05-09-2010, 03:17 PM | #51 |
Desert Dweller
Re: Airconditioning
Thanks man, it does look tight in there... Probably not going to be able to have room for the glove box...
What did you use for vents? Did you cut them in the dash or mount under it? Thanks again, Tony |
05-09-2010, 10:45 PM | #52 |
Re: Airconditioning
The kit I got had 3 under the dash vents, one rectangular one in the middle and two round ones for each side.
05-09-2010, 10:48 PM | #53 |
Re: Airconditioning
here are a couple of pic.
05-10-2010, 12:41 AM | #54 |
Re: Airconditioning
Tony,
One more option for you, You can make a small roll pan that mounts under the dash that can house the a/c vents.Your roll pan can either bolt on to the bottom of the dash or weld to the dash. Justin www.scottshotrods.com |
