#51 |
Re: air bag kit!
ok i know what to get for the back wich is the re7's, shock relocate with drop shocks, bolt in notch but whats a mild notch and a regular notch? if i get a 3" lowering blocks instead of 2 what would that do? and when i install my rear bags is it ok to drive it with no air in the bags for a while?
#52 |
low n' slo
![]() Join Date: Mar 2009
Re: air bag kit!
bolt in c notch is basically mild. nothing to extreme to installing one compared to a monster notch (which is the bigger one you have to weld in...BUT, some companies sell bolt in monster notches also). with 3" blocks you will run into scrub issues with your wheels, unless you run big rims. with stock rims, 2" is the safest best. if you have a blowout in the rear with 3" blocks, your suspension could drop low enough to hit the ground and rip everything up. also, i got the airlift dominator 2600's all around and they are some beefy bags! ***************** has them on sale for 60 bucks a piece. you can click on my build thread and check out the pics i have in there. in basically just bags replacing springs, no drop spindles or notch or anything...yet...
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#53 |
Re: air bag kit!
Never drive it without some air in the bags. You will also want to get a Super or Deluxe track bar. Whichever one goes from the driver side frame to the passenger side trailing arm.
3" blocks will allow you to run a little more air pressure than 2" blocks at whatever ride height you want. The standard bolt in notch is about 3". It's about half the height of the frame and about as far as the rear axle can go without hitting the bed. |
#54 |
Re: air bag kit!
ok i already know what setup im going to do which is the 2" lowering blocks and u know all the other stuff!
so when i install my rear bags should i have the compressor and tank already? |
#55 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: air bag kit!
yes.
Or run schrader valves until you have the funds.
#56 |
Re: air bag kit!
ok well whats a good compressor kit for the price?
#57 |
Re: air bag kit!
This is a schrader valve.
#58 |
Re: air bag kit!
but thats cheap i have to fill it up with a regular compressor and leave it with air till i get the compressors right?
but i could still hook up the gauges with the compressor? |
#59 |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Re: air bag kit!
Here's a before & after of Gumby with a bolt on kit.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
#60 |
Phone's ringin Dude.
![]() Join Date: Mar 2007
Re: air bag kit!
I would maybe suggest researching the suspension forum. 100% of the questions you are asking can be answered just by reading through various posts on here. An air ride system is nothing to just jump into without at least a little bit of studying on the subject.
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
#61 |
Re: air bag kit!
i know what to do im just asking some quick questions!
whats ur setup on gumby? |
#62 |
Member of the longbed union.
Re: air bag kit!
I think what everyone was refering to on the bump stops is for the front control arms. In order to get as low as you want to go you will have to cut them off.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#63 |
On the path to financial ruin!
![]() Join Date: Jan 2009
Re: air bag kit!
3 pages in a forum doesn't seem to be quick questions. If you know what to do you wouldn't be asking about what is a good price for a compressor. Or not knowing what was meant by removing bumpstops or know not to ever even think of running bags without any air in them. We are trying to help you and love helping fellow members. But like Dieselarmy13 said, go to the suspension forum and you will better understand because some of this stuff has been discussed. Also, if you live near an installation shop that sells and installs air suspension components talk to them and they may be able to show you some stuff in the shop to help you get a better understanding. Then if all else fails, call Ride Tech or Accuair's tech line. Please don't take what I'm saying as rude or disrespectful. I once was unknowledgeable myself so no harm meant.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 Last edited by 68jewel; 11-21-2009 at 03:25 PM. |
#64 |
Re: air bag kit!
Gumby thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=365580 Look at the top of the page. There is a search feature specific to this site. I agree,... the suspension section has alot of the answers you are looking for.
#65 |
Re: air bag kit!
Until you can order some real good stuff I have some old stuff that would help you get started. Compressor, air guages with 2 switch's, I do have a 3 gal airtank that got some water it in, but would be a good start. Or I could sell you my 8gal 9 port tank. PM me if you wanna know about any of the stuff.
#66 |
Re: air bag kit!
pm'd
#67 |
Re: air bag kit!
which starter kit would go good with my setup im going to use?
im going with the re7's all around heres the link http://www.*****************/catalog/...anagement-kits |
#68 |
Re: air bag kit!
well something you have to think about is how fast you want it to raise and lower. I went with a dual 3/8-1/2 kit.
But for the money and what you want for bags, This is your best bet http://www.*****************/air-mana...ement-kit-1-38
#69 |
Re: air bag kit!
i want a starter kit for now since those are way cheeper
#70 |
Re: air bag kit!
well you got to think about it this way. You want 4 RE7's They cost like 80 per bag for the cheapest. So that's 320 for just bags. Then you have to add the cheapest starter kit is 699.99 so your at $1020.
They kit I just sent you adds the bags plus 2 air compressors for 70 more
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 Last edited by ruffrida2005; 11-22-2009 at 12:00 AM. |
#71 |
Re: air bag kit!
oh i didnt read all the way down ok ya that is a good kit thanks alot!
so ill just need the lowering shocks, c-notch, and my drop spindles |
#72 |
Re: air bag kit!
,... and shock relocators, adjustable track bar, upper plates and lower cups,... unless you already have these,...
#73 |
Re: air bag kit!
am i gonna need plates for the rear?
i have coils on my truck right now |
#74 | |
Re: air bag kit!
I have suggestion. Why don't you do a 5.5/7.5" static drop. Same stuff except springs in the place of bags (for now). That way you can spend your cash on all the quality components that you need and ride low for a while. Then when you get the rest of the cash,... you can just swap out the springs for bags and add a nice air management system. That's basically what I did on my blazer.
#75 |
Re: air bag kit!
im not laying frame im just gonna do a simple bag setup
