#51 |
The One And Only !!!
Re: going racing friday night
If you guy's are gonna wade water with mowers ya'll should build a couple of these;
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
#52 |
Badass
we where thinking about that but the money for the tires,rims, and some sort of axles would cost wayyy to much. but we made somthing like that but smaller tires
the last one is going deepp!!!!!
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
#53 |
I have about 6 mowers and never thought of this at all. course in az we dont have much water...... did you use the stock motor to get 45mph? is it in the gearing????
#54 |
Badass
we get them all for free.ppl just throw them away or give them to us..
but just flip the front pully over you might have to cut it in half and do some welding to that pully.and for the back go down to your hardwear store and buy a pully and put it on. get like a 2.5 in pully.and a belt. that set up with be good for 30 mph. oh take off the hole brake.with it on it slows down the rearend and just melts the pads(you dont need brakes anyways ![]() oh and take the deck off too lol
#55 | |
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
#56 |
Badass
nice ive allways liked the briggs ohv motors they dont rev as high but you get more displacement.(also the hole motor and head is alum.)i bore out the intake and clean up the head.me make a tap so we can change the timing and that helps out alot in the higher rpms.for a carb i like to use my honda atc carb becuse it has bigger jets.
but ive blowen up a few (ive got smart and put a tach on the motors) i got pics on the other computer ill put up later ![]()
#57 | |
