#51 |
Re: '67 5.3L Build Thread
nice truck so far, I'm almost done with my restoration and 5.3 swap. heres what i did for my trans cooler. i haven't ran it yet to see if it works good or not but i always have the option of using the factory cooler in the rad and the frame rail cooler together.
![]() Last edited by mrhino; 11-22-2010 at 04:22 PM. |
#52 |
![]() Join Date: Aug 2010
Looks clean, but do you think it will get enough air flow on the inside of the frame channel like that?
#53 |
I dont really know for sure, But I think so. I plan on using a good synthetic trans fluid like Amsoil, it transfers heat better than others, but like i said, if I see it getting to hot, I can add a line straight up the frame rail to the rad cooler and that should take care of it.
#54 | |
#55 |
i think i used stock lines from a 73. you have to replace the fitting in the back of the 5.3 p/s pump to make those work
#56 |
Interesting, I didn't think of using a later model year. I am have one made that goes from the inverted flare to a -6 JIC/AN. Then I will attach it to a metric O-ring to AN adapter. I'll be more specific with part#'s once it all gets here and I know if it worked out.
#57 |
![]() Join Date: Apr 2005
Nice build, errhhh I meant update,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-21-2010 at 07:06 AM. |
#58 |
This is what I am doing for the fuel pressure gauge. Since I am running -6 AN for the fuel lines I put on a Russel P#670340 to screw a Summit 100psi gauge in to.
#59 |
I also thought that I would mention that my hose shop couldn't get me the metric O-ring fitting for the power steering pump, but I found that Russel P#648060 is an adaptor that will make this into a -6 AN male fitting, which he could make a hose for.
#60 |
This is what I stumbled across for the valve cover breather line. You just drill a hole in your intake tube, insert the grommet and press in the elbow. Then I can just hook up the 3/8" breather line to it.
#61 |
When I posted pics of my ac compressor it was brought to my attention that I am going to have ac line clearance issues, so I notched the flared portion of the frame as seen here.
#62 |
This is what I have done for my oil pressure gauge. I drilled and tapped the oil cooler take-off cover for 1/8-28 NPT and screwed the sender right in.
#63 |
This is where I was told to put my water temp sender, but it is metric. Everyone said that it was 12mm, but nobody ever said the thread pitch (that I could find anyway), so I bought M12x1, but it was a bad guess. What you need is a M12x1.5 to 1/8"NPT adapter. This is Auto Meter part# ATM-2277. Hopefully all of these specifics will help someone else to not make the same mistakes I have.
#64 |
Big Red - Now its a SWB!
Great thread! I will be watching for sure!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#65 | |
![]() Join Date: Dec 2009
I am doing the edelbrock carb/MSD controller conversion. Q1: on the power steering, did you have the adapter/converter at the old steering box end, or at the new pump end of the hose? Q2: What kind of motor mount adapter did you use? The one I got does not allow my AC pump to be on. Q3: where is the water temp sensor? Is that the bolt right behind the header tube on the head? Im sure I will have other questions. Thanks again.
68 c10 350/th350 winter daily driver 90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver "Just so we are reminded of those who are held back, Up front there ought to be a Man in Black". Johnny Cash. Last edited by 6D8_C10; 09-23-2010 at 07:59 PM. |
#66 |
Yes, the temp sensor goes right where that bolt sticking out is. I ended up buying a new 12mm sender from classic instruments, after spending days looking for a 12mm to 1/8 pipe adapter ( to the best of my knowledge there inst one)and/or a any OEM sender that would work. as far as the oil pressure sender I just hogged out a Stock one and tapped the inside to 1/8 pipe works great. Last edited by mrhino; 09-23-2010 at 08:32 PM. |
#67 |
I have been doing the same swap into an 85 c10. Just wondering what your plans are for the engine harness?
#68 |
Truck and auto performance nut
I'd run it thru a catch can 1st. These LSx motors have a history of sucking oil residue right past the pcv and into the intake tract.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#69 | |
#70 |
I'm going with Speartech. I'll post pics when I get it from him. He says 2-3 weeks. Hopefully he's right. I am anxious to get this thing rolling. The only thing that's stopping me is waiting for the harness (Speartech), the fuel tank (Boyd), and the electric fans (123 auto).
#71 | |
A2: I used the ECE mounting system. Look back at page 1 and you can see pics. The trans ECE X-member just bolted right into place too, with no drilling. A3: Yup, on the passenger side. |
#72 |
I read thru a lot of debate on this and decided that if it's good enough for factory, then it's good enough for me. Thanks for your input though. If anyone has any other suggestions on how to make this swap better/easier I'm all ears (or eyes in this case).
#73 | |
#74 |
Awesome build..
#75 |
This was a major find for me. I couldn't figure out how to hook up the power brake booster hose from the 5.3 to the '67 booster, since the hose on the 5.3 is 1/2" and the '67 check valve port is 3/8". This is GM part# 15823207 and it fits right into the '67 booster. It even comes with a new grommet. SWEET!!!
