#51 |
![]() Join Date: Aug 2009
Re: Porterbuilt Stage II "Mild Drop Kit" for 63-72C10
Nate, will this kit work on my 71 c20 ? from what I understand the rear arms are different in size I want to drop/bag it with the 8 lug set up starting with the back end. Also Do you have anything for a c20 front end? Thanks,Tom
Posted via Mobile Device |
#52 | |
Doug Looking for a 67-72 short bed driver..... Last edited by m6z; 09-13-2010 at 09:22 PM. |
#53 |
Nope. the economy version does not include the upper bag cup (nor does it need them). The Stage2 comes standard with our 1" drop arms... NOT the 3" drop arms pictured. The upper cup is not used with the 1" drop arms either.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#54 |
damn, that is sexy! idk if i'll be buying the kit but those notch plates have my name all over them!! great work again, please keep it up!
#55 |
Nate, I luv the looks of all the craftmanship on your previous stuff, but just dont want to do the bag thing just my opinion. BUT, like 68GMCCustom i am all in for the coilover front version when it is available "money in hand and waiting". That being said can the stage 2 mild drop for the rear be used or made to work for rear coilovers? This is so cool nate you are developing the type of suspension system ive been waiting on for a while now, coilovers all the way around, thanks.
skeeterbug
'71 LWB c10-"WORK" in progress ![]() 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
#56 |
deleted.
1967 Chevy Short/Fleet 1969 Chevy Short/Step 2004.5 Dodge 2500 4x4 Cummins 6spd Last edited by John @ BROTHERS; 09-21-2010 at 12:19 AM. Reason: Not stepping on anyone's toes |
#57 |
Happy to be here
![]() Join Date: Mar 2000
Rob is a good guy that has been active on here lately. We haven't been able to convince him to be a Forum Vendor "yet", but still good people...
![]() I have heard that Nate has a lot of coil over kits in the works. See if he has one ready to fit your needs
#58 |
Alright this is probably a stupid question but I'm gonna ask anyway.
Are your tubular trailing arms any stronger (stiffer) than the stock ones? I'm runnin a BBC 502 that has lots of torque and wouldn't mind having some stronger arms instead of the original ones.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 Last edited by Painter D; 09-17-2010 at 08:10 PM. |
#59 | |
#60 |
New Member
![]() Join Date: May 2007
Nate,
Were you able to get any pictures of a fleetside bed with this setup? I see the picture on the first page of the stepside. Just curious what ride height and drop height looks like on the non-drop member trucks. Keep up the good work. It all looks great!
My Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=366351 |
#61 |
Nate,
Would the stage II front and rear kit hold up to the abuse of 600 hp? I love this stance and definitely want to go PB but need something that can take the abuse. I guess my question is whether the trailing arms would be a weak point or not? I would love a "mild" Dropmember for this setup, thanks
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
#62 |
No Dropmember here..... Porterbuilts front a-arms (upper & lower) on a factory 72 x-member & the 'mild' rear TA kit.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-24-2010 at 11:31 PM. |
#63 |
Tot Roddin'
Not that SCOTI hasn't seen this truck first hand, but I can also verify this truck was not running a DM. The "perfect" setup IMO... Mild Rear matched with U/L tublar a-arms.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#64 | |
Hi Nate, Great products, I have a similar question for you that was asked buy nds1968, Q. if using your upper shock crossmember, will the stock trailing arms lower shock location suit the new upper shock mount positions (63C10) I am intending to use bags, Thanks darron UK, |
#65 | |
I would like this product, but i live in the UK an will be towing a caravan (15 feet long) 1500 kg and a nose wieght of 80kg. Thanks darron |
