The oddest Todd around
At my wit's end
Ok,
1972, c10, lwb, 355, front disc brakes. I've replaced: Master Cylinder Front Brake Hoses (both sides) Calipers (both sides) Rotors (both sides) Pads (both sides) and inner and outer bearings (both sides) Flushed the brake fluid My front right wheel is dragging. If I lift the truck up, and spin the wheel, it stops spinning again immediately. Not after spinning a couple of revolutions, but after a couple of inches. WTF could it be? I've replaced everything, except the proportioning valve, but I don't think the proportioning valve would cause only the front right tire to drag. The front left tire is fine, but the front right is dragging.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
Between Trucks...
Re: At my wit's end
How did you adjust the wheel bearings? If you pull the caliper does it spin freely?
Beat it to fit, Paint it to match... ![]() |
![]() Join Date: Oct 2001
Re: At my wit's end
Make sure you didnt over tighten the castle nut on the spindle 1st.
2nd just because you replaced the parts doesnt mean the new parts are good I've worked for a Auto Parts store for the last 9 yrs and I see new or reman parts sold from time to time and they be defective. You could go back and blead your brakes again if thats the problem area! Good luck.........
Things happen for a reason! |
Old member
Check the castle nut on your spindales make sure it's not over tightened.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: At my wit's end
If you have determined that the dragging is not in the hub, get another caliper. I just went through the same issue. It turned out to be a defective caliper.
Re: At my wit's end
have you adjusted the pushrod for the proper pedal freeplay
Re: At my wit's end
I am going to check the caliper bolts. What ft/lbs should they be?
When the caliper is off, the rotor spins freely.
Re: At my wit's end
Replace the caliper again. The piston is not retracting, the pins will not cause this to happen.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Re: At my wit's end
Well ****... *sigh*
OK, I'll replace the caliper... again... and check back in after that.
Re: At my wit's end
Well ****... *sigh*
Grandpa in the rustmobile...
Re: At my wit's end
have you converted to power brakes lately? i had an extra gromit between booster/mc
and my brakes still hang a lil i think its the adj. rod
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Your UncleBen
![]() Join Date: Dec 2002
Re: At my wit's end
Definitely sounds like a dragging caliper to me! Would check that out.
68 C10 shortbed -- Street/Strip ![]() |
#13 |
Re: At my wit's end
yeah, but WHAT would cause the caliper to drag (unless plain faulty)...
#14 |
Re: At my wit's end
Ensure you didn't kink the brake hose by spinning the caliper 360 degrees before remounting. I did that when I was learning to work on cars years back and it made that caliper stick.
Just another thought..... Good luck
1969 GMC Wideside SWB 400ci/TH400/373/Disc Brakes/Leaf Springs 1992 Chevy C3500 Ext Cab Dually Silverado 454 TBI 2007 Chevy Corvette ZO6 427ci 505HP |
#15 | |
Your UncleBen
Re: At my wit's end
These are all good ideas on causes... The bleeders on the calipers should be pointing up. Are they? It is possible to have the calipers on the wrong sides of the truck....Just something to check. Other than that...bent or seized up slides but most common is just a junk caliper. See if it will compress in... lata CHRIS
#16 |
Re: At my wit's end
What if the pins were bent? This could cause the caliper to be cocked relative to the rotor, and it would definitely bind then.
Ray |
#17 |
Re: At my wit's end
Ok... tomorrow I pick up another caliper to replace the one that is "bad".
A few things though that were brought up: -They are power brakes, factory installed -Yes, the piston will compress (with a c-clamp), but as soon as I press the brakes, they drag again. -The bleed screws are on the top -The brake hoses are new, and so are not twisted -I actually have too much freeplay in the brake pedal, besides, that wouldn't cause just one wheel to drag After I replace this caliper, again, it will be #3 on that side. I just find it kind of odd that the old caliper, and the new caliper, were both dragging. I mean seriously, what are the odds? Luckily it is covered by warranty, so it will only cost me some time to switch it out, and not money.
#18 |
Your UncleBen
Re: At my wit's end
Man that is weird.... What about the non rubber part of the line... Is there a kink or something going on there? Maybe something inside the line itself?? All odd things but this situation is an odd one!
lata CHRIS
#19 |
Re: At my wit's end
yeah ive seen a rubber line have a bad spot on the inside causing a check valve effect doing the same thing u described.
1972 super cheyenne 1970 Suburb |
#20 |
Re: At my wit's end
Yeah... but 2 rubber lines in a row? Highly unlikely.
#21 |
Your UncleBen
Re: At my wit's end
True.... But there are only just so many parts in a brake system. I am still thinking a caliper.
#22 |
Junior Member
Re: At my wit's end
if you didnt change the rotor on that side(possibly the bearing race wasnt seated all the way and holding the rotor out of center in the caliper)..and all you did is go from the old caliper to the new,id say once the old new caliper is off,disconnect the hard line from the Y block where it goes to the other front side,spray some brake cleaner in there and blow the hard line out with compressed air. could have some rot/flaking in the hard line thats acting like a one way valve, letting in pressure but not releasing it. if worse comes to worse, rig up a whole new hard line to test the theory.
67-72 Truckless for the moment ![]() Member# 1126 The one that got away http://customclassictrucks.com/featu...001/index.html |
#23 |
GM Addicted
Re: At my wit's end
I have the same problem on my 79 and i also have all new parts, i decided to change the proportioning valve and still no luck im stumped just like you man good luck its a headache.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#24 |
Re: At my wit's end
Try swapping all the parts side to side & see if the problem remains on that side or follows the parts.
#25 |
Re: At my wit's end
good idea scot
