Old 03-28-2010, 11:19 AM   #1
383Ram
383Ram's Avatar
Re: Halfbreed - GMC Z71 + IH Extd Cab
Neat project. I am digging this. I read this thread yesterday and was impressed.
As far as the floor deal goes, i dont think the on paper .6" difference is worth it to channel the floor into the cab. I would rather space the bed up to where it need to be and get the stance with the suspension. I dont know what exactly the floor looks like between the two vehicles, but would it be a little better to put the Chevy floor on top of the remnents of the IH floor instead of the IH floor on top of the chevy? That will help a tiny little bit.
454/4 speed, '85 Dodge Ram hybrid build in progress
454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track
Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050
Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289
383Ram is offline   Reply With Quote
Old 03-29-2010, 04:08 PM   #2
BlueJeep
BlueJeep's Avatar
Originally Posted by sparkydog View Post
Now dropping the body is extra work compared with just laying the remnants of the IH floor onto the GM floor in a simple lap joint. Not too much extra but extra none the less. The other choice is to just spacer the IH bed .6" higher over the frame and call it good.
Hmmm, decisions, decisions. If it had been a bigger difference, like 1 or 2 inches then I would do it for sure because I want a low ride stance and will plan to use an aftermarket lowering kit. But .6" is right at the ragged edge of being worth it.
If you weren't already splicing the floor from the GMC I might say space the bed up...but since you're this far...drop the cab down to where you want it. It might even be easier to work with, depending on how it lays out.
Also, after seeing your last photos, I vote for slide the cab back and center the front wheels. I think the work of sectioning the front clip wouldn't be worth the reward. Plus, looks like your steering column/wheel are already back too far into the passenger compartment in your "forward" position.
Love the project, I'm a secret IH fan as well!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-29-2010, 04:21 PM   #3
sparkydog
sparkydog's Avatar
Yeah the basic tradeoff is:
Cab forward means I HAVE to section the hood and fenders and find a shorter steering column and change the brake pedal distance. The benefit is I get a longer bed, the "cooler" look that I want and less work to the back of the cab bottom (where it will hit if I slide the cab back).
Cab back means it looks OK with the stock IH fenders and hood. Don't have to mess with the steering column or brake pedal. DO have to mess with the bottom rear of the IH cab because it will hit the frame/fuel tank. Also means the bed will end up at 6.5 ft or so.
And on the sectioning of the nose - I know what and how I would do the hood but the more I look at the fenders and their funny little IH swoop thingy, the more I don't know a clean way to shorten it up without rebuilding the whole side.
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 03-29-2010, 10:22 PM   #4
BlueJeep
BlueJeep's Avatar
I was looking at the fenders too wondering how you figured on doing that.
I'd also add to your list of having to change in the forward position: seat mounts for the front seats and I'm also wondering how you'd fit heat/AC under a dash if it's that far forward...
I wonder if another way to achieve the look you're after with the front would be to kinda do the opposite of what chopped top guys do with the windshield. Instead of laying the top back, what if you would lay the bottom forward, and shorten the hood as you've planned. That way your fenders could stay stock, your hood could be shortened, and the nose would look "stubbier"... Maybe you could take the "kick" out of the front of the door that way, and have the leading edge of the door be straight. Think 61-63 Chevy truck vs 64-66 Chevy truck. Hope I'm conveying what I'm thinking.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 03-29-2010, 11:23 PM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
In my personal opinion, I think the shorter 6.5' bed would would look better, especially with the crewcab. But its your truck and you have to do it like you like it. Either way, I'm a big fan of your truck!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-27-2010, 12:43 AM   #6
nuke1
nuke1's Avatar
Now that is looking amazing, as for the runaway, i could not control my laughter when I saw that, too funny, but not funny. I really like the way you are goin about building this. one question, thou. Do you plan on shortening the bed or lengthening the frame if need be, just wondering, I do not think that I saw that here, but I could be wrong.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-27-2010, 09:39 AM   #7
sparkydog
sparkydog's Avatar
Yes I have the 8ft bed. I will need to shorten it to approx 6.5ft.
Balls and a Sawzall
Project Halfbreed
Old 03-27-2010, 11:54 AM   #8
NONHOG
NONHOG's Avatar
Just reading this time instead of skimming through the pics.
Today I find out your not a youngster that I assumed you were. Heck your an old fart like me.
Aleve and margarita's, I can relate.
Love the build, keep up the great work.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 03-27-2010, 01:51 PM   #9
ERASER5
ERASER5's Avatar
I am in awe.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-27-2010, 04:19 PM   #10
sparkydog
sparkydog's Avatar
Yeah one of the motivators for me to try this project was I'm starting to get bad enough arthritis that I know I've only got a few more years left before I won't be able to do stuff like this. Waaaaaaah..
OK back to work.
Balls and a Sawzall
Project Halfbreed
Old 03-27-2010, 02:23 PM   #11
Stitch
Location: Where I come from, it's cornbread and chicken...
x2
Stitch is offline   Reply With Quote
Old 03-27-2010, 03:00 PM   #12
sparkydog
sparkydog's Avatar
Aw shucks guys, thanks for the compliments and encouragement. I have learned that it really doesn't take much talent to rip stuff up - just balls and a sawzall. The talent comes in putting it back together!
Here I am now with more sheet metal gone than I ever expected. All for perfectly good reasons, however the project is still not quite to the turning point of CONstruction. When I get to the point that I am tack welding on a routine basis I will feel more like I deserve your compliments!
Balls and a Sawzall
Project Halfbreed
Old 03-28-2010, 08:06 PM   #13
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Really diggin this project....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-01-2010, 08:10 PM   #14
sparkydog
sparkydog's Avatar
Ducks??!!! Who are the Ducks??
Balls and a Sawzall
Project Halfbreed
Old 03-29-2010, 03:46 PM   #15
sparkydog
sparkydog's Avatar
On Sunday I finally took the GMC headlights off just for something to do. I figured somebody was eventually going to ask me why I was trying to use them on the IH grill.
Then on to some real work which was to add a temp brace to the front of the cab and then cut out the IH floorpan.
And I even managed NOT to cut through the GMC floor - which has been known to happen with me!!!
Balls and a Sawzall
Project Halfbreed
Old 03-29-2010, 03:47 PM   #16
sparkydog
sparkydog's Avatar
I also did some minor trimming along the corners of the GMC firewall and this allowed me to position the cab farther forward and closer to final ride height. I still can't drop the cab down to the proper level until I do a little more trimming on some cowl interference. But now I can begin to make my final decision on the fore/aft placement of the cab relative to the front wheels. In these next pictures I have it as far forward as I might want to put it - this would be where I would have to section the nose of the truck or else it would look like a dork truck.
Balls and a Sawzall
Project Halfbreed
Old 03-29-2010, 03:53 PM   #17
sparkydog
sparkydog's Avatar
Milestone
After doing all this and getting the cab lower and being able to slide it fore/aft, I was able to actually "see" the real truck that was in my head and on those crude photo sketches. It was an important motivational milestone. Felt great!
Boy am I getting tired of cutting..
Balls and a Sawzall
Project Halfbreed
Old 03-29-2010, 11:16 PM   #18
67ChevyRedneck
67ChevyRedneck's Avatar
I think the 6.5' bed would look great
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-30-2010, 06:08 PM   #19
89muscletruck
89muscletruck's Avatar
that body line on the fender might not be too much of a headache to work around...
just an idea but, maybe if you took 3 inches out dircetly above the wheel then too some off the back of the fender?
kinda like this
89muscletruck is offline   Reply With Quote
Old 04-01-2010, 07:44 PM   #20
Frizzle Fry
Frizzle Fry's Avatar
Personally, I like short beds and that bobbed nose just doesn't look right to me. What about this idea? Use a rear wheel arch to clean up the front lines and place it wherever you want (centered on your wheel placement).
Frizzle Fry is offline   Reply With Quote
Old 04-01-2010, 08:15 PM   #21
sparkydog
sparkydog's Avatar
Oooooooooo!!! First time I have seen my baby in a single color!! (I don't know how to use photoshop.) Thanks for posting that image! I see you are another Oregonian. BTW you are a god with the fab you are doing on your stuff. I'm following along with your current build. Really enjoy it.
Balls and a Sawzall
Project Halfbreed
Old 04-01-2010, 11:58 PM   #22
Frizzle Fry
Thanks man. I did that all in MS Paint. The real photochoppers are truly magicians with that stuff. I just read through your whole thread. Love the cut/paste mentality. Looking forward to more. If you know my builds then you know which direction I would have gone (diggin the CC concept though).
Old 04-02-2010, 06:30 PM   #23
sparkydog
sparkydog's Avatar
Then this is probably more your style!! I've traded emails with the owner. It has a mild roof chop and the front window was laid back. And now that I am studying front fender wells, I'm looking at this and thinking maybe he messed with the swoosh thingy too.
Balls and a Sawzall
Project Halfbreed
Old 04-02-2010, 01:36 AM   #24
Racinaround
Racinaround's Avatar
sub.
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 04-02-2010, 06:48 AM   #25
Stitch
it's a fat hoe...lol
