Old 06-06-2010, 04:43 PM   #51
'72customdeluxe
Re: Ram air hood ..thoughts/ideas ????
Originally Posted by Andy4639 View Post
Thanks,
It took some time doing it but after it was done I think it was worth the trouble. Here is a shot of the grille off showing the opening for the cold air. Right beside the drivers head light.
that's where I plan to make the hole for the ramairbox.com setup. OP, check this link out and see how they set it up http://www.fordmuscle.com/archives/1999/12/ramairbox/ you can still make your own box and plastic/dryer hose to save money. Your mock up just seems more complicated than this
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 06-06-2010, 05:21 PM   #52
Andy4639
Old member
Andy4639's Avatar
Talking Re: Ram air hood ..thoughts/ideas ????
My setup has been in the truck now for over 10 years. I did this before I ever saw anybody else doing it. As the TPI motor it has been in the truck since 1989 only a handful of people even knew about transplanting these motors back then. I was one of the first on this site to do it.
My cold air only cost me $25.00 total which is another reason I did it my way.
plastic/dryer hose to save money!!!
The hose I used is for just this type of setup. This is auto hose you buy at O-riley's not dryer hose.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-06-2010, 05:24 PM   #53
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Originally Posted by Hottrucks View Post
ok NO LAUGHING!!
I did have to chuckle a little bit. I like your ingenuity.
Here's a few shots of my ram air system. It definitely makes a difference. When I shift from 3rd to 4th gear at 90 MPH there's a definite kick that isn't there when I don't have it hooked up.
The breather is from a '76 Vette ebay purchase. The tubes are 80's breather tubes used on Chevy/GMC trucks. The black plastic is ABS 3" and 4" Pipe from the hardware store.
Both inlets sit directly behind the upper grill on right and lower grill on left and don't alter the factory appearance.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 06-06-2010, 06:52 PM   #54
Andy4639
Old member
Andy4639's Avatar
Old Yeller 1970,
I guess you have to run 90 MPH to keep it cooled off without no radiator in there!!! Sorry could resist.
Nice setup you have. I like it!
Old 06-06-2010, 08:15 PM   #55
Old Yeller 1970
DON'T TREAD ON ME
Yeah, I have the worlds only air cooled 350. Thanks for the compliment.
I appreciate the effort you put into your TPI Cold Air intake setup. It looks sharp.
Old Yeller
