#51 |
Re: My first truck
no im going to have to whole truck blue except the top of the cab and its going to be silver
71 Chevy c10 pickup with a 350 small block ![]() |
#52 |
Re: My first truck
man she sure is offline alot
#53 |
Grandpa in the rustmobile...
Re: My first truck
its summer she has other things to do than constantly work on trucks lol
ok imma go weld some more pannels in and holes up.. ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#54 |
Re: My first truck
nice looking truck
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
#55 |
Re: My first truck
lol yeah i have been busy but i am suposed to work on my truck tomorrow
#56 |
Re: My first truck
my motor
#57 |
VA72C10
![]() Join Date: Mar 2008
Re: My first truck
looks good. I'm thinking of a satin black truck with lime green accents for my next build....
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#58 |
Re: My first truck
WoW looking good, I have always liked that color.
1980 1/2 ton shortbed project 1978 grand prix project Never stop trying... Last edited by Dusty4x4; 06-26-2010 at 03:04 PM. |
#59 |
Re: My first truck
Definitly grabs your attention keep up the good work and please more pics we love pics
1969 Chevy C10 Short Step -Project 2005 GMC Sierra Crew Cab 1500 -DD 2017 Laguna Orange Roadglide - Good Weather DD |
#60 |
Re: My first truck
nice engine wait tell you paint the block and heads thats fun i just got done a couple of days ago paintin mine hugger orange
#61 |
Re: My first truck
wow that looks good! Have you driven it yet???
have you got the toolbox working yet
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 Last edited by oldblue1968chevy; 06-28-2010 at 08:05 PM. |
#62 |
Re: My first truck
No I have not but my dad and grandpa have and it over heated
#63 |
Re: My first truck
well lets see or here i mean wait you cant hear through the internet so um lets just see any type of progress
#64 |
Re: My first truck
Any updates on this one?
#65 |
Learning As I Go
Re: My first truck
whats the thermostat rated at? 190 or 200? make sure theres coolant in it not all water you gotta have a leak somewhere if it over heated
1972 Chevy C-20 Longbed 2wd Granny Low with a Crate 350: Air Gap Manifold, Edelbrock 600cfm, HEI, Headers to a 40 series flow (soon to be dual again) |
#66 |
Re: My first truck
well guys and gals the lasest news is my boyfriend thought he could drive my truck and he ended up striping the colum out of it so now i have tno fix that as well so as a result Girls NEVER let your man drive you truck
#67 |
Re: My first truck
i let my gf drive mine she did a burnout on accident
![]() too bad maybe u can find a column on the parts board
#68 |
Learning As I Go
Re: My first truck
wait stripping the column out? huh but that dont make sense unless it means he took the column out of it
#69 |
Re: My first truck
you cnt shift it anymore. it wont go into any gears at all
#70 |
Re: My first truck
It sounds like a broken linkage to me have u checked by the trans yet?
71 c10 with a 305. new dd wohoo 1956 chevy bel air hard top with a 327. 1998 honda passport V6 old dd. |
#71 |
Re: My first truck
Will it shift if you line up the two "ears" on the column? I've seen it happen a few times where the column gets really worn so that "sloppy" shifting will cause the linkage to get hung up. It seems to happen if you don't shift carefully between first and second........when you pass through the middle as you are shifting up and back, it tries to move both levers at once and ends up hanging in between.
Usually, all it takes is to pop the hood and manually move the two "ears" on the column until they're parallel, then you can get back in the cab and shift normally. You have to make sure you shift carefully so it doesn't hang up again. That may or may not be the problem.......or the fix......but that's the only thing I've seen that is similar to the symptoms you described. I hope it helps. |
#72 |
Re: My first truck
we tryed that and he actully broke it. have to either fix the coulm or but the shifter on the floor
#73 |
Learning As I Go
Re: My first truck
get a lokar floor shift kit
#74 |
Re: My first truck
Im assuming this is all 3spd on tree?
#75 |
Re: My first truck
i have a kit to put it on the floor and yes it is a 3 on the tree
