#51 |
Re: All '64 roll call!!!!
Here are my two 64's enriching my neighborhood.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#52 |
![]() Join Date: Nov 2010
I wish you lived in my neighborhood!!
LIFE IS SHORT HAVE FUN |
#53 |
My contribution to recycling. Has a GMC grille in it but it's a Chevy. 283, pg. Sorry about the nosebleed stance, though that will be remedied before spring.
#54 |
Here's mine. It's running a weak-a@# '79 4-bolt 350 in dire need of better heads. Transmission is now a 700R4 instead of the original 4 speed. The lowering is via CPP springs and spindles, 4 1/2" in the front, 4" in the back. 4 wheel discs, 3.73 w/ Auburn LSD, and (finally, thanks to Capt Fab) brand new power steering. I'd originally stuck the 350 in it just to get it on the road since the 283/4 speed was so tired, but two transfers, a wife and two kids later and it's still in there. At least it runs good.
#55 |
Post Whore
![]() Join Date: Mar 2013
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#56 |
![]() Join Date: Mar 2005
Here's my '64:
![]() That picture was taken about 9 months ago, when it was in it's final mock-up stage. Since this picture, the truck has been Z'd, but it won't be much lower in the front. The chassis mod was done primarily for ground clearance. The engine and trans are now installed, the exhaust is installed, and I'm in the process of painting the inner fenders and core support and everything is going back in for the final time very soon. The engine in a 1990 350 factory roller short block with Vortec heads. I reworked the bowl areas, left the ports alone, and cut down the valve guides for added lift. Installed good springs and roller rockers. The cam is a GM Performance roller (part# 846: .509/.528 lift, 222/230 duration @ .050, 112 lobe center. Advanced 4 degrees). The intake is an Air Gap, the carb is a Holley 750 vacuum secondary. The ignition is an HEI with MSD guts inside. The horsepower should be around 380. Some magazines have built similar combinations and have claimed 425, but I'm going to set my estimate on the conservative side. The trans is a 700r4, with a 2200 stall converter, and the lock-up feature is activated. The rear end is a 12-bolt from a '79 suburban, narrowed 3 inches, with Strange axles. The front suspension is from a '79 Suburban. BellTech drop spindles, 1 coil cut from the stock 1/2 ton front spring, and the chassis was Z'd up 2" and forward 1". The lower control arm shafts were re-spotfaced 3/4" forward to gain caster. The rear suspension has a Super Track Bar kit, the upper shock mounts were relocated, and the forward trailing arm brackets were flipped. The rear coils are 5" drop. I plan to lower the rear about another 2", so I plan to raise the bed floor slightly for clearance. The wheels are late '60s ET Supers. The fronts are 15x6, and the rears are 15x8.5 with a 3" backspace. The lips were polished, and the spokes were painted a light charcoal. Factory ET oval caps. Since this picture was taken, the rust in the fenders has been repaired and the holes in the bedsides for the gas doors have been filled. Once all of the small repairs have been done, the areas will be blended in and "aged" to match the rest of the paint. The entire truck will be sprayed in an industrial Imron (satin) to seal the paint. This truck earned it's patina, and I have no intention of repainting this truck.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 Last edited by chevyrestoguy; 11-17-2013 at 10:39 AM. |
#57 |
Here some of mine the first is with the skirts and side pipes. I habe sinced remove both, as shown in the last pic
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
#58 |
My 64 prior to being lowered a little more.
#59 |
Should be about that low once done.
Danny 64 C10 SWB fleet |
#60 |
My 64
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
#61 |
Nice trucks guys! I love my 64.
Live and let live ![]() |
#62 |
#63 |
My 64 GMC. before i tore it back down to rebuild motor and cab work.
1964 ![]() |
#64 |
Currently...
![]() Coming this spring! ![]() ![]()
64 LWB to SWB Step build. Daily driven! ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=647168 |
#65 |
Here is my 64. Just put on ps & pb.
1948 Chevy 1/2T 1964 Chevy 1/2T stepside short bed 1939 Pontiac coupe Street Rod 2005 GMC 1/2T short bed |
#66 |
my 64 in England
#67 |
my stock 64, 3 on the tree and straight 6
#68 |
My 64
Bagged, Sectioned Crossmember, Tube Control Arms, Step Notch, And More! Trucky is currently torn down to the frame, Frame is now Z,d. Awaiting sandblasting and powdercoating. I hope to get it back together for next summer.
#69 |
Attachment 1468743
My 64 the day I bought her. About a year and a half from the start of my build. Currently working on a 62 and 65 build. |
#70 |
'64 Factory 4wd long bed. Currently in the process of a stock restoration.
#71 |
I am in.
#72 |
![]() ![]() Join Date: Jul 2002
Here is mine
#73 |
Looking good paf70!!!! Luv the stance, 4 / 6 drop?
#74 |
Heres my 64. Long bed on bags. 350/700r4 trans.
#75 |
Moderator
![]() ![]() Join Date: Aug 2011
Ah-Ha there is a bar in the middle of your grille that no one seems to know where to get. I knew it went there.
