#51 |
![]() Join Date: Apr 2008
Re: "valdez"
looks like a fun build, why did you brake before the finish line in that last clip?
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#52 |
Re: "valdez"
finally got the firewall painted, looks a little gloss in the picture but it should die back to a little more satin. tomorrow ill start re assembling the firewall to find out how new paint makes everything else look ugly and dirty haha
VALDEZ 1971 C10 LWB 350/350 http://67-72chevytrucks.com/vboard/s...d.php?t=400327 |
#53 |
Re: "valdez"
haha its bracket racing you gotta pick the time its gonna take you to run a 1/4 mile and run closer to that number than the other driver runs to their number with out going to fast
#54 | |
Re: "valdez"
Craig Last edited by cokeb; 07-31-2011 at 12:10 PM. |
#55 |
landarts
![]() Join Date: May 2005
Re: "valdez"
Kyle the firewall looks killer! keep moving forward and get some paint on the rest of the truck.
When can I come over and deal with you on the c-30 cab????? |
#56 |
Re: "valdez"
O.K. I understand now.
Firewall looks great.
#57 |
Re: "valdez"
thanks, sorry but for what ever reason even though i have no plans for it she's not forsale
#58 |
Re: "valdez"
been real busy messing with the rest of the engine bay just about to go spray black on the inside of passenger fender then its time start re assembling everything and move on to replacing the cab mount bushings.
#59 |
Re: "valdez"
got the cab mount bushings replaced. highschool races were last friday, got out to the track and put the slicks on and was about to go to tech inspection, when i turned the key i heard the motor turn over once and then nothing. i didnt have my test meter with me so i couldnt test the battery but all my lights "looked" bright so i figured it was good. a buddy of mine had a starter out of a 70 so i went to put that in and it was the aluminum one so my bolts were to short so i went down to ask a friend if he had longer starter bolts, he did not but he let me borrow a mini starter wich as soon as i was about to bolt it to yhe block my mom showed up with starter she picked up for me at napa. and turns out i told her to get the wrong ones and my starter bolts were to short so i called my dad when he got off of work and had him pick up longer starter bolts. when he showed up we got the starter in then i turned the key and... still nothing so we grabbed his test meter and checked the battery, 9 volts with everything off and like 6.7 volts when trying to start it. so we took the battery out of my dads car and off i went. got on to the track just before they closed the lanes to get ready for eliminations and i hit the 60 foot mark and the truck shorted out, i got in to much of a hurry and the positive cable going down to the starter i ended up wedging against the exhaust and shorted it all out. got it all fixed right before eliminations and redlit first round by -0.071. its just amazing how fast a battery can loose its cold cranking amps!
#60 |
Still plays with trucks
Re: "valdez"
Nice progress.
Hope not too much got messed up with the dead short of the battery cable. Next time I get to Boise to see my best friend I will look you guys up and see if we can hit the track.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#61 |
Re: "valdez"
nothing was really damaged by the short other than the battery cables themselves haha. but ya look us up next time your over here and i can show the worlds slowest 15 second pass
#62 |
Re: "valdez"
got the take out from behind the seat the a while ago so the other day i decided to start making a patch for the old filler neck. note to self dont get in a hurry fitting is key haha
#63 |
Re: "valdez"
I saw a link someone on the board had to a company that made contoured filler neck cover plates that fit really well. I will see if I can dig up the link and info. They were pretty inexpensive.
#64 |
Re: "valdez"
if you could it would be great! even though i could probably use the practice i gotta get it filled before the snow comes.
#65 |
Re: "valdez"
gettin ready to take the insurance off of the truck, finally broke down and bought something that gets some mileage, a 72 comet with a 200 six. i know yall hate me for buyin a ford lol but who knows maybe ill actually make some progress on the truck when im not driving it everyday
#66 |
HOW long until spring??
![]() Join Date: Mar 2009
Re: "valdez"
the buzzing half dozen!!!
That is why I left the inline 6 in the 64 truck that daughter is driving!! But for the best mileage you have to keep your foot off the floorboard!!! As per the blue oval...... I forgive you .. it is still classic iron and I am proud of you for not just getting a rice burner!!!!! BUT we need pictures!!!!!
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#67 |
Re: "valdez"
haha its a six with a single barrel to the floor and cruising are the same thing. and the 40mpg honda was very tempting
#68 |
Re: "valdez"
here is the only one i have at the moment
#69 |
Re: "valdez"
ok bruce maybe you can explain this gas mileage thing to me again because at the moment the comet is getting about the same as the truck haha
#70 |
Re: "valdez"
Well Kyle,
You must not be paying enough attention in school these days.... It is just a matter of applying simple physics.. While doing a burnout, you have NO forward motion while using a large amount of fuel in the process, So to increase the Miles Per Gallon ratio, try for more forward motion and less fuel consumption. ![]() ![]() This may be the same problem that is causing causing the poor fuel economy in the truck!!! ![]()
#71 |
Re: "valdez"
ok now you got me confused they call it mpg ( miles per gallon) so if im not moving how can that affect my miles per gallon?
#72 |
Re: "valdez"
Okay Kyle We will try this again-pay attention this time!
There must be too many girls in your classes as you seem distracted. Just physics and math ![]() First - the burnouts are measured in SMILES per gallon,so the mileage factor does not apply in the equation . ![]() Second -You are having fun ....doing burnouts are fun and the resulting bad MPG spoils the fun... so ignore the constant drop of the fuel gauge at this time. Third -The BEST mileage comes with a really sharp truck just sitting still collecting dust and no bugs , but we call that a Trailer Queen!! So Trailer Queen without Forward Motion equals LAME and the result is a negative. Maybe we need to introduce a additional factor in the equation to dilute the fuel and increase the capacity to the carburetor ![]() I would consider the bottled fun juice to be a positive So remember, the Fun to mileage ratio always improves with Dads credit card as the exponent. Good luck with that Bubba
#73 |
Re: "valdez"
there are two problems with the previous statement, N2O is always a negative to your pocket i am assuming this is where my dads credit card comes in, but you have forgotten there is a bonding agent between my carb and his credit card, this is called love. something of which my father seems lack for my projects and me when i bring another project home.
#74 |
Re: "valdez"
Bubba, I can't take it anymore.... No more projects! Why does his projects have to be mine? Looks like the only solution is to send him your way, you have lots of experience with the old six I have none....problem solved.
thanks for the help, Craig |
#75 |
Re: "valdez"
by the sounds of it he gets more done to... just sayin haha
Tags |
71 chevy lwb 350 |
