Old 12-28-2010, 04:51 PM   #51
vintage_car
Re: v8 motor mounts with s-10 swap?
Originally Posted by rollinrooster View Post
vintage car....
If you use the mounts you will have to switch sides (left mount on the right / right mount on the left) you will have to modify the mount on the passenger side to clear the fuel pump. I'm kinda like thadious and after looking at all my options i'm just going to make mine.
rooster, did they not work for you either, even swapped?
vintage_car is offline   Reply With Quote
Old 12-28-2010, 04:53 PM   #52
vintage_car
good looking cross member Thadious. thanks for the pics on that and the engine mount tabs. I'm anxious to see the mounts welded up.
Old 12-30-2010, 01:11 PM   #53
vintage_car
rooster- I flipped them around and the engine is sitting where it is supposed to sit. There is a little over an inch clearance from cab to distributor. I had to notch the passenger side around the cast area the fuel pump attaches to. I have an electric pump, so I'm just going to put a block off plate on mine.
Old 12-30-2010, 11:00 PM   #54
rollinrooster
rollinrooster's Avatar
When i got my s-10 frame it had 4.3v6 mounts and after trying almost all options i've decided to use these mounts and it puts my motor about an inch or so from the firewall with little work. I will be using an electric fuel pump also and an vintage air front runner system. I'm glad you got the mounts to work for you i came real close to doing the same thing you did with the mounts i have.
rollinrooster is offline   Reply With Quote
Old 06-24-2012, 04:01 PM   #55
55dude
55dude's Avatar
old thread but great info!
55dude is offline   Reply With Quote
Old 04-22-2014, 01:42 AM   #56
Nodough50
I agree! About ready to install 350 in my '50 and am considering the Jags that run mounts - I like the adjustability aspect. Also looking at Ad engineering's mounts made specifically for this install. ADE's mounts are a little pricy but come with poly bushings... decisions decisions
Nodough50 is offline   Reply With Quote
Old 05-05-2014, 12:15 AM   #57
T-P Auto
Hello guys:
I have a project on this site(The Frankenstine).
I'm use n a 305 V8 with a 200r4 trans.
I have some pic on the motor mounts that I used.
I have stock 4.3 steel frame mounts from a Olds 4x4,then used the rubber engine mount from the same 4.3 engine.
The 4.3 n 5.7 n 305 all use the same bolt pattern on the block.
I set the motor in the frame ,then used the exhaust manifold off a vortex 305 to clear the A frame.
Look at the pic in my post under projects.
I had the serptine set on the front of the mock up an all cleared.
I have went to old school set P/S n Alt with v-belt set up.
Hope that this will help out some of you on your mock up.
T_P Auto
T-P Auto is offline   Reply With Quote
Old 05-07-2014, 08:08 AM   #58
T-P Auto
Hi guys.
I just got my 305V8 set back in the frame. pic
The mounts I used where off the 4.3 (Old 4x4).
The steel mounts were off the same truck.
You can see the mounts in the photo.
T-P Auto
