Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-17-2010, 10:57 AM   #51
silver7
silver7's Avatar
Re: Project: Custom 71 4x4 hotrod
Yesterday's weather was perfect for working on the truck. Unfortunately, I had to use to use it to remove my faulty ABS system from my 2002 GMC Yukon. Today I get to bleed the brakes in the rain. Basically my ABS initiates at random - not a good thing. I had the repairs quoted at the dealership but the $1000 for parts and $400 for labor was absolute madness.
Luckily, I found a couple of companies on the web that will rebuild them for $150 or so. Can't beat that - I figure I'll save myself at least $1000, which means more cash for my truck!
www.modulemaster.com
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
Old 01-17-2010, 11:37 AM   #52
msgross
msgross's Avatar
great, one more item to watch out for on my Tahoe...
I just replaced the driver side O2 sensor @ 50K miles since it was fouling all four driver side plugs and not the pass side. had to pull the front driveshaft in order to reach the cannon plug, what a PITA..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-17-2010, 11:21 PM   #53
silver7
silver7's Avatar
According to everything I read it is not a matter of if these go bad, but when. But you probably have quite a few years left before you have to worry about it.
Shawn
1971 C10 4x4
Old 01-18-2010, 09:54 PM   #54
silver7
silver7's Avatar
Finished welding my traction bar brackets and drilling holes for the driver side tonight. Everything bolted up perfect!
Shawn
1971 C10 4x4
Old 01-18-2010, 10:03 PM   #55
msgross
msgross's Avatar
what do traction bars help with a leaf spring rear? I've seen the 4 link setups with coils but not leafs...
is it simply to keep the axle from rotating?
The Garage:
Old 01-18-2010, 10:07 PM   #56
silver7
silver7's Avatar
They are supposed to help with preventing 'axle wrap' or the tendency of the leaf springs to compress when you punch it. The 383 stroker I plan on building should have around 450 HP so I wanted to be sure my lifted springs did not hinder putting power to my rear end.
Shawn
1971 C10 4x4
Old 01-18-2010, 10:12 PM   #57
msgross
msgross's Avatar
hope that 12 bolt holds...
The Garage:
Old 01-18-2010, 10:23 PM   #58
silver7
silver7's Avatar
Me too.
Shawn
1971 C10 4x4
Old 01-18-2010, 11:37 PM   #59
Big-Blue
Big-Blue's Avatar
Where did you get the traction bars? Kit or did you put together the parts yourself?
Looks good! Is it possible to mount to the top of the rear end so that ground clearance isn't an issue?
Big-Blue is offline   Reply With Quote
Old 01-19-2010, 01:06 AM   #60
Wildstreak
"something witty here"
Wildstreak's Avatar
x3
great build man looking forward to seeing the end results
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 01-19-2010, 07:52 AM   #61
silver7
silver7's Avatar
I bought my traction bars from a guy on Craigslist. I liked these because they were very robust. Now that I know more about them I wish I had made them myself. All you need are 4 x heim joints, 2 x steel rods and 4 x rod ends, a little welding and you are good to go. The brackets were a little more complicated.
I'm sure you could mount on the top, but I preferred the look of keeping mine on the bottom. The bottom part of the diff housing is lower than my traction bar tabs so I wasn't concerned about clearance since it would likely hit first.
Thanks for the comments and questions guys.
Shawn
1971 C10 4x4
Old 01-19-2010, 10:18 AM   #62
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
The PO on my truck had mounted them to the same bracket as the leaf spring front mount to. Not bad engineering on his part.
Of course, this truck was maybe making 150HP so what he did not have power for he overcame with speed........
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
Old 01-24-2010, 10:29 AM   #63
silver7
silver7's Avatar
Got some stuff done this week. Finished attaching the 2nd rear traction bar and removed the spare tire cross member.
After a lot of thought and changing my mind multiple times , I finally decided to mount dual shocks in the rear. I was conflicted how to mount them as recommended - one towards the front end - one towards to rear bumper. But as discussed earlier in the thread, this would have put the rear upper shock mount in the way of where I planned to mount my aluminum gas tank. So I decided to mount both towards the front. I considered having them side-by-side, but instead I'm going to have one mounted a little bit further forward of the second so you can see both from the side. Basically, there is a space to the rear of the current bracket where I plan to put it. The brackets I plan on making will be bolt on so if I don't like the look of this I'll have them side by side since my current upper shock bracket could handle this with just a little bit of surgery.
To make this possible I needed to build a lower shock bracket that could handle two shocks side-by-side. You can see where I took a current 1/4" thick shock brackets I bought from Barnes4WD, cut them in half and welded enough 1/4" steel to allow two shocks side-by-side with a bushing in between the two (3.7" inside width).
I hope to finish my other shock bracket today as well as beginning fabrication of the two upper shock brackets.
I also wanted to say thanks to 'Brossow' for a thread he put together back in 2008 which helped me out tremendously with a shock bushing bolt he recommended. I went to NAPA yesterday and picked them up and they worked like a champ. They even came with rubber bushings with the same bolt diameter as my lower shock brackets so I plan to use these in between two two shocks going side-by-side on the same bracket.
All-in-all yesterday was a good day even though my compressor motor died. Does anyone know of a good place to send my motor to be rebuilt? I thought about doing in myself but I need it fast so that won't work.
Shawn
1971 C10 4x4
Old 01-24-2010, 11:08 AM   #64
msgross
msgross's Avatar
I like those lower shock mounts, I bought shock tabs but might modify them to look like those.. or just order a set of those...
find an electrical shop in town that might have rebuilt motors, they will probably take yours as a trade in. check the RPM's and direction CW vs CCW and keep your pulley.
The Garage:
Old 01-24-2010, 01:30 PM   #65
brossow
Amateur Rust Fighter
brossow's Avatar
Originally Posted by silver7 View Post
These traction bars will not only prevent axle wrap but they will also articulate well with my suspension. Here they are.
Not crapping on this idea but honestly curious ... without any way for the bars to pivot at all, isn't this solid connection going to cause an incredibly jarring ride? I'm also not sure how it's going to articulate with the suspension as the bars are fixed length but when the axle moves it's not always the exact same distance from the front mount point of your traction bar setup.
Compare your setup with my Caltracs as shown in this thread. Here are a couple pics:
Notice how those pivot at the front to allow the axle to move as the spring compresses and extends. Now, I'm no engineer and I could be wrong, but that setup concerns me. Thought I should at least mention it, even if I'm completely wrong.
Brent
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 01-24-2010, 02:26 PM   #66
bignbad
bignbad's Avatar
superlift make off road traction bars the mount to the top of the axle houseing to the u-bolts.
http://www.rockymountainsusp.com/tractionbars.htm
here are rear upper shock mount part numbers that i bought to replace mine wornout hacked up home made that was on the truck when i bought the truck.And here is a tread thats has some pictures of them..
http://67-72chevytrucks.com/vboard/s...94#post3069894
15698355 LH
15698356 RH
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 01-24-2010, 10:25 PM   #67
silver7
silver7's Avatar
Bigmike - Good idea. We'll see how much I can get the other motor for and I might end up doing that.
Brossow- My traction bars use the same kind of spherical heim joint as in the picture you posted so yes it will travel with the suspension. I even used the same misalignment spacers on the heim joints under my axle. I guess you missed the earlier photos which showed the my heim joints. That Caltrac bracket is kind of slick - wish I had seen them earlier. . .
bignbad - Thanks. I was looking to see if there upper shock brackets out there I could purchase. Don't mind making them, just takes a lot of time. This helps.
Shawn
1971 C10 4x4
Old 01-24-2010, 10:37 PM   #68
brossow
brossow's Avatar
They will move up and down (and side to side to a negligible extent), but there's no forward and aft motion possible as with the Caltracs. The Heim joints are the same, yes, but there's no front pivot. As a leaf spring compresses, the distance between the spring eyes increases. With the front eye fixed relative to the frame, the center of the spring -- and therefore the axle -- moves rearward. When the spring unloads (as in going over a bump) the spring shortens (eye to eye) and the axle moves forward. Your setup would seem to prevent this movement. Maybe I'm missing something, but I don't think so.
Brent
Old 01-24-2010, 11:17 PM   #69
silver7
silver7's Avatar
Spot on. I put my traction bars on my truck to limit the movement of my axle forwards and backswards - aka axle wrap. I plan to have close to 500 hp so I was concerned my lifted springs may cause a lot of axle wrap with this kind of horsepower.
I'm curious - if you want front to rear movement in your springs, why did you put traction bars on your truck?
Shawn
1971 C10 4x4
Old 01-24-2010, 11:37 PM   #70
brossow
brossow's Avatar
I must be missing something. I'll trust you on this for your setup. The more I think about it, essentially what you've done is created a sort of combined trailing arm and leaf spring suspension in one. Sorta.
As for my Caltracs, I'm not preventing fore-aft movement. That's not what a good traction control system does. My goal is the same as what you called it but not what you described: preventing spring (axle) wrap, which isn't fore-aft movement at all but rotation of the axle in place, causing the leaf springs to "wrap" into an S shape. During normal driving the axle still needs to be able to move forward and backward as I described previously and hence the need for the front pivot. Under hard acceleration, however, if the axle tries to rotate forward, the Caltracs prevent this rotation.
But like I said, I'm not an engineer and maybe I'm missing something. I'll leave it at that and hope it perfectly works for you. Sometimes I overthink things.
Cheers,
Brent
Brent
Old 01-25-2010, 12:39 PM   #71
msgross
msgross's Avatar
Silver7, won't your rear springs be as hard as a rock now?
The Garage:
Old 01-25-2010, 02:30 PM   #72
silver7
silver7's Avatar
I guess I won't know until I drive it, but I'm sure my traction bars will stiffen them up quite a bit. To be honest, I'm not too worried about it because my brackets and how I mounted them are nearly identical to the majority of traction bar set-ups I've seen on lifted trucks.
Before building this I looked into a lot of different traction bars and bracket set-ups and I never heard of the Caltracs or saw anything mounted like yours. But what you say makes sense and maybe yours offers an advantage over the other simpler set-ups like mine. Either way, I appreciate the discussion and will keep these in mind if my set-up gives me problems. I made my brackets myself so I wouldn't be surprised if I need to make another modification in the future.
On another note, brossow, can you send me the dimensions (height and width) on your rear upper shock brackets your showed in the build thread with the shock bushing bolt from NAPA? I may buy me a set of those if they will fit my current space.
Shawn
1971 C10 4x4
Old 01-25-2010, 02:46 PM   #73
brossow
brossow's Avatar
I'd love to, but everything is literally buried in the garage until spring. It would be a full weekend of work just to get at the parts to measure. Sorry!
Brent
Old 01-25-2010, 06:56 PM   #74
silver7
silver7's Avatar
I understand. Thanks
Shawn
1971 C10 4x4
Old 01-30-2010, 10:51 PM   #75
silver7
silver7's Avatar
I finally figured out how I am going to work my rear dual shocks. I saw some photos of a truck with Rough Country dual shocks in the rear end I really liked the look - symmetrical and side-by-side except mine will be oriented towards the front of the truck and the lower mounts will attach higher on the axle. Unfortunately, with the way the previous owner fabricated the current upper shock brackets I wouldn't be able to duplicate it without making some changes. As a result, I decided to remove my current upper shock mounts and replace with the spare tire cross member I removed from the rear of my frame so I could mount a larger gas tank. I plan to attach the same kind of lower shock brackets to this cross member that I already fabricated for my axle housing. 5 hours of cutting, grinding, sanding and welding in the garage today allowed me to remove the old shocks mounts and replace with some new steel. I think I may be getting the hang of this welding thing. . .
Next steps are to lengthen the cross member 5 inches (the shock mount location is at a wider part in the frame than where the cross member was originally) and weld the brackets to it when they arrive from Barnes 4WD.
Shawn
1971 C10 4x4
