06-09-2010, 12:36 PM | #51 |
Under Construction
Re: Finally some PAINT!!!
Nice truck, great workmanship!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
06-10-2010, 12:08 AM | #52 |
What was I thinking?
Thanks guys for the compliments… but I've got some bad news. I finally got my truck aligned today, so I decided to go for a cruse. When I started to notice that my oil pressure was acting up. Under acceleration I lose oil pressure. I wasn't far from home(like less than a mile), so I headed back. Almost home it sounded like a bearing was squalling. I get home and at idle I've got like four pounds of pressure. Not for sure what the problem is. I'll try to get it out this weekend. I guess this is what I get for trusting someone… when they said "motor is fresh rebuild, just had it built" I bought the truck that it was in. It did run and drive great. That was like three plus years ago. I've driven this truck for like the last two weeks back and forth to work, never over 55. Then as soon as I get on the highway up around 70 to 75. Then the problem starts to happen. I have know idea.
Justin |
06-10-2010, 12:32 AM | #53 |
Still Learning
so sorry to hear about the engine. Man, that sucks big time! I know from experience when you lose oil pressure and it sounds like a bearing, well more than likely it is. Hope it all works out good. If not you will need to throw that 5.3 in there.
06-10-2010, 12:48 AM | #54 |
Man that sucks but it looks cool
06-10-2010, 07:10 AM | #55 |
One day...
Oh dude thats no good
06-10-2010, 06:20 PM | #56 |
I'm goin to pull the pan Saturday. I'm hoping that the pickup tube fell off, but I figured that if it did fall off I'd have zero pressure. What do you guys think?
My dad told me to check that. He said that he was working on one, where it would have pressure at idle(low RPM) then it would lose it. The pickup tube fell off of that one. Thanks, Justin I'm saving that 5.3 for my other 68, but if I can get a deal on a 6 liter I'll go that route. I've been told i can get that 5.3 resleeved to like a 4XX cubic inch, without over heating problems. Might look into that. |
06-10-2010, 06:29 PM | #57 |
One day...
Did it have a miss to it? Cam going down can make you lose pressure too but im sure you knew..
Was it knocking? I would put a wet line on it before i pull the pan and do that much work, just to see if something is wrong with the gauge.. If you do find a deal on a 6.0 ill take the 5.3 off your hands |
06-10-2010, 06:37 PM | #58 |
No miss and it wasn't knocking. The only noise it made was for like 5 sec. and it was like metal on metal squealing noise. It would only do that if you reved it up. So I shut it down. Not for sure I know what you mean about wet line... Whats that? I do have a mechanical gauge on it.
06-10-2010, 06:41 PM | #59 | |
One day...
Yeah could have spun a main.. thats no good but we'll hope for the best. |
06-10-2010, 06:57 PM | #60 |
That's what I thought you meant. We'll see what happens.
06-10-2010, 07:04 PM | #61 |
Still Learning
You could have spun a main, and yep it can squeal on you you too. Hope not but it sure doesn't sound good. Good luck with finding a "deal" on a 6.0.
06-10-2010, 07:46 PM | #62 |
man that looks AWESOME i'm digging the white walls!!
06-12-2010, 09:35 PM | #63 |
Well I've got some good news! Fixed the problem, hope I didn't do much damage. Pulled the pan today and the pickup tube fell off. I figured that if the tube would of fallen off I'd lost all the pressure...I was wronge, but glad it was an easy fix. Pulled the front main just to check the bearing. Been told if you starve a motor of oil, it's usally the first to go. Since it's the farthest away from the pump. It looked good. So torqed it down, welded the tube back to the pump...back in buisness!
And here's another pic for you. I'm doin this off a computer at work, since mine at home is trashed. |
06-12-2010, 09:39 PM | #64 |
Right on!!!
Glad it was a quick fix!!
CHEVY ONLY |
06-12-2010, 10:57 PM | #65 |
Still Learning
That was a quick fix! Glad to hear your engine isn't trashed
06-13-2010, 12:57 AM | #66 |
Still plays with trucks
Looks like the weld broke from the initial installation. Never seen a weld break on a pickup tube before.
Glad you caught it before it did any serious damage. Truck looks great. Keep up the good work.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
06-13-2010, 08:55 AM | #67 |
One day...
Cool man glad to hear it wasnt anything too bad
06-14-2010, 11:30 AM | #68 | |
06-15-2010, 08:32 PM | #69 |
Thanks everyone! Well see if the big block will hold together…
06-15-2010, 08:45 PM | #70 |
One day...
You get it back together yet?
06-16-2010, 01:06 AM | #71 |
Yeah! I did it all last Saturday. Just pulled the pump and welded it back on. Then looked at the front main. New pan gasket and topped it off with new oil. I've been driving it since. I know it's just been three days, but today I drove it about 40 miles to get a sending unit. So I could get my full gauge to work and I ran out of gas two blocks from my house. Damn big block drinks the fuel! I hope I don't get tired of feeling it up… but the motor sound good and solid. I think it'll last.
06-16-2010, 07:21 AM | #72 |
One day...
Well cool man glad to hear its back and running
06-16-2010, 08:54 AM | #73 |
Still Learning
Just another reason to stick that LS motor in there! Glad to hear you got it back on the road
06-18-2010, 07:00 PM | #74 | |
CHEVY ONLY |
06-18-2010, 07:09 PM | #75 |
Tot Roddin'
Quick fix and great pics!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
