Old 10-07-2012, 11:39 AM   #51
txinliner
txinliner's Avatar
Thumbs up Re: Buttercup '66
Originally Posted by MalibuKasey View Post
an update is WAY past due. By now I think everyone has seen the truck.
So the motor I had in the truck had some SERIOUS blow back issues. I tore it down and found three broken top rings and a lobe on the cam was almost rounded off.
Before Goodguys I yanked the whole frontend and redid the firewall. It was painted and black and bugged the hell out of me. I used some custom mix rattle cans from the local paint store and it worked PERFECT!!!
I then tossed in a temporary vortec headed SBC just to get me there.
The old motor is getting an internal makeover. Its still going to "look" like the factory 283... but its going to be healthy :-) MUHAHAHAHA
I also had to do a little rust repair while the frontend was off... the lower cowl had a big hole in it. Top Banana hooked me up with the right part.
As for the rest of the truck... When the motor goes back in its getting a 700R4 and powersteering. A long with a CPP rear swaybar. I actually picked up the Steering box and Pump from Richards in Denton, NC this past Saturday. Other than that... Im going to lower the seat a little to give the Jewels a little extra room to breath :-)
love the stance and that you left the top of the cab alone.im really thinking about the 7 drop for the back of mine but the fronts gonna have to come up ( so i can get out of my drive way) youre truck is *****in
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 10-07-2012, 09:54 PM   #53
allaboutchevelles
allaboutchevelles's Avatar
Re: Buttercup '66
I dont know if he is but I sure am ready for the good guys. I havent ever made it to the goodguys. I normally go to both the charlotte auto fairs but I will surely see yall down there at the goodguys in a couple weeks.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 01-28-2013, 04:10 PM   #54
MalibuKasey
Artist
MalibuKasey's Avatar
Re: Buttercup '66
Its been awhile. I havent messed with the truck alot. I destroyed the 700R4 behind the little 283... So I have been working on a T56 upgrade. I just about have all the parts for the whole deal and after this week I will have all of them.
I spent time this weekend doing a little odds and ends. I have a serious ground issue that I hope I tracked down with the tail light harness. Some chipmunk decided to try and wire a trailer harness to it. BAD IDEA! Ive attached pics of the wire nutted wonder!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 01-28-2013, 04:11 PM   #55
MalibuKasey
Artist
Re: Buttercup '66
Yesterday I worked on making the perfect steering wheel! Based on the Astronaut's (John "The Wiz" Glenn) original idea.... I found a wheel with a 15" outer ring so I took the center of a 66 and got the ball rolling! Its going to be killer!
Old 01-28-2013, 09:34 PM   #56
CRGRS 66
CRGRS 66's Avatar
Re: Buttercup '66
Killer truck, love that shot on the freeway
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 01-28-2013, 09:49 PM   #57
theastronaut
theastronaut's Avatar
Re: Buttercup '66
Looking good! The steering wheel idea wasn't original with me though, I saw it in a wheel resto how-to book. Get that six speed in, we need rolling burnout shots!
Looking forward to a shifter relocation how-to, hint hint.
theastronaut is offline   Reply With Quote
Old 01-29-2013, 02:01 PM   #58
jcramsey
jcramsey's Avatar
Re: Buttercup '66
Truck looks great! Glad to see you are running drop springs and spindles up front without any issues...the spindles and discs are next on my list.
jcramsey is offline   Reply With Quote
Old 02-08-2013, 04:41 PM   #59
MalibuKasey
Artist
Re: Buttercup '66
Started on the T56 Shifter relocation....
Old 02-10-2013, 06:50 PM   #60
MalibuKasey
Artist
Re: Buttercup '66
Picked up another front crossmember..... Who wants to bring the syrup for the pancake?
Old 02-10-2013, 06:54 PM   #61
theastronaut
Re: Buttercup '66
Just sent you a link about that... like two minutes ago before I saw this.
Old 02-17-2013, 07:32 PM   #62
MalibuKasey
Artist
Re: Buttercup '66
Finally for the t56 shifter relocation done!!!! Ready to get this joker in!!
Old 02-17-2013, 08:11 PM   #63
theastronaut
Re: Buttercup '66
Lookin good! You might have to notch the crossmember and drop your "283" down so it clears your floor.
Old 02-19-2013, 12:13 AM   #64
MalibuKasey
Artist
Re: Buttercup '66
Hmmmm we shall find out tomorrow night.
Old 02-20-2013, 12:03 AM   #65
MalibuKasey
Artist
Re: Buttercup '66
Tossed the 6 speed in just to test fit and clearance. Boy it is SUPER snug in there!!
Old 02-20-2013, 02:25 PM   #66
theastronaut
Re: Buttercup '66
You prolly know this stuff already but these were a big help for this driveline dummy.
http://www.iedls.com/asp/admin/getFi...&TID=28&FN=PDF
http://www2.dana.com/pdf/J3311-1-HVTSS.PDF
Although I feel about like this after reading through those and wondering how I'm going to actually use the info!!
Old 02-20-2013, 05:12 PM   #67
MalibuKasey
Artist
Re: Buttercup '66
Thats actually pretty good info. I guess I need to purchase an angle finder and get started. Lowering the engine down doesnt seem to be a good idea with pancaking the crossmember. Seems like oil pan clearance will be an issue. A high tranny hump might not be a bad idea. I could sell the low hump mat I just installed. Does anyone sell a high hump?
Old 02-20-2013, 05:37 PM   #68
MalibuKasey
Artist
Re: Buttercup '66
Im thinking these.... Something a little nicer.
http://www.classicperform.com/Store/...ck/6372MPS.htm
Old 02-27-2013, 01:03 PM   #69
Bomp
Bomp's Avatar
Re: Buttercup '66
Read. Like. Watchin.
Bomp is offline   Reply With Quote
Old 02-27-2013, 02:04 PM   #70
1963c-10
1963c-10's Avatar
Re: Buttercup '66
Great looking truck....always glad to see more carolina truckers here. What does your buddy charge to dyno an engine? Ive got a big block that Id like to dyno when I pick it up in a few weeks. Figured it'd be easier to tune on the dyno
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-01-2013, 11:46 AM   #71
theastronaut
Re: Buttercup '66
Originally Posted by theastronaut View Post
...we need rolling burnout shots!
Cough cough...
Old 03-01-2013, 02:37 PM   #72
MalibuKasey
Artist
Re: Buttercup '66
Soon enough!!! Picked up a tranny hump from these folks.
http://www.4-5-6chevytrucks.com/
Hopefully it will be here next week.
Old 03-02-2013, 12:29 AM   #73
66 C10 383
Re: Buttercup '66
Did you use the Keisler T56 relocation kit? I see they're now priced at $400. I have an Aftermarket T56 to put in my 66 but for $400 I'llleave the shifter wherever it comes thru. Does anybody else make a more reasonably priced relocation kit?
Awesome build on the truck !!!
66 C10 383 is offline   Reply With Quote
Old 03-02-2013, 12:32 AM   #74
MalibuKasey
Artist
Re: Buttercup '66
Mine is the New style Keisler kit... they are the only ones that make the relocation kit. Pricey... Im deadset on a Bench seat so there is no way around it.
Old 03-02-2013, 12:33 AM   #75
MalibuKasey
Artist
Re: Buttercup '66
and thanks I dig the heck out of the truck. Its been fun.
