11-27-2010, 12:54 PM | #51 |
Re: Easy way to clean out the gas tank
Who all has used the 149.00 new tank and who has them?
Thanks |
11-27-2010, 01:43 PM | #52 |
I'll second everything Swamp Rat says!
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
01-02-2011, 01:03 AM | #53 | |
Thanks this just answered a few different questions that I had, ok so im thinking instead of buying a new tank, cleaning the old, etc, why just not buy an old keg and make a gas tank!! empty kegs go for around $40 or so...but who wants to buy an empty keg lol
58 Jeep willys pickup 67 K10 4x4- soon to be trail truck TROUBLE MAKER RACING "If you can't stand BEHIND our troops, please stand in FRONT of them." |
01-02-2011, 08:17 AM | #54 |
So buy the full keg and have a work party. I'm sure you'll get lots of help pulling the old tank, patching the hole, anything else that needs done, by then the new tank will be empty and ready for "tapping" the new fuel lines in. Where you going to put it thought?
01-02-2011, 10:34 AM | #55 |
Active Member
Hay Fitz, your just what this site needed: a rocket scientist!
01-02-2011, 12:34 PM | #56 |
"brand new second-hand"
I have aftermarket saddle tanks that need cleaning. These look like they are made from steel. Would these be a good canidate for the radiator shop clean-out or what have you done to clean/seal them?
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
02-25-2011, 07:41 PM | #57 |
Acid can be neutralized pretty easily with a little baking soda and you could evaporate or burn the alcohol. Hey, you could just filter it out and put it back in the tank for fuel
07-07-2014, 12:46 PM | #58 |
I did my tank this weekend. The rotisserie would've come in handy!! Went to carwash and washed inside of tank 5 times until all that was coming out was soapy water. The first couple of times I emptied it, it was disgusting.
Went home and stuck a 20 foot length of chain in it, propped it on the raised tailgate and played see saw w/it for about 90 minutes, sliding the chain back and forth. I'd rinse periodically w/fresh water washing out the rusty water. Did that till it was pretty clear. Mixed 5 gals (4 to 1 solution of muriatic acid) and dumped that in the tank and let sit for about 2 hours on each side. Before I dumped it out, I added a 5 gals of water that that I dissolved a box of baking soda in to neutralize the acid. I did that 2 more times. Rinsed a couple more times w/water and let dry. Installing in truck tonite and I'll let ya know tomorrow how it went. Note: My sending unit was pretty rusty, but I let it soak in vinegar for 24 hours and it is now clean as a whistle. All in all, I've saved at least $200, but still don't have peace of mind as opposed to buying a new tank. |
07-07-2014, 04:26 PM | #59 |
Muriatic acid is hydrochloric acid. That's the same stuff your stomach uses to digest food. When was the last time you had to call a hazmat team because some drunk puked in the mens room at your favorite bar? If the stuff were toxic all of you would already be DEAD!
07-07-2014, 04:42 PM | #60 |
I'll second the Caswell sealer for fuel tanks. It survives motorcycle tank usage- with vibration, heat and the usual unseen rust inside. A guy at a bike shop told me 'This is the stuff you use to cover all the other sealants that get used!' It works! I use it on old British motorcycle restorations- solves all the problems, however, I've never used it on a Fiberglas tank, those are best replaced with steel.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
07-07-2014, 06:34 PM | #61 |
I cleaned mine out with formic acid, it totally dissolves rust into a very fine powder when dry. Just put in 2 gallons and fill the entire tank up and let it sit for about 24 hours. Drain, (can be disposed in city sewer systems) rinse really good a few times and empty the tank. Let it air dry for a day then reinstall. There will be a surface rust formed but when you fill it with gas the next time it will dissolve completely. I have used fomic acid for cleaning everything from rusty tools to entire fenders and engine blocks and never had any problems.
07-07-2014, 06:41 PM | #62 |
X3 on the muratic acid. Also use a small langth of chain. Like from an old transfercase.
I got my acid at lowes.
1967custom |
07-07-2014, 06:54 PM | #63 |
Junior Member
if its rusty vinegar works great. takes a few days but is easy & cheap. its a mild acid...
frontstreetcycle on Instagram |
07-07-2014, 07:00 PM | #64 |
It wasn't cheap but this is what I did, on advice from VW Nate.
I pumped out my (siphoned) out my old gasoline and then removed the tank. I took the tank over to a radiator shop and had them clean and "renew" it. They boiled it then cut holes into the sides to sandblast out the rust. Then they welded up the cuts and coated the insides with a material. I then painted the outside with primer and then paint. I like it. I got to keep my original tank too. |
07-08-2014, 08:59 AM | #65 | |
