#51 | |
![]() Join Date: Nov 2006
Re: Blazer interior rear panels
If you take Paypal, I would be interested in a set of patterns, just would need to know the shipping cost to zip code 93637. |
#52 |
![]() Join Date: Sep 2011
I too am really interested in the paper patterns for the panels. How much to ship them to 92315?
Do you also have a drawing or anything for the standoff brackets? Thanks in advance! Chris |
#53 |
You still offering panel patterns?
#54 |
![]() Join Date: Nov 2013
This is what I did for my '70 CST
3/16" textured ABS plastic sheet....less than $100 for a 4' x 8' sheet anodized aluminum "J" trim vinyl push-on trim for the edges I found a pattern with the dimensions on line these fit so snugly...I only put in 4 trim screws to hold them The only issue is black only....which was fine for me when I switched from blue to black interior stopped it at the B pillar and added the vinyl trim you can see one small black screw here
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#55 |
[QUOTE=A1971Blazer;8581705]This is what I did for my '70 CST
3/16" textured ABS plastic sheet....less than $100 for a 4' x 8' sheet anodized aluminum "J" trim vinyl push-on trim for the edges I found a pattern with the dimensions on line these fit so snugly... Do you happen to remember where you found the pattern? Thanks |
#56 |
That looks better than the stock ones !
#57 |
PM me and I'll send you a PDF file
I can also get you the info for the trim
#58 |
Also Azek PVC board comes in 4' x 8' sheets. Smooth finish, 3/8" is what I used,..About $80. scuffed and primed with epoxy paint, urethane base coat over. No top trim, pvc piece glued 90 degrees on top, cut to fit the profile. 4 screws hold it in place.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
#59 |
Guest
Posts: n/a
I see a guy on Ebay is selling what looks like a repro rear side panel; have you looked into that option?
#60 |
![]() Join Date: May 2005
A1971Blazer- Where did you source your plastic and j channel....... Looks good, might be a market for these
#61 | |
The J channel and vinyl push-on trim came from McMaster-Carr supply Co aluminum J channel https://www.mcmaster.com/8427a64 trim material https://www.mcmaster.com/8451a47
#62 |
Following
#63 |
They look awesome
#64 |
Good stuff
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
