will get you very far. Keep at it, and keep us updated with progress.
01-12-2010, 11:35 AM | #58 |
GM Addicted
thanks man, as of now the truck doesnt move the ignition tumbler went out im going to attempt to fix it myslef here in a bit see how it goes
01-12-2010, 11:40 AM | #59 |
Brandon, just talked to my neighbor... he said its a piece of cake. pull the steering wheel, horn plate, and use that tool to push down on the spring and release the clip(??) and you'll see the screw that holds the ign. tumbler. he said the hardest part is getting the tool good luck bro
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
01-12-2010, 11:41 AM | #60 |
GM Addicted
alrite well see how it goes dennis, ill call you if i need any help man, ahah tell your neighboor too tag along and help us out ahahah..
01-12-2010, 11:46 AM | #61 |
he charges by the minute!lol
01-12-2010, 11:49 AM | #62 |
GM Addicted
hahaha lunch will be on me tell him haha, serious though if hes down..
01-12-2010, 01:12 PM | #63 | |
01-12-2010, 10:50 PM | #64 |
GM Addicted
that wasnt the problm i think the ignition switch or the rod itself is messed up but for now i have a toggle switch wired to my starter just a temporary fix
01-13-2010, 05:04 PM | #65 |
What is it exactly doing, or not doing.
01-13-2010, 05:43 PM | #66 |
I gaurentee 100 to 1 its a broken rack or selector gear in your column.http://www.lmctruck.com/icatalog/cc/full.aspx?page=138
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
01-13-2010, 08:53 PM | #67 |
GM Addicted
hahaha, okay when i turn the key on the collum to the run position all the power comes on but when i put it in the start position it doesnt crank or nothing, so what i did was wire up a on off toggle to the battery + and to the s terminal on the starter and i use this to start it, its always been hard to start it i would have to move the collum down to the lowest tilt to start it then bring it back up but not it doesnt crank from the ignition. i believe it is the rod in the collum.. but for now it runs
01-14-2010, 06:11 PM | #68 |
Yeah it's a little keyway thing that keeps the ignition in line with the tilt column. It is made out of like a potmetal and is very common to break. You can buy them at the auto parts store in the Help section.
01-14-2010, 09:26 PM | #69 |
GM Addicted
didnt run for long left me stranded again last nite i would turn the key and get no power but my toggle still worked and all lights, so i droped the collum and took off the ignition switch thinking that was it so i had a buddy go get me one and when i took it off the rod came out it is bent, now i need to find a way to get it back in and what do i need. for now i have the new iginition switch in but not mounted i use the rod to push and pull on the slot for it as if it where all connected in the collum so it still runs just want to fix it rite
01-22-2010, 01:16 AM | #70 |
GM Addicted
Here is my tailgate band, just need to finish polishing it out and find another mounting bracket for it, hopefully find one soon so i can put it on, anyone have one willing to help me out with one.. Interior pics finally coming tomorrow..
96. 97. 98. 99.
01-22-2010, 09:25 AM | #71 |
Nice looking band. That will look good on your truck.
01-22-2010, 10:18 PM | #72 |
GM Addicted
thanks man cant wait to get it on there i only paid 8.00 bucks for the band at Pick-N-Pull good steal if you ask me..
01-22-2010, 10:23 PM | #73 |
That's a definite steal. You don't find bands in that good of shape very often at the pick and pull.
01-22-2010, 10:30 PM | #74 |
GM Addicted
i walked by the truck, well all of them n most of them had tailgates down then i was like it will make my day if one has a good band on it the first one i lifted had this one on it, i was lucky, what you think about running the stock front bumper gaurds on my truck, think itll look good?? anyone photoshop it for me.
01-22-2010, 10:41 PM | #75 |
My vote would be for no bumper guards. It looks so much cleaner without them.
