#51 |
Frequent Flyer
Re: What have you done to your 67-72 Chevrolet/GMC
#52 |
Under Construction
On my way to work I drove by the shop where my truck is being worked on and noticed the bed sitting outside.I figured that meant something was getting done yesterday!
72 chevy 4x4-my project 67-72chevytrucks.com/vboard/showthread.php?t=368210 94 Nissan 4x4-Daily Driver and off road beater 03 Saab 9-3 -tripper 90 Polaris Trail Boss- 2 Stroker |
#53 |
Just Not Low Enough!
started re-wiring the engine bay, what did i just get myself into?
ah well, at least i know it will be reliable now. still confused as to why one of my turn signals has a constant 12v, and the other doesn't, same flasher....did i miss something.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd ![]() Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
#54 |
Drive it everday to work.
Finally installed sun visors, made a custom stereo inset to hide the stock hole, and replaced the thermostat housing due to a leak. |
#55 | |
6>8 Plugless........
![]() Join Date: Sep 2007
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#56 |
Tried to get mine started today, may need plugs or timing set.
#57 |
same thing with me, requested 3 days off to get those brake line hooked up in the front end. (did the 5 lug disk brake swap) also to get the 700 r4 in and MAYBE get this project out of my garage!!
1967custom |
#58 |
getting to cold to work...........
pulled the driver door off loaded in my DD to take to welding class but kept messing up on my first project so ill have to haul it another 60 miles .......already get bad enough MPG but its all worth it!!!!!!!!!!1
58 Jeep willys pickup 67 K10 4x4- soon to be trail truck ![]() TROUBLE MAKER RACING ![]() "If you can't stand BEHIND our troops, please stand in FRONT of them." |
#59 |
I pulled a couple spark plugs to see how she was running.Did a compression check on a couple cylinders.Adjusted the timing.Reset the idle mixture screws on the 1406.
Took a lap through town her.Got out to the country and was gonna open her up and I ran outta gas!Luckily a freind was within 10 minutes of me.Sometimes I hate them cell phones.But they can be life savers to. On the way home I laid into it and got a third gear scratch outta the old girl. And I took a picture of it with my nova... ![]()
69 c-10 lwb,Converted to 4x4,dana 44f,12blt,4 inch lift,vortec headed 355,th350/np203 34x10.50x15 swamper tsl's |
#60 |
On the path to financial ruin!
![]() Join Date: Jan 2009
I got the new version of the Dropmember for my baby. Not installed yet, but soon to be.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
#61 | |
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
#62 |
S.D.M.F.
Replaced the heater core(sucked), and put on new cab lights
1969 Chevy Longhorn 396/400 3/4 ton. ![]() 1991 Chevy Camaro RS 305/700r4 ![]() 1978 Honda XL175 and XL350(the evil twin) ![]() 2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous 1971 BSA Thunderbolt 650cc ![]() |
#63 |
Turned the heat on in the garage so the truck would not get cold for the next 4 months. I like to go out and work on it in my shorts and t shirt.
#64 |
67cheby
![]() Join Date: Sep 2008
ordered steering ujoints and shaft cpp has a christmas special !!!
#65 |
I checked the plug wires to make sure they were on the right plugs,and found two out of place.It seems that when the carb. messed up the man that stopped to help started pulling wires and did not get them on right.
#66 |
And found out that three out of eight plugs fouled.
#67 |
Last night I got home and I finish wiring the engine, install my new optima red battery and fired it up...it sounded so sweet, until my wife came in screaming cuz I woke the baby (3 weeks old).
![]() Leo
Leo70 ![]() 1970 Chevy Shortbed 1956 Chevy 210 Post 1963 Chevy Impala SS Rag..SOLD! ![]() |
#68 |
![]() Join Date: Aug 2007
Broke a u-joint.....
#69 |
flushed my glasspacks and installed a new headlight. one was getting dim and it seemed about the right time to change it.
68 Chevy C10 long box |
#70 |
I brushed off 6" of snow, locked in the front hubs, and cruised oround town to see how many Crown Vics could catch me. Used to do it at 17 and it's just as fun at 49.
#71 |
bad ground
#72 |
Ordered the wiring harness and alternator resister. Picked up the 1 piece oil pan gasket, called on a set of fenders, drooled over the pics on this site. Wife calls the web site "Wills truck porn website" to her friends and they all pick on me.
1970 Chevy K10 350 CID with 4 speed 4" lift with 86 Dana 44 Front disk brakes Electric fan/Internal regulated Alt. |
#73 |
67cheby
i recieved my 2000 pb front sway bar.... I say that because 4 months ago i started by just trying to order a swaybar from porterbuilt i had no intentions on buying a Dropmember or rear 4 link .... so basically my 250 sway bar set me back about $2000
#74 |
Went out in the garage and worked on the wood bed while my 13 year old son polished the stainless bolts. He was proud of the great job he did and so was I.
#75 |
Junior Member
Life has got in the way and I have not touched either one of my projects in a while.
The last thing I did on the '67 was put a new water pump and thermostat on the l6 250. If I remember right the last thing I did on the '71 was put a better hood on it. I have been concentrating on getting things ready for the winter and building a craft room. Heck I can hardly get in my garage because of the mowers. It is time to service them and move them to their winter storage. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
