Old 01-19-2010, 11:05 AM   #51
CPPJEFF
Re: How about the new double adjustable trac bars that came out?
Originally Posted by project 67 sub View Post
well mine is static dropped 12" in the rear without bags right now. so i am not sure exactly how long it will need to be, my new one im building is only half built until i get some sort of bracket on the trailing arm, and i will be using the stock frame one as well.
edit: also mine will most likely not be adjustable unfortunately, but i will not have more than the cost of new bushings into it (and possibly a mounting bracket).
Typically its a 24" bar but keep me posted as i have other lengths available.
CPPJEFF is offline   Reply With Quote
Old 01-19-2010, 06:29 PM   #52
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
thanx Jeff
I'm picking up another truck this weekend so I'll take a measurement on that one..
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-19-2010, 06:59 PM   #53
CPPJEFF
Originally Posted by Hottrucks View Post
thanx Jeff
Jeff
10-4 Keep me posted. Thanks
Old 01-19-2010, 07:53 PM   #54
Hottrucks
Hottrucks's Avatar
jeff Once I get that # I'll pm you my specs then you will have it to work with...
my rear is bagged with a 2 1/2" C notch in the stock spring location and I plan to use the stock frame hanger and goto the trailing arm
maybe someone else has the same spec and can grab the measurement for me??
Old 01-19-2010, 08:00 PM   #55
CPPJEFF
No problem the bars we make are 24 inch and 27 inch are the most common.
Old 01-19-2010, 08:08 PM   #56
Hottrucks
Hottrucks's Avatar
can I buy the bung and ends if I need to or would you make one up??
Old 01-19-2010, 09:13 PM   #57
gopokes
gopokes's Avatar
You mean this one?? Lets do it!
How much for that kit?
gopokes is offline   Reply With Quote
Old 01-19-2010, 10:06 PM   #58
project 67 sub
project 67 sub's Avatar
no never ordered that stuff lol. I am just wanting the brackets for the trailing arms as i am builing my own pan-hard bar and don't want to weld brackets to the lowering block. How much would that stuff be, so i know if i can order it when i get paid?
Originally Posted by cppjeff View Post
like $50.00 for those parts.
with or without shipping?
project 67 sub is offline   Reply With Quote
Old 01-20-2010, 10:46 PM   #59
project 67 sub
bump for answers
Old 01-21-2010, 11:07 AM   #60
CPPJEFF
Freight should be around $10.00.
Old 01-21-2010, 11:49 AM   #61
Hottrucks
Hottrucks's Avatar
Jeff I took a measurement from my stock frame mount to the inside of the trailing arm....the # I came up with is 36" eye to eye leaving room for a bracket on the inside of the arm...not sure how close to ride height I am since its in the garage surrounded by crap.....but I think I'm pretty close.....
is this something that you would/could make up or....heres a good Idea..maybe you guys could come up with a kit that one end is fabbed up and then it could be cut to fit your application??
thanx
the other Jeff
oh and then we would have a bit of adjustment to fine tune??
Old 01-21-2010, 12:30 PM   #62
CPPJEFF
thanx
the other Jeff
Ok we might be in buisness! I mass produce one ready to go right now at 35" inches center to center on the bungs. This sounds like a winner!
Old 01-21-2010, 03:01 PM   #63
Hottrucks
Hottrucks's Avatar
I could probably fab my bracket to make up the diff......after I posted this I was thinking that it maybe longer than that....why wouldn't I move the factory hanger to the opsite side fram rail.....I need to keep my wheels as square to the body as I can...the prostreet tires arn't going to be that forgiving when it comes to side travel...I'll have to get back to you as I work though the build.. do you have a list of pre fab lengths??...thank you for your time!!
Old 01-21-2010, 03:31 PM   #64
72gmcshorty
72gmcshorty's Avatar
I see you guys don't sell 6" rear lowering springs? I couldn't find the bolt-in cnotch on your site either. I need a kit like this without the spindles, 1/6 drop, and a couple of c-notches.
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 01-25-2010, 10:43 PM   #65
chopper john
chopper john's Avatar
thanks jeff for the great service . its orozco, called this mornin and i got a panhard and the brackets that come in one of your kits. and the guys in the service dest were great help to, thanks alot
chopper john is offline   Reply With Quote
Old 01-26-2010, 11:18 AM   #66
CPPJEFF
Great to hear this!! Thanks for coming in.
Old 03-19-2010, 12:40 AM   #67
Wildstreak
"something witty here"
Wildstreak's Avatar
whats this kits worth and could you exclude the springs and spindles from this kit? but with the double adjustable track bar. and add some c-notches lol. Im just bagging my truck and need to figure out all that I need. so the list may grow as I go.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 03-19-2010, 10:23 AM   #68
CPPJEFF
No sweat P.M. me or feel free to call me and i will get you a quote put in the system. Thanks
Old 03-20-2010, 05:47 PM   #69
Schwinn68
Schwinn68's Avatar
Hopefully I'll be in touch soon. I saw your ad in custom classic trucks and now to see that you are a sponsor on this board is great. I have a 71 chevy shortbed and I'm looking at getting the front and rear suspension package and the deluxe trac bar kit. I would like to get the front and rear disc brake kit too but one thing at a time. I have to do some more research to see exactly how much drop I want and how much I can spend but knowing you're a vendor, I'll definitely be getting my suspension parts from you.
Schwinn68 is offline   Reply With Quote
Old 03-20-2010, 05:53 PM   #70
Hart_Rod
Hart_Rod's Avatar
I got mine installed yesterday. Let just say, it's the CAT'S MEOW!!!!
r/
Hart_Rod is offline   Reply With Quote
Old 03-22-2010, 10:53 AM   #71
CPPJEFF
Sonds good bro! Hit me up on whatever you need and i will get you a great deal. Thanks
Old 03-22-2010, 10:53 AM   #72
CPPJEFF
r/
Thats what i like to hear brutha!!
Old 03-29-2010, 09:03 PM   #73
Steve Van Gent
Steve Van Gent's Avatar
Jeff,
I tried to order one of your dual adjust trac bars today, I was told the order could not be processed or shipped for a week! Is that typical lead time?
Steve Van Gent is offline   Reply With Quote
Old 03-30-2010, 12:22 PM   #74
CPPJEFF
Originally Posted by Steve Van Gent View Post
Jeff,
Yes it is unless we make special arrangements which i can sometimes help if we are in a pinch. We just VERY BUSY!!
Old 03-30-2010, 01:42 PM   #75
Steve Van Gent
Just got off phone with Jeff at CPP, GREAT GUY! Understood my delema, my lack of planning, took my order, promised to get in mail TODAY! I dont recommend everyone try to rush their order, but Jeff will get more business from me going forward!
Just to be honest, I was not even aware of CPP until this week....Been using another vendor...
