Old 06-08-2011, 12:57 AM   #51
boucher racing
boucher racing's Avatar
Re: Inline 250 - T3 Turbo - w/ Video
Originally Posted by Junkpyl View Post
Your truck is awesome! I have been tinkering with my 67 for over 2 years now and want to put a turbo on it. I have the turbo along with a clifford 4bbl intake and headers but not sure which direction to go. Your idea with the stock intake/exhaust look like a good alternative I hadn't even considered. Any updates? Keep up the great work. Subscribed
I wanted to keep the stock look of the intake/exhaust manifolds, just make them flow better. I hogged the factory 1bbl out to accept a 2bbl. I figured I would try it, if it didn't work, I would buy an Offenhauser. It seems to be working just fine. I believe with the Clifford, you cannot run the factory exhaust manifold, so running a simple J-pipe, as a charge pipe to the turbo would not work.
I have changed the springs out in the HEI and it runs even better. I had the heavy springs and it was not advancing quickly enough, causing a rich bog. I may even try the lightest springs and see how it reacts. I switched out the 31 for a #28 squirter and changed the accelerator pump cam to the white one in position 1. It is all fine tuning from here on, the AEM uego is a huge help. I highly recommend.
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 06-08-2011, 01:06 AM   #52
tropa
tropa's Avatar
awesome truck...love it!!!
tropa is offline   Reply With Quote
Old 06-09-2011, 12:32 AM   #53
Junkpyl
Very cool, I can't wait to see some more updates on your truck. I like the stock look with subtle performance mods. Keep up the great work.
Junkpyl is offline   Reply With Quote
Old 06-11-2011, 03:47 PM   #54
AllenKarber
Very,very,very cool!! I love it!
AllenKarber is offline   Reply With Quote
Old 06-21-2011, 07:02 PM   #55
MBEXHAUST
MBEXHAUST's Avatar
Very cool I have a 6 truck and was looking to sell it. After seeing this I could see my mind changing. Nice work.
MB
MBEXHAUST is offline   Reply With Quote
Old 06-21-2011, 08:36 PM   #56
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
I just saw this thread for the first time. Very cool! I like the build over all. A lot like what I would like to do with my small block, a budget turbo set up. Very cool!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 10-25-2011, 03:45 PM   #57
rpmerf
rpmerf's Avatar
Just saw this engine in another thread. Very cool! The turbo almost looks like it was meant to be there. Any status updates?
how are you controlling boost? vac line straight from the manifold to the waste gate?
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 10-25-2011, 05:07 PM   #58
MusicMan70
MusicMan70's Avatar
sub scribed! Nice GMC!
MusicMan70
1961 GMC Suburban
MusicMan70 is online now   Reply With Quote
Old 10-25-2011, 10:37 PM   #59
boucher racing
[/QUOTE]
how are you controlling boost? vac line straight from the manifold to the waste gate?[/QUOTE]
I am using the factory internal wastegate that is on the turbo. The only problem that it was a HD which means the PSI range was like 17-30 psi. So I was hitting 19 psi at times! I modified the wastegate to open earlier by designing a spring assist.
Check it out if you like:
http://youtu.be/rogCn4AJYsY
To control boost, there is a port on the intake side of the turbo that connects to the wastegate.
"Cropwell" 66 C10
Old 10-25-2011, 10:42 PM   #60
boucher racing
The truck is running great. I have set the wastegate to open at 10 psi. I drove it over 300 miles last week with no problems. The only issues is that my 1st gear in my T5 is trashed. It will not stay in, pops out everytime. I love driving it and hearing that turbo spool up and wastegate flutter out. Here is a pic of the finished engine as it sits. Possibly a intercooler set up this winter.
"Cropwell" 66 C10
Old 10-25-2011, 11:45 PM   #61
rpmerf
rpmerf's Avatar
Wow pretty cool mod on the waste gate! Could you not find a WG set at around 8 psi or did you want the HD one so its easier to push higher?
Are you doing anything for your PCV system while your in boost?
1997 GMC Suburban
Old 10-26-2011, 12:24 AM   #62
boucher racing
I wanted to use what I had, b/c a new one was a 100 bucks. Plus, I can always turn this one up.
There is no PVC system, I am running a crankcase vent though. I have two inline valve cover breathers connected to a 45 deg nipple port on my exhaust about 3' down the downpipe. It suprisingly provides alot of suction or vacuum to pull positive pressure out.
"Cropwell" 66 C10
Old 10-26-2011, 01:05 AM   #63
rpmerf
rpmerf's Avatar
oh cool venting into the exhaust seems to be the best way to do it.
1997 GMC Suburban
Old 11-26-2011, 01:57 PM   #64
jiyrulz 1
jiyrulz 1's Avatar
Awesome engine. Makes me wish I hadn't ditched my 250.
jiyrulz 1 is offline   Reply With Quote
Old 11-26-2011, 03:18 PM   #65
kissingbug1978
subscribed
kissingbug1978 is offline   Reply With Quote
Old 11-26-2011, 07:28 PM   #66
porter90
porter90's Avatar
this thread is making me have some serious second thoughts about gettin rid of my 250 as well...hrm where does the turbo start boosting?
porter90 is offline   Reply With Quote
Old 11-26-2011, 08:18 PM   #67
VA72C10
VA72C10
VA72C10's Avatar
very cool! Love the engine bay vibe too!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-26-2011, 10:21 PM   #68
boucher racing
If you mean, WHEN?, It spools up quick around 1500 rpms. The engine is not a high RPM machine, so shifting is pretty quick. The psi's climb really quick, when my wastegate was not working correctly, at around 1500 rpm it was 1-2psi and at 2000 rpm it was at 15psi +! I had to get out of it quick.
I still want to put a intercooler on it this winter and swap the T5 out for one that 1st gear actually works. All in all, very pleased.
"Cropwell" 66 C10
Old 11-26-2011, 11:02 PM   #69
c10hevy
c10hevy's Avatar
Subscribed! Im going to get my 250 rebuilt in december then follow exactly in your footsteps! 66 GMC and all!!
c10hevy is offline   Reply With Quote
Old 11-27-2011, 01:06 AM   #70
porter90
porter90's Avatar
yea thats what i meant! lol it was something i had always wondered because all of the turbo cars i have experience with seem to boost around 3000 and i dont really like to go much higher than that with mine. thats really awesome tho, if i knew how to subscribe i would! this is really cool and i think im going to look into it for sure
Old 11-27-2011, 09:39 PM   #71
awbrown
Did you destroy first gear , or do you think it was on it's way out ??
awbrown is offline   Reply With Quote
Old 11-28-2011, 12:52 AM   #72
boucher racing
i believe that is a synchro issue. It will not stay in first at all with a load. Also, this trans is loud! Mabey all T5's are noise, I dont know. I have a clean NWC donor (the tailshaft swapper) that I will install soon.
"Cropwell" 66 C10
Old 11-28-2011, 05:46 PM   #73
1963c-10
1963c-10's Avatar
Very cool build. The inlines are such great engines
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-30-2011, 07:26 PM   #74
jbon64
jbon64's Avatar
very cool set up !!!!!!!!!! one question , in your opening post it says GN T3 turbo . i assume that would be a grand national turbo ? as in a buick GN
hey.....smell my finger
64 nova wagon , 63 nova convertible
jbon64 is offline   Reply With Quote
Old 11-30-2011, 09:32 PM   #75
boucher racing
You are correct. Its from a low mile 87 Buick Grand National, factory wastegate and elbow.
"Cropwell" 66 C10
