06-19-2010, 08:18 PM | #51 |
VA72C10
Re: Project Tweaked - 2wd Blazer build
VERY NICE!!!!!! Looking GOOOOOOD!
Looking for a 67-72 swb or blazer project in or around VA. |
06-19-2010, 08:43 PM | #52 |
looks awesome buddy!!!! really coming along
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
06-19-2010, 10:37 PM | #54 |
Looking good.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
06-19-2010, 10:41 PM | #55 |
GM Addicted
Looking good, should pull that balancer off again and tape it off and paint the timing mark white first then red. Did it on mine can see the mark perfect every time, just a thought.
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
06-21-2010, 01:40 PM | #57 |
Thanks guys! I'm excited about getting it back together!
Style question. Being that I'm going back with all of the factory trim and chrome, should I spring for the windshield seal with the chrome center or just go with the solid black seal? Opinions???? Input? Thanks, Mike |
06-21-2010, 01:59 PM | #58 |
67-72 parts collector,…
Solid black.
The chrome will start to look like crap in a couple years.
06-21-2010, 05:40 PM | #59 |
I think the solid black trim looks the best. Simple and clean.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
06-21-2010, 10:48 PM | #60 |
Black it is.
I pulled all of the front suspension out from under the truck this evening. I'll get the new bushings and ball joints in it tomorrow and hopefully back together tomorrow night with the new spindles and springs. |
06-21-2010, 11:18 PM | #61 |
Wow that Blazer is sweeet. Great Job bud. Cant wait to see the pics with the wheels on u dog. lol
Its Kool to be a square 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers New Mexico Member --- Member of the Square Body Club--- |
06-22-2010, 10:30 PM | #62 |
thats lookin real good
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
06-29-2010, 07:58 PM | #63 |
More progress. Front and rear suspension done, and new shoes mounted. Heading back out now to set motor and trans in.
Hope to have it running in a couple of days. |
06-29-2010, 08:08 PM | #64 |
beautiful!
06-29-2010, 09:56 PM | #65 |
Happy to be here
It looked good with the new paint, but the wheels set it off. Nice build up.
06-30-2010, 10:13 AM | #67 |
how did you get the boss wheels to work with your front calipers?
WillieloRidez Drive em in Drag em out! Projects: 1956 Chevrolet 210 2dr post 58 chevrolet 2dr delray 58 chevrolet belair 4dr hardtop 1965 Chevelle big block 4spd 88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=388445 |
06-30-2010, 10:55 AM | #68 |
Thanks for the compliments. I did get back out there last night. The engine and transmission are now bolted in the truck.
Mounting the Boss 338's was fairly easy. I used DJM lowering spindles for the light duty brake system (1 inch rotors). I bought new rotors (hubs) and calipers for the light duty brakes. I mocked up the new hubs to the wheels with the dust caps installed. The only issue was that it was pushing the center cap out of the wheel about 1/8-3/16 of an inch. After considering grinding on the hubs I started looking at the center caps. The fingers that hold the center caps in are about 3/16-1/4 inch longer than they have to be to still function as they should. 2 minutes with a flapper wheel on an angle grinder was all it took to make the center caps work perfectly. No other issues. Mike Last edited by Mr.Chevy4x4; 06-30-2010 at 10:55 AM. |
06-30-2010, 12:16 PM | #69 |
Thanks for the info Mike the blazer is lookin sweet
07-11-2010, 09:35 AM | #70 |
Got her running yesterday. Update this afternoon with pics and hopefully video.
07-11-2010, 04:03 PM | #71 |
Ok, here's the video of the initial start up. I filled the front fuel bowl with a syringe and gave it a couple of primer squirts before starting the video. I must have gotten pretty lucky dropping the distributor. After stopping the video I found a small fuel leak at the carburetor. Other than that everything looks good to go! After correcting the fuel leak I started it back up, set the timing, checked and topped off the fluid in the new 700r4, and let her get up to operating temperature. Not too far off from a "spin" around the block!
07-11-2010, 04:32 PM | #72 |
sounds good man. is thate a crate motor
07-11-2010, 04:36 PM | #73 |
No, I built it. The short block started life as a marine ram jet engine. It is a factory roller block so I went with the GM LT4 hot cam to give it a little thump. I can't wait to see how it drives. Sounds strong and has very good throttle response.
07-11-2010, 06:44 PM | #74 |
VA72C10
sounds good! Nice tough sounding idle...
07-11-2010, 07:45 PM | #75 |
Thanks!
Here are some pictures from today. The front end still needs to come down a little. I'm hoping the hood, windshield, and bumper will be enough weight to bring it down a little. If not enough then I will cut the new springs before I get an alignment. Oh, and yes it will turn a tire over.....just in case you were wondering! Last edited by Mr.Chevy4x4; 07-11-2010 at 07:48 PM. |
