#51 |
Re: Lift Pics
Its good....really stiff at first...but worth the money...don't get blocks for the rear get new springs...double check the shocks they give you I think they gave me the wrong ones...but over all good buy
Posted via Mobile Device |
#52 |
Re: Lift Pics
first pic is 7 inch with 35s then i went to 37s and the last is the 40's that i just picked up just havent found the right rim i want to run hope this helps
#53 |
Re: Lift Pics
#54 |
Re: Lift Pics
tried to post sdaileys truck in the above post.
#55 | |
The Few, The Proud
![]() Join Date: Jun 2007
Re: Lift Pics
Yes, it has a 2" lift and yes those are 10" rally's that were widened.
Shannon |
#56 |
#57 |
Re: Lift Pics
I have a 4" Rough Country all spring lift and it rides like a tank. The rear bounces a lot with the 52" spring. I would recomend getting the longer 56" leafs for the back and moving the rear spring hanger towards the rear 4". A lot of guys do that for a smoother ride. Less arch in the spring means a smoother ride.
http://67-72chevytrucks.com/vboard/s...d.php?t=355153 |
#58 | |
Re: Lift Pics
did the 33x12.50's ever rub with the 2"? would it be worth looking into the 2.5" kits or the 3" or did you feel the 2" was enough? did you have to do anything besides change the spring packs? like extended brake lines? steering arm drop? was longer shocks a must? thanks! |
#59 |
Re: Lift Pics
I'd try taking out those front shims, there probably pulling out your caster and thats whats making the truck wander.
#60 |
![]() Join Date: Aug 2011
Re: Lift Pics
83' has 3" lift with 33X12.50X16.5
![]() 79' has 6" lift with 35X12.50X15 ![]()
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
#61 |
Re: Lift Pics
6 inch lift with 35x12.50's
[IMG] ![]()
1977 K10 shortbox Scottsdale 4x4 1988 C30 Crewcab Silverado 1987 K10 longbox Silverado 4x4 1969 GMC 1500 4x2 |
#62 |
Re: Lift Pics
my brothers, 10 inch (i think) suspension 2 body, 40s.
#63 |
Re: Lift Pics
7``total lift 4 susp ,3 body
1990 k5 blazer 1990 gmc jimmy 1949 1300 p/u-sold 1977 bbc skylark 96 roadmaster 06 9c1 impala |
#64 |
Re: Lift Pics
here is my 87 with a 1" add a leaf running 33s
#65 |
Re: Lift Pics
Only ones I have left lost them on my other phone
12"suspension and 3" body 44" super swampers TSL |
#66 |
Re: Lift Pics
