Old 05-30-2010, 01:29 AM   #51
NONHOG
NONHOG's Avatar
Re: My 48 ford shop truck
Loving it !
What did you use to seal your tank patches ? thanks.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 05-30-2010, 11:51 AM   #52
jgb7038
jgb7038's Avatar
I used 3m panel bond(8115).Its a structural adhesive for steel.I use it when putting door skins and quarter panels on at work.I have been using it for all kinds of projects on my own builds.It obliviously will glue metal together,even dissimilar metals like steel to aluminum,but also acts as a sealant,its not affected by gas,oil,chemicals once it has cured,and acts as a rust preventer where ever you use it.
jgb7038 is offline   Reply With Quote
Old 05-30-2010, 12:48 PM   #53
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Totally killler ford build man im lovin it..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-05-2010, 09:55 PM   #54
jgb7038
jgb7038's Avatar
Finished painting the rear axle,
cleaned and painted the underside of the cab floor,and frame under the cab,still have some touch up to do.
Reinstalled the gas tank.
Old 06-05-2010, 09:57 PM   #55
jgb7038
jgb7038's Avatar
Built a rack to hold the bed so I can do the body work on it.Also can roll it around the shop now.
Old 07-06-2010, 11:15 PM   #56
jgb7038
jgb7038's Avatar
Got the new front bed panel installed.
Old 07-06-2010, 11:19 PM   #57
jgb7038
jgb7038's Avatar
Cleaned up the inside of the cab,sealed up the joints and added some paint.
Old 07-06-2010, 11:24 PM   #58
jgb7038
jgb7038's Avatar
Before I finished up the inside of the cab,I needed to finish welding the fire wall/trans tunnel.Of course to do that,Had to pull the front sheet metal off again,and pull the motor/trans for access.
I put it up on stands to make the job easier.....
Old 07-06-2010, 11:30 PM   #59
jgb7038
jgb7038's Avatar
While it was in the air,I wanted to finish welding the bottom of the cab corners and cowl extensions.Needed to clean off a little filler first........kinda got carried away....
Ended up stripping the rest of the cab,except the doors.I had found some small rust bubbles where the top chop joints were at,so i figured i better clean it out now and fix it so it wont bite me in the butt later...
I did end up finishing the cab corners....
Old 07-06-2010, 11:33 PM   #60
jgb7038
jgb7038's Avatar
Rebuilt the front cab mounts.
Cleaned up the firewall and sealed it up before filler.
Old 07-06-2010, 11:40 PM   #61
jgb7038
jgb7038's Avatar
Finished boxing the frame rails where the motor/trans were blocking before.
Had to box the area around the front spring,so I dropped the front suspension and got to work.
With every thing boxed and cleaned ,added some paint to finish it out.
The front suspension will get color later,being that some parts are going to be painted,and some powder coated.
Old 07-06-2010, 11:42 PM   #62
jgb7038
jgb7038's Avatar
Added some sound deadener to the inside of the cab to see if I had enough,which I did not.Guess im going to have to get some more.
Old 07-30-2010, 10:21 AM   #63
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Oh the talent! Nice creation you're building!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 07-30-2010, 02:17 PM   #64
cayoterun
Junior Member
cayoterun's Avatar
Greeat work! Tip-o-tha-hat to you on a fantastic job. Love those projects from the throw-away parts piles.
Cayoterun
Cayoterun
Okla. Panhandle
I think I'll do it myself and pay the extra $500.
cayoterun is offline   Reply With Quote
Old 08-01-2010, 12:38 PM   #65
cayoterun
Junior Member
cayoterun's Avatar
I really like the front end on your truck. I'd like to have something similar on my next project.
Wish I had your skills and patience.
Cayoterun
Cayoterun
Okla. Panhandle
Old 09-16-2010, 04:24 PM   #66
jgb7038
jgb7038's Avatar
Though It was time to update this build,so here it goes.......
Installed a dual latch system for the hood.Its actually a small bear claw system meant for tail gates.Added some door poppers to open the hood.
Added the strikers to the hood,and built an inner brace...twice.
Needed to re-peak the hood,ground off the old brake line peak,added new solid 1/4" round rod.
Old 09-16-2010, 04:40 PM   #67
jgb7038
jgb7038's Avatar
After the prior owners work on it,cows walking on it in a field,and my cutting the snot out of it,the hood needed a little heat shrinking to help it conform to its new shape.I have only done this one time successfully,so of course.I jumped in head first....Four evenings later,I got it to conform to my will....Its if far from perfect,but it is no longer stretched and the smaller ripples can easily be filled later.
This is how it looked after the shrinking.....
I moved on to the interior panels. Im doing this now,so I can work without having to worry about scratching the paint. I used some panel board from the local diy store and left over wood from past projects.
Rear cab panel:
Door and kick panels:
Arm rests:
Center console rear storage:
All the panels are just roughed out,they will get final fit and finished when I get to the actual upholstery part of the build.The upper center console will also have a solid civer to hide the door/lock assembly.
Old 09-16-2010, 04:49 PM   #68
jgb7038
jgb7038's Avatar
Spent my labor day weekend working on the bed.Got the first round of filler/primer work done.Still need to go back and do the touch ups and re-prime and block it .
Spent the last few days working on the cab.again,got the first round of filler/primer on it.Still need to do the detail work,jambs,dashboard,inner sheet metal,etc.I can see better now,what still needs to be done before the next round of priming/blocking.....
Now I feel like Im making some progress again,hopfully it will keep me motivated though all the tedious jamb/dash work I have to do now......
Old 09-16-2010, 11:15 PM   #69
FRENCHBLUE72
PROJECT 7DEUCE
She looks killer did I miss the color choice or have you decided on one?
MEMBER #6377
Project "7DEUCE"
Old 09-16-2010, 11:50 PM   #70
JHT67
JHT67's Avatar
WOW! Just went thru the thread, and you are gettin-r- done on so many levels. Just plain awesome build.
JHT67 is offline   Reply With Quote
Old 09-17-2010, 06:37 AM   #71
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Just stumbled on this build and read through the thread. Very cool build. I've been thinking about doing something like this once my '65 C10 is done. My skills are nowhere close to yours, but a build like this looks like a blast. Tuning in for the rest for sure.
fryer1979 is offline   Reply With Quote
Old 09-18-2010, 02:46 AM   #72
884x4Sub
p p pullin'
884x4Sub's Avatar
Man Ive learned some things from your fab work......awesome!...love it
what kind of sound deadener did you use in the cab?
doug
884x4Sub is offline   Reply With Quote
Old 09-18-2010, 10:25 PM   #73
McC_65_91
McC_65_91's Avatar
your fab work is incredible... sick truck
McC_65_91 is offline   Reply With Quote
Old 10-15-2010, 03:41 PM   #74
63 & 64 Bowties
and a few others
Holy Crap. Great job.
I was thinking "what great fab skills" then I get to the door panels and console part, you're a good carpenter too?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-04-2011, 12:02 AM   #75
jgb7038
jgb7038's Avatar
Just realized its been quit a while since I updated this build,so here it goes....
I have been blocking primer for a while now.I got thru the first round of it,
I always liked the stock '48 hood side trim,so I put it back on before the second round of primer.
Primer round 2....
Blocking round 2....
I really hate blocking,so in an effort to keep my self motivated,I had some paint sprayed on the front sheet metal to see if all the blocking is worth the extra work....
Hood:
Hood Side Panels:
