Old 04-01-2010, 02:30 PM   #51
wholio
wholio's Avatar
Re: My Restoration Begins on a 1969 k5
ok i know i been asking a lot of questions about where and how to mount a 2wd suspension on my 4x4 frame, i just want to really be sure before i start drilling
but yeaha ok so after alot of measurements i was about to find one pre-existent common holes on the 4x4 frame, heres some pictures, can some one let me know if im in the right direction, before i start drilling the rest of the holes
wholio is offline   Reply With Quote
Old 04-01-2010, 02:33 PM   #52
wholio
wholio's Avatar
ok the next concern i have is that i mounted the cross member the holds the trailing arms, but the axle goes behind the orginel bump stop on the 4x4 frame. i want to kno if this is normal
Old 04-01-2010, 03:38 PM   #53
notsolo
notsolo's Avatar
You may be in the correct place. but ..measure 10 times drill once. Go back to the 2wd spec drawing. measurements are from ctr radiator support. I subtracted 16.50 off the 38.40 and I got 21.90 or 21 7/8 " ctr front axle to ctr radiator support. From there check ctr front axle to ctr rear axle 104" good luck
notsolo is offline   Reply With Quote
Old 07-19-2010, 09:44 PM   #54
wholio
wholio's Avatar
Its been a while since i messed with my truck, kinda got distracted but its koo im back and im goin at it harder then ever, instead of a restoration im goin for a full out custom blazer with corvette suspension all the way around with porter front cross memeber , shaved all the way around,for ever convertible, with a 572 motor maybe, more to come here are some pictures to keep yall updated
Old 07-20-2010, 12:29 AM   #55
wholio
wholio's Avatar
more pics
Old 09-22-2010, 10:53 AM   #56
wholio
wholio's Avatar
heres more pictures of my current updates
i finally got around to cutting my k5 in half and cuttin the cab take alook at the pics
Old 09-22-2010, 10:56 AM   #57
wholio
wholio's Avatar
here you see the back half of the of my 1969 k5 and the front half of my 1967 c10, i cant wait to see my baby complete
Old 09-22-2010, 01:07 PM   #58
1956cameo
1956cameo's Avatar
I wish I had more spare time so I could help you on that project! Looks like you are getting it knocked out!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 10-27-2010, 03:55 PM   #59
wholio
wholio's Avatar
bought some corvette sawblades for when i install the corvette suspension got em for $100 with tire
Old 10-27-2010, 05:36 PM   #60
wholio
wholio's Avatar
had to get the chasis rolling and ready for sandblast n primer soon
Old 10-27-2010, 05:39 PM   #61
wholio
wholio's Avatar
this is how the doors look after installed after the welding to the body was done, i think the gap isnt big enough n the body line is kinda off alil bit...
Old 10-28-2010, 09:02 PM   #62
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
That doesn't look too bad, can you adjust it out? How is the gap at the top of the door and windshield frame? Enough room to swing the door up any?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 01-05-2011, 07:22 PM   #63
wholio
wholio's Avatar
i Got bored so i took a wire wheel to my frame to try n clean it up a bit and sprayed it with an all porpuse paint flate black for now
the only problem i have now is how im i gunna do the inside of the frame lol
the out side was fairly easy, i dont know about the inside, does any one have any tips?
it aint custom unless you CUT IT!!
Old 01-05-2011, 07:27 PM   #64
wholio
wholio's Avatar
i also painted the side of the truck to better see the inperfections, i dont know if you can tell but one of my main concerns i have is that the rocker panel and doors dont line up when the door is close, which makes me believe that the cab was welded off to the right n not leveled, idk, i also think it may be the door, its not in the best of shape or even straight at the bottom, or i was also thinking that maybe the rocker panels were welded to close idk
imma pos some pictures yall let me know
Old 01-05-2011, 07:33 PM   #65
wholio
wholio's Avatar
heres some more pictures
as u can see in picture 1, u can see that it kinda leans to the left
in picture 3 its of the door closed and how it lines up wit that cab
Old 01-05-2011, 07:39 PM   #66
wholio
wholio's Avatar
heres some more pictures of the door closed against the windshield frame
Old 03-11-2011, 11:44 AM   #67
wholio
wholio's Avatar
had a little time yesterday so i mounted the body on to the frame to see if the 2wd conversion was done correctly,
Old 03-11-2011, 11:47 AM   #68
wholio
wholio's Avatar
as u can see in the front is shows the tire being to far back and in the rear it shows the wheel to forward,
im just wondering if thats normal or so i have to re-do it , im not to concern aboy the rear im more concern in the front can some one jump in an let me know thanks
Old 03-12-2011, 01:02 AM   #69
Deep C 915
Deep C 915's Avatar
I just took my body off & I did not use any supports.......everything went fine. Now are we suggesting that the body can get tweeked and sit funny on frame when placed back on frame if not supported. This looks like a safe removal right.....
Deep C 915 is offline   Reply With Quote
Old 03-14-2011, 11:58 AM   #70
wholio
wholio's Avatar
me personality i dont think it would affect the shape of the tub. as long as ur not addin stress to it or have it unleveled
Old 09-27-2011, 01:47 PM   #71
wholio
wholio's Avatar
An unexpected turn of events has come up n my project is off to the scrap yard in the next week or so maybe later on I'll find a much easier project to start out from, don't get
Me wrong I was up for a challenge but now I have to move outta state n can't take it with me
Old 09-27-2011, 11:34 PM   #72
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
please dont scrap that tub! that is SOOOOOO much better than mine! wonder how much it would cost to ship that to Iowa.... i mean heck, my doors are welded in anyway....
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 09-30-2011, 06:52 PM   #73
wholio
wholio's Avatar
i have no choice
Old 10-01-2011, 08:41 AM   #74
chevy2racr
chevy2racr's Avatar
if i was close enough to come get some of it the "box" section I'dget from ya for sure... put a post up about it see if anyone close enough might give ya what the yard would for it....
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 10-15-2011, 10:18 PM   #75
SILVER_WS6
so can you sell a pass fender
SILVER_WS6 is offline   Reply With Quote
