View Poll Results: Floor shifter | |||
Yes |
58 | 41.13% |
Heck NO! |
83 | 58.87% |
Voters: 141. You may not vote on this poll |
#51 | |
Re: Does anyone think a auto floor shifter kills a truck
#52 |
I like em...but then again im 50/50 between chevy trucks/ an muscle
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
#53 |
I like the Lokar but not the B&M (Had a B&M Z Gate in a 57 Chevy BigWindow Short Step and I found it hard to shift). In fact I am going to put a Lokar in my 67 Shortwide.
JRBECK64 |
#54 |
Like em, I also like Joe Dirt.
#55 |
#56 |
Its cool in a daily driver hot rod too...
1970 Chevrolet C-10 w/355sbc ![]() 2010 Silverado Daily Driver ![]() 1971 Mercedes 280sl project car ![]() |
#57 |
I always wanted one when I was younger. I also wanted everything modified. Now that I am older I have an appreciation for the stock stuff. Word of advice. get a floor shifter if you have a habit of using a worn out stock shifter as an arm rest. Dropping a tranny into first at 65 mph wreaks havoc on planetary gears
#58 |
The Lokar floor mounted shifters are very nice. My cousin just put on in his 66 GMC. He has been in the tranny business forever and he was very impressed with the quality.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#59 |
#60 |
I'm outtttttttt!
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" ![]() ![]() |
#61 |
the locar looks the best in my opinion
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
#62 |
Have the B&M ProRatchet cable shift inbetween bucket seats hooked up to a TH400. Had to take off the down shift linkage from carb to trans to use the Ratcheting option for hot rodding. If I didn't have a big engine then merging or passing would be a chore. B&M requires maintenance, cleaning and lubing, or you will be stuck in gear. Because of this, I'm looking into the Lokar mechanicle linkage. A plus, still have the columb shifter parts.
#63 |
If you still want the ratcheting, you can run a B&M Megashifter. Never had the first problem out of it. Plus, if you have a TH400, you should be able to run the electronic switch kickdown (what I have on mine) that mounts right on the carb. Had to run it on mine since I have a double pumper.
#64 |
I've gone with vaccum secondary's, will the switch still work, and is it an electronic trans vaccum kickdown? Does the Mega Shifter require shifting twice from reverse to park like the ProRatchet?
Look at the difference between the two: B&M Mega Shifter: http://www.bmracing.com/PRODUCTS/Per...ck-Megashifter Cable operated 12.6" high Pull reverse lockout lever seperate from stick Lokar http://www.lokar.com/product-descrip...s-shifters.htm Mechanicle 6, 8, 10, 12, 16, 23, & 32 inch shifter levers. Psuh button reverse lock out IMO, the Lokar looks nostalgic with modern indicators: http://www.lokar.com/interior_pages/indicatorsboots.htm But much more pricy: Lokar shifter and boot+indicator are sold seperatly with a cost upwards of $450. B&M Mega Shifter comes complete at a cost of $250 |
#65 |
I'm not sure about vaccum secondaries, but the way mines set up is the switch is mounted to the throttle assembly on the carb and basically when you go WOT, it depresses the switch signaling the transmission to go into its passing gear (kick down) granted mine has mechanical secondaries. I dont remember having to double shift to go from reverse to park, Ill pay attention to it tomorrow, but it does have the reverse lockout.
#66 |
I know enough to be dangerous, better triple check that yellow wire connected to my TH400.
#67 |
Beautiful and creative, way to make an old classic a modern American stunner!
#68 |
Anyone know where to pick up a four speed shifter for cheap??
"Its better to burn out than it is to rust!" '70 GMC C10 2wd. 2.02 aluminum heads. TH400 trans. 450WHP '04 Nissan 350z DD, Twin Turbo, 600whp, drag beast! |
