#51 |
![]() Join Date: Jan 2011
Re: stepside
X2 ! That truck is incredible.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#52 |
Re: stepside
68 Stepbed- would you mind sharing your wheel / tire sizes? Drop and back spacing? Thanks.
#53 |
Re: stepside
Thanks, guys! I'm glad I can bring some inspiration to your builds.
Wheel/tire specs: 17x8(4"bs)-255/50/17-steer, 17x9.5(5.5"bs)-275/55/17-rear with 1/4 spacer. I recommend 5" bs on a 9.5 or wider rear wheel. Drop specs: 3.5/5 drop- 2.5" spindles and 1" drop springs-front, 5" drop springs-rear. I also have rear shock relocators and a Super Track Bar from ECE and KYB shocks.
#54 |
Re: stepside
I'm also running ECE but with a 4/6 drop. My wheels are 17x8 all around with 4 inch bs. Front tires 255/55/17, rear 275/55/17
After all of that, I measured the width in the front and in the back and found the front to be 3 inches overall wider than the rear... I think the spindles pushed out the front. Was this a problem for you and the reason you spaced out the rear? |
#55 |
Re: stepside
The spindles do widen the front track width. That's why GM widened the rearend in the 71-72 models. I have a 72 rearend under mine so that's not the issue. The 5.5" backspacing is just too deep. It clears fine as long as I'm driving in a straight line, but when I make turns or when the chassis flexes, they rub on the inside of the bedsides. If I were still using a narrower 67-70 rear, it would be worse. It still rubs just a little bit with the spacers, but only when turning into somewhere with a grade and the chassis flexes more.
#56 |
Re: stepside
me and my dad both have step sides
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
#57 |
Re: stepside
#58 |
![]() Join Date: Apr 2011
Re: stepside
I have a 67 stepside 4x4, I'll post pics if I figure out how to do that.
#59 |
Re: stepside
#60 |
Re: stepside
mine had the spare cut out.A friend of mine had a nice non-cut fender w/ chrome steps.It was even a really good color match.I dont miss the spare cut out much sry
![]() ![]() ![]() I originally had plans to sell the step bed a put on a fleet.My Dad drove a 53 five window short step(I have it now) and the step bed has grown on me,I love it.Yall be good |
#61 | |
Re: stepside
#62 |
Re: stepside
http://67-72chevytrucks.com/vboard/a...1&d=1303701009 http://67-72chevytrucks.com/vboard/a...1&d=1303701009 Here's mine. Needs a little cancer repair, plan to restore as I drive.
#63 |
Re: stepside
I'm really not sure exactly on that. I've never measured track width, but I beleive it may be. An interesting facto about steppers, though. The stepside fenders aren't as wide as the fleets, so the narrower rear track width isn't as noticeable on a stepper as it is on a fleetside. A good way to see this is to look at different trucks with the same size wheels/tires on all four corners. The feetside look like the wheel is sunk under the bed more than the front, but the steppers look even.
#64 |
Re: stepside
Step side and four eyes even less popular. Just the way I like it.
#65 |
Re: stepside
x2
68 ![]() My other ride ,,, 07 Streetglide.. |
