10-24-2010, 05:32 PM | #51 |
Re: Project Burro Viejo
Here I raised the front end 2", so is a simulated 28" front tire, then I put a 1.5" board under the rear tires, so it will simulate a 29" tire in the rear. Not sure this is going to work, about 1.5" of travel over there.
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216 Last edited by steinepstein; 10-24-2010 at 05:32 PM. |
10-24-2010, 05:55 PM | #52 |
Kvn1011
nice!!! i want to get the same motor, but the pricing has not been in my neiborhood!! love the build!!
02-20-2011, 12:05 AM | #53 |
In with the Rick's tank, out with the hitch.
If anyone wants to weld in this hitch and have a hidden hitch, I will send it to you free if you just pay for shipping. I am looking for the original rear crossmember for a 68 GMC leaf spring setup....this one doesn't appear to fit correctly, probably from another style.
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216 |
02-20-2011, 12:12 AM | #54 |
I had these lowering spacers fabbed up from 2x3 rectangular tubing. On the passenger side, I extended it and cut it at an angle and threaded the inside (simple explanation). My panhard bar will bolt into this and run parallel to the rear axle. On the other side, I will install a dropped bracket which will keep the panhard low and parallel....should improve handling.
02-20-2011, 12:18 AM | #55 |
Still Learning
Man that looks great, I will take the hitch if it doesn't cost too much to ship thanks!
02-21-2011, 07:21 PM | #56 |
McBassin,
It is a pretty heavy piece, I'm guessing $25-30 to ship. If this is ok, I will move forward. Thanks, Jon
02-27-2011, 08:48 PM | #57 |
Nice build!!!!
02-27-2011, 11:45 PM | #58 |
Still Learning
Thanks Jon, I'm gonna pass for now. I forgot how heavy that thing is.
03-12-2011, 12:05 PM | #59 |
Got some goodies this week.
03-12-2011, 12:09 PM | #60 |
Thanks to Greg (lynnfield) for getting me the proper rear crossmember.
Now I can finish off the rest of the frame. The Rick's tank is pretty sweet.
03-12-2011, 12:17 PM | #61 |
VA72C10
looking good!!!
Looking for a 67-72 swb or blazer project in or around VA. |
03-12-2011, 01:49 PM | #62 |
PROJECT 7DEUCE
Nice new goodies..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-04-2011, 10:40 PM | #63 |
Started to "shave" the firewall. All of the electrical components will be mount up under the dash. I had some female threaded blinds made out of 3/4" solid round. You can see two of them attached to the MSD coil. They are being welded under the dash to mount the components, so no screws or bolts are coming out of the firewall.
06-04-2011, 10:42 PM | #64 |
Panhard bar mocked up.
06-19-2011, 10:03 PM | #65 |
Continuing to mount all the electrical components on the underside of the dash. My ECU (Motec) is going to mount above the radio, so I cut out the old speaker pass-through and will be tacking in a solid piece.
Credit to "bad bagged 68.5" on the inserts he made on page 15 of his build, great idea. I will also be shaving my dash and not running a dash pad, thanks! Awesome build by the way...
08-28-2011, 10:11 PM | #66 |
Continuing to work on the firewall......
08-29-2011, 08:31 AM | #67 |
Still Learning
Looking good Stein! Where did you get the ac/heater hose pass through?
08-30-2011, 10:36 AM | #68 |
Thanks McB.
A/C passthrough is from Vintage Air.
08-30-2011, 03:47 PM | #69 |
67cheby
Nice work !!
10-18-2011, 02:15 PM | #70 |
Adding a 3/16" plate to the mild notch area...just a little more structure at the weak link point.
10-18-2011, 02:16 PM | #71 |
Pick up ls1 parts here and there...future secret weapon.
11-08-2011, 01:18 PM | #72 |
The plate is now fitted to the inside of the frame rail. Now I can begin reassembly for the final time, hopefully...and open up some space in the shop. Got a lot more to go.... 12 bolt getting shipped off for a full build.
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216 Last edited by steinepstein; 11-08-2011 at 01:27 PM. |
11-08-2011, 01:25 PM | #73 |
67cheby
sweet...motor looks great !
11-08-2011, 02:29 PM | #74 |
Still Learning
Oh yeah! diggin the new motor!
05-16-2013, 10:17 PM | #75 |
do u still the lower control arms?
