Old 11-12-2010, 01:27 PM   #51
69CST-V
69CST-V's Avatar
Re: PROJECT LOW DOUGH -1967 shortbed
We can always work something out. If need be bring it over and we can make that frame correct if it is truely off. That's not that big of a deal.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 11-12-2010, 01:27 PM   #52
lolife99
67-72 parts collector,…
lolife99's Avatar
You're talking about this kit?
The PB stuff works,... as long as the rearend is placed in the correct spot on the frame, otherwise the notch won't line up with the axle tubes.
Keith
Convert to disc brakes.
Old 11-12-2010, 01:32 PM   #53
lolife99
lolife99's Avatar
Originally Posted by bguild View Post
No the trailing arm crossmember is bolted in.. The cut was made just after it so it would have had to move to compensate for the cut. From what I have read this is the right place to cut it.. Now they didnt do a angle cut or reinforce it. It is just a straight cut and weld but I will weld it up better in the near future.
Some people cut in front of the trailing arm crossmember (12") and move the rear cab mount back.
(and then cut off 8" from the frame rails back by the rear bumper)
Here's a good tech article from ECE's website:
http://www.earlyclassic.com/tech.asp...20No!-Shortbed
Keith
Old 11-12-2010, 01:34 PM   #54
bguild
bguild's Avatar
Yes sir that is the kit.. I would like to get his trailing arm crossmember to go along with it.. I figure i can measure alot and fix the issue if there is one with this set up.. I just need a grand or so. I will have to put the wife on the corner this weekend. (-;
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 11-12-2010, 01:35 PM   #55
69CST-V
69CST-V's Avatar
If I remember right Nates measurements are taken from the front bed mount rear rivet. Then the centerline of the axle is 29.5" back. Don't quote me from memory but I will verify tonight.
Bryce
Company Trucks
Old 11-12-2010, 01:42 PM   #56
bguild
bguild's Avatar
haha if mine comes back like 40 inches I will be worried. LOL I will measure as soon as i can get back to my truck.
My front bed mount still has one rivet (the rear one).. Then the front rivet closest to the cab is removed and welded.. That is were they cut it. basically right inline with the front rivet.. But if that is how Nate gave you the measurements then it should tell me if the trailing arm crossmember is right.. I assume if its off its not off by much.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 11-12-2010, 01:44 PM   #57
69CST-V
69CST-V's Avatar
Its one of the rivets. I know the measurement is 29.5". So its either the front mount rear rivet or the second mount front rivet. I will verify for sure.
Bryce
Company Trucks
Old 11-12-2010, 01:47 PM   #58
69CST-V
69CST-V's Avatar
What's your email. I just found Nates email to me. PM it to me.
Bryce
Company Trucks
Old 12-03-2010, 03:53 PM   #59
bguild
bguild's Avatar
Well the welder is officially mine.. I havent welded with it yet but my buddy and I traded last night so I am pretty excited about it.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 12-03-2010, 07:17 PM   #60
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That welder is amazing Brian...
Now we should be seeing some progress.
And I see that you're considering going all out with the mild PB rear, excellent choice IMO.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-03-2010, 07:35 PM   #61
kyull67
kyull67's Avatar
Score!!
kyull67 is offline   Reply With Quote
Old 12-03-2010, 08:42 PM   #62
69CST-V
69CST-V's Avatar
Nice score..... Let me know if you need some help setting everything up. Progress is progress and tools always help with that. IMO
Bryce
Company Trucks
Old 12-28-2010, 02:39 PM   #63
bguild
bguild's Avatar
should be getting my 700r4 trans this week...
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 12-30-2010, 11:01 AM   #64
bguild
bguild's Avatar
Picked up the 700r4 from 69cst-v last night and also just bought a cab from teeitup. I havent seen it in person but I figure it might be easier to work a cab with it off the truck. My plan is to get the new cab finished up while driving my truck this summer then late summer possibly putting on the new cab. The good is that the stereo hasnt been cut and its an AC cab.
I hope to get some more updates soon but I need to focus on my Harley for the next few months.. I want to have it running by this Spring.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 01-01-2011, 10:22 PM   #65
72BlckButy
Tot Roddin'
72BlckButy's Avatar
What are you updating on the Harley?
-Nate
Old 01-04-2011, 06:24 PM   #66
bguild
bguild's Avatar
As for the Harley.. I welded on some Tank Extension yesterday.. I also am wiring up a dakota digital speedo, moved my ignition switch so its not on the dash.. I also plan to make a custom fiberglass dash then paint it all before spring.... I have some pictures of my tank extension that I added yesterday that I will post when i get time.. I am planning on starting the trans install on my truck soon. I think we decided to pull the motor so we dont have to lay on our backs plus that will give us more time to paint clean etc..
Just not enough time in the day (-: oh well long drawn out projects are good.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 02-09-2011, 06:31 PM   #67
bguild
bguild's Avatar
Well I know I havent posted in a long while.. The reasoning is that its been way to cold to work on anything in my opinion. The only thing I have been doing is working on the harley. I am posting some pictures below of the added tank extensions. I am now going to make a custom fiberglass dash to house my new Dakota Digital Speedo/tach.. Then I plan to prepare for paint. I actually like the look of the satin black sealer i used on my tank so I think I am going to shoot the whole bike that color.. Its either that or gloss black. What do you guys think? The satin black will be faster and cheaper which is appealing since its going to be March soon and riding weather will be upon us.
As for the truck i havent done anything. I did drive out and start it the other day and that got me fired up. My buddy and I plan to pull the engine soon so I can do some clean up and bolt up the 700r4 that I got from 69cstv. Hopefully it works like he said it would (-;
Then I plan to attack the truck with my new welder and get things in primer.
Hope all is well with everyone.
here are the pics of the Harley.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 02-09-2011, 06:37 PM   #68
bguild
bguild's Avatar
oh and yes that is my new trans in the background of the last pic.. (-:
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 02-10-2011, 11:10 PM   #69
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Brian... those tank extensions look killer!
It's a toss up for me on either satin or gloss black on the bike. Both colors look great and offer their own appeal and look. Can't even see any weld lines on the tank, awesome work!
-Nate
Old 02-11-2011, 11:13 AM   #70
67chevemall
67chevemall's Avatar
good job on the welder! And thanks for taking the late model bed off the truck..that is such a no no....
Keep er going!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-11-2011, 01:10 PM   #71
bguild
bguild's Avatar
Thanks.. Trust me there is some puddy in there. LOL The way you have to weld them on you are stuck with an area that needs bondo. That is the way everyone does it though. They are looking pretty good.. I plan to shoot it some high build primer soon and then do some final sanding on the entire bike and probably go the satin black color. It really makes the chrome pop on the bike and its cheaper and easier to get rolling.
I appreciate the props on the bike and welder.. I am excited to tear in my truck.. I have a lot of plans for it.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 02-11-2011, 01:11 PM   #72
bguild
bguild's Avatar
Keep er going!
Yes that bed was ugly.... I just hope I can get this one fixed up.. the drivers side has some issues but atleast its not rust.. I should be able to patch it up nicely with this new welder.. I am out of gas already on the welder so I hope to get some soon.. It would be nice to have teh truck running so I could take it to get filled (-;
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 02-11-2011, 02:57 PM   #73
JORGIE95961
Just wanted to say nice work on the bike and the truck... I just bought a 72 with rusty bed floor. can i set up my bed just lik eyours i was under the impression the floor kida held the whole thing together, any advise old wise one?
JORGIE95961 is offline   Reply With Quote
Old 02-11-2011, 04:26 PM   #74
bguild
bguild's Avatar
What you would need to do is buy the wood floor cross sills. You can buy them repo'd or used like I did. I plan to put a wood floor in mine soon but thought I would wait until I get my air ride all set up. The side panels fenderwells are the same. The front panel next to the cab is longer on a wood style bed but you can buy a 20 dollar adapter that you weld on from classic parts. Anyway I hope this helps. The answer is yes you can do it but it would cost you some money to get the cross sills.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 03-02-2011, 09:10 PM   #75
kyull67
kyull67's Avatar
whats going on?!
