Old 09-02-2011, 01:39 PM   #1
youngrodder
youngrodder's Avatar
Re: Tami's 51 build
Skip- The cab looks great. What a difference a little primer makes huh..
Keep up the good work.
Best of luck with the blower..lord knoes that ther is enough room under the hood on these AD trucks.
As a side note, I was able to put 50 miles on my truck last weekend...It felt awesome.....
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 09-12-2011, 01:04 PM   #2
Vic45
Vic45's Avatar
Re: Tami's 51 build
from one FF to another that is one nice looking build you have going there
Vic45 is offline   Reply With Quote
Old 12-15-2011, 07:32 PM   #3
Spackle100
Re: Tami's 51 build
Any updates?
Spackle100 is offline   Reply With Quote
Old 01-22-2012, 11:34 AM   #4
skip99
skip99's Avatar
1 piece manual window conversion
It's been a while since I got to work on the 51, had to paint a few money makers !!
The plan was to convert the 2 piece to 1 piece window..the initial info I got was that it was pretty easy, you just needed the 49 type mechanism..WRONG, WRONG WRONG !!!!lol..
I was already committed with these doors( chopped, bear claws)
and couldnt find 49 doors here in ohio anyway..so....here is what I hope is a very comprehensive how to..
(ps..finding 1 piece doors is by far the easiest, if you know ahead of time..)
here we go !!
starting with the original 51..you see the single arm regulator..
this is the mechanism you will need, along with some extra track.
i used the track from one of the original pieces, and cut it in half.
you will also need to build a front glass run channel,( or as I found after I built mine, they now make a repro. that is narrow 5/8 just for this..$25 ea. just buy it !!
if you want to make your own..just copy the rear, and make a extension to mount it to the door. the new front track stans out about 3 1/2 inch from the door jamb. use 22 gauge steel, bend to 5/8 inside for 5/8 felt WITHOUT the metal around the glass.
here's something you never read...to get the rubber in place for the outside wiper, you need to extend the channel, luckily I had an extra old door and so I separated the 2 pieces of metal, welded on an extension and the tacked it back in the door, I have read where some have simply used fuzzies that fit and glued or dbl, side tape them in.. you cannot screw or rivet like on later cars,
welded in new extension
close ups of where to drill
track cut from original 2 pc
templates make it a little easier
small track added.. when Installing.. I screwed one side and the pivot the other until the track is level. at the time of install, I'll probably tack it in place.but dont weld it first..
almost there
you'll need to fill in this notch, or use 49 style.
welded up..
with garnish in place...5/8 wide for glass WITHOUT metal trim around it
also have to bend up the area where the vent went.
finished ....I ordered new regulators.. these had busted springs and rollers, but worked for mock up..
I borrowed this pic, it helped a lot.thanks!!
Now I see why most just went with a power option!!..
also, if you want the metal trim glass, use wider glass run, and felt from a 49.original stuff should work, but again, we chose the hard route, but glass run was easy to find. cr lawrence? has it my local glass guy has it..
hope this helps!!
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 02-12-2012, 04:04 PM   #5
skip99
skip99's Avatar
Re: Tami's 51 build
got a little done...
going to add an eaton posi unit with 342 gears.
trying to decide where to weld this..
Tami's 51 build
Old 02-16-2012, 08:25 PM   #6
skip99
skip99's Avatar
Re: Tami's 51 build
working on adding the e brake...
Tami's 51 build
Old 04-16-2012, 03:39 PM   #7
youngrodder
Re: Tami's 51 build
Skip-
The progress looks good..
Keep it up.
Marc
Old 07-14-2012, 11:31 PM   #8
skip99
skip99's Avatar
Re: Tami's 51 build
truck on hold ..again...doing a restore on a black 79 trans am...to sell and spend $$$ on the truck !!lol
Tami's 51 build
Old 09-07-2012, 10:35 PM   #9
skip99
skip99's Avatar
Re: Tami's 51 build
alrighty...sold the black TA, paid the bills and pulled the truck out and started welding again !! will post some pics in a day or two...here's the TA ...turned out pretty nice...
got strange reactions from the trans am crowd....they would say."you're selling this , to work on that"? lol!! Tami loves her truck !!
Tami's 51 build
Old 09-08-2012, 11:31 PM   #10
mknittle
mknittle's Avatar
Re: Tami's 51 build
Looking forward to seeing how the bed comes out.I was thinking about doing the same thing with the rails.
T/A came out nice.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-09-2012, 12:33 AM   #11
skip99
skip99's Avatar
Re: Tami's 51 build
I'll get pics posted monday. of the bed. she's roughed in..lol
Tami's 51 build
Old 09-09-2012, 10:50 AM   #12
mknittle
mknittle's Avatar
Re: Tami's 51 build
Cool, I was looking through your thread again{it's been a while} and getting some ideas
I like the A/C vent idea! and looking at your bear claw linkage gave me an idea that may solve a problem with mine with the turn down handles.{one of thoce the same but different}sort of things.
Mark
My GMC build.
Old 09-19-2012, 12:45 PM   #13
67_ShortFleet
67_ShortFleet's Avatar
Re: Tami's 51 build
Nice build! Can't wait for more progress.
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 09-20-2012, 05:15 PM   #14
skip99
skip99's Avatar
Re: Tami's 51 build
time to catch up !
playing with hood alignment and fit...
almost done with the bed...took an s-10 roll pan, cut off the flange at top and the sides, then welded it in. didnt want a heavy look to the rear, then fit and trim the original pockets to contour to the new pan,
in the next day or two...gonna put a 48" flush mount 200 led light across the pan, just above the plate square. also putting a 6" flush 3rd brake light under rear window. STAY TUNED !!
you'll also notice that I reworked the tailgate hinges .we plan on using a net, so you can see the custom, black carbon fiber bed planks that we designed..
Tami's 51 build
Old 09-20-2012, 07:49 PM   #15
mknittle
mknittle's Avatar
Re: Tami's 51 build
That looks way more better Ilike it
Mark
My GMC build.
Old 01-14-2013, 03:31 PM   #16
skip99
skip99's Avatar
Re: Tami's 51 build
A little progress...the bed is done..the cab and hood are done,,,I have blocked til my arms are noodles !!
slot cut for LED lites.
epoxied in place..
did a small led below window..
bodywork done and a coat of featherfill
hood smoothed...
gaps close..
getting ready to build the running boards,,,
Tami's 51 build
Old 01-14-2013, 04:59 PM   #17
youngrodder
Re: Tami's 51 build
Skip-
It's looking more and more like a truck. Nice progress.
Keep it up. I agree sanding does suck. Your hood/gaps look great. That is where most AD trucks show there age.
Marc
Old 04-15-2013, 10:27 AM   #18
skip99
skip99's Avatar
Re: Tami's 51 build
Getting closer....today is the first time it's seen daylight in 2 years!
I think ..hope...all the bodywork is finally done, gonna spend the next month or so sitting out on sunny days.....
Gonna get the ac stuff ordered, and see how all that goes in !
Tami's 51 build
Old 04-15-2013, 10:44 AM   #19
skip99
skip99's Avatar
Re: Tami's 51 build
Running boards and front bumper are done too!
Boards were made in a few pieces, because we wanted smooth boards but still have the original curves on the inside and edge, so there was a lot of cutting and welding..front bumper was smoothed and studded, then reworked the bumper brackets so bumper is about 1 inch from grille, then just made a filler panel and welded it to bumper..
Tami's 51 build
Old 04-15-2013, 10:56 AM   #20
mknittle
mknittle's Avatar
Re: Tami's 51 build
Funny how much the primer changes the whole look of the truck. Or any color for that matter. looking great!!!
Mark
My GMC build.
Old 04-15-2013, 07:26 PM   #21
youngrodder
Re: Tami's 51 build
Skip -
Nice progress. All of your gaps look great.
Marc
Old 04-15-2013, 10:36 PM   #22
solidaxel
solidaxel's Avatar
Re: Tami's 51 build
So if you had a competent shop follow your instructions, how many hours would they charge you to put the truck in that stage?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-17-2013, 08:43 AM   #23
skip99
skip99's Avatar
Re: Tami's 51 build
Sounds like a rhetorical question ! I quit even trying to keep track, I do know I could have built maybe 3 cars in the time it's taken me to do this...but close guess, 500 hrs so far...
If I were paying for it, would have been much cheaper to just buy rear fenders
, but wanted to use original pieces...running boards, just another example of our depravity..lol....probably have 40 to 50 hours in those...
Tami sat in it yesterday pretending to drive, you know... Vroom vroom, sckeeerrch ! Smiles are worth it all...
Tami's 51 build
Old 04-17-2013, 09:37 AM   #24
solidaxel
solidaxel's Avatar
Re: Tami's 51 build
That is the part most folks do NOT see when they look a high price FINISHED truck.
Nice job, you will enjoy all of those hours when you are driving HER truck!!
LS 3 4L70E
Old 04-17-2013, 12:21 PM   #25
skip99
skip99's Avatar
Re: Tami's 51 build
That's a fact. This is the day I brought it home....other that the chop, looks like all I did was spray primer, huh.?
Tami's 51 build
