Old 11-11-2010, 05:26 PM   #51
blazerboy72
Re: Project Anna (71 2wd Blazer)
I also mocked up the electric fans. It almost looks like they were made for it, and not a nissan.
blazerboy72 is offline   Reply With Quote
Old 11-12-2010, 09:34 PM   #52
blazerboy72
I bought a 72 Highlander rear seat to narrow 6 maybe 7 inches so I can tub the rear. I also have 72 doors to go on it, so I'm thinking about making it a 72 2wd highlander replica.
Old 11-13-2010, 08:50 AM   #53
Like the fan setup a lot! What Nissan they come from?
Old 11-13-2010, 03:17 PM   #54
blazerboy72
I believe an altima, ill have to check the part number to see for sure. A friend of mine worked at nissan and there were three sets of these thrown in dumpster because they had small cracks in the shrouds so he gave me 2 sets. Cant beat them for the price.
Old 11-18-2010, 04:45 PM   #55
blazerboy72
Got the hot side built, just have to finish welding it and clean it up. Also got one of the tubs widened and the floor narrowed.
Old 01-27-2011, 06:48 PM   #56
blazerboy72
Put the front clip back on and got the hot side fully welded. Also got in the 29x12.5x15 MT's too.
Old 01-29-2011, 08:50 PM   #57
blazerboy72
Anna is topless!
Old 01-29-2011, 09:12 PM   #58
PHAT TONY
PHAT TONY's Avatar
I was gettin pretty excited there for a minute....just gonna rig it to the door opener?
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 01-29-2011, 09:15 PM   #59
blazerboy72
I just have 4 eye bolts with ratchet straps on each corner. Lot easier than trying to lift it alone.
Old 02-10-2011, 04:24 PM   #60
blazerboy72
Got one seat done. It isn't perfect but I don't think it is too bad for my first attempt.
Old 02-10-2011, 04:41 PM   #61
VA72C10
VA72C10
VA72C10's Avatar
Looks pretty good. Since you said it isn't perfect....Leave it out in the sun for a bit the next warm day you get and it'll help it stretch/settle better also....but it looks good in the picture.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-17-2011, 09:45 PM   #62
blazerboy72
Finally made the decision SHE WILL BE DRIVABLE BY SUMMER!!! I just spent $932 for the fuel system minus the injectors and fuel cell. Now I just need to plumb the brakes, build a driveshaft, finish up the turbo plumbing, and rebuild the steering.
Old 02-18-2011, 10:24 AM   #63
SOON2BLAZE
SOON2BLAZE's Avatar
kickin azz!
SOON2BLAZE is offline   Reply With Quote
Old 02-19-2011, 05:43 AM   #64
blazerboy72
Ordered the 35"x12"x4" intercooler and some 80lb injectors. I hope this E85 is worth the extra effort. I figured even if I don't like E85 I ill have a 1000hp fuel system.
Old 02-21-2011, 04:12 PM   #65
blazerboy72
Just received the fuel lines. Summit accidentally sent me a paper element filter instead of the stainless one. I called customer service and was told to throw it away, that the correct one was on its way. Do they really think I'm going to throw away a $74 fuel filter? Should have time to work on it Thursday. Hopefully by then the waste gate and blow off valve will be here.
Old 02-21-2011, 08:24 PM   #66
1969~C-20~Heavy-Half
1969~C-20~Heavy-Half's Avatar
Love the build keep up the good work.. Any advice you could toss my way in lowering one of these?
1969~C-20~Heavy-Half is offline   Reply With Quote
Old 11-25-2011, 08:30 PM   #67
blazerboy72
Guess I should update this. I sold another one of my toys to get money to fund this project. I have also purchased a second 2wd frame to build up and then put my body on. The engine is about to be torn back down for a more turbo friendly cam, patriot gold dual springs and hardened push rods. The steel should be here this week for the tubular crossmembers. I also have new stainless brake lines on the way from inlinetube. After I get everything mocked up ill tear it back down for paint. Hopefully it will be up and running by spring.
