Old 03-26-2011, 10:11 PM   #51
72MARIO
72MARIO's Avatar
Re: 2wd lift and new 18's w/ 33x10.5 Nittos
Do you think that the 2500 8 bolt wheel 2wd lift spindles could be adapted the same way to a 67-87 2wd ?
Would like to get spindle lift for my 67. I have the fabtech 3" coils and 1.5" coil spring spacer. ball joint flipped from top to bottom of upper controll arm and 1" spacer on top of the ball joint. but there is not alot of rebound.
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-02-2012, 03:41 AM   #52
silverado_men
I want do the same on my 87 silverado. Problem is I'm Germany and to get the parts is very Hard. My question is wehre can I get the 4" lift spindles? Is there a link? Can I use these ones?
http://www.ebay.com/itm/260606807174...1#ht_561wt_922
Thx for you help :-)
silverado_men is offline   Reply With Quote
Old 06-02-2012, 05:29 AM   #53
wwj75c30
wwj75c30's Avatar
Mario
not trying to steal a tread but did putting the ball joint under controll arm plus 1" spacer add a inch? i have 3" coil spacers and could use a extra inch
wwj75c30 is offline   Reply With Quote
Old 07-17-2013, 09:35 AM   #54
Twistedvegas
Adding life to an old highly informative thread. I'm in the middle of doing this swap on my 71 C20. For those wanting to run Fabtechs 92-98 8-lug spindles, the upper balljoints are not the 88-98 joints. Looking like the factory C20 uppers will work. We'll see when I get off work and can pick the suckers up from O'reilly. If not, does anyone have any suggestions?
Twistedvegas is offline   Reply With Quote
Old 02-13-2014, 01:40 PM   #55
aggie91
I'm just glad to be here!
aggie91's Avatar
Glad I found this one...My youngest boy wants to build a pre-runner style truck...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-02-2014, 06:54 PM   #56
stersam
So are the ball joints 3/4ton? Because I have a 73 c20 that i'd like to do this to but with a bit wider tire.
stersam is offline   Reply With Quote
Old 10-14-2014, 11:05 PM   #57
79 blue monster
79 blue monster's Avatar
Question: I have a 3/4 ton and want to do the same lift but keep it a 3/4 ton instead of a half ton. Do they make 3/4 ton 88-98 lift spindles? If not, is the 73-87 3/4 ton spindle size the same as the 88-98 1/2 ton spindle size?
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP
http://67-72chevytrucks.com/vboard/s...d.php?t=518625
1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972
79 blue monster is offline   Reply With Quote
Old 11-10-2014, 02:38 PM   #58
B-wayne44
Originally Posted by Justins76 View Post
18x8" Chevy 6 lugs wheels off a new Z71
Nitto Terragrappler 33x10.50
Rear 2.5" Rancho lift blocks
Bilstein 5100 extended shocks
Front-
88-98 Rough Country lift spindles
88-98 Raybestos PG ball joints
88-98 C2500 LD 6 lugs rotors and calipers
Moog 6454 HD springs.
Belltech 1 3/8" sway bar
73-87 C30 lower A-arm
73-87 C10 upper A-arm
One problem I ran into was the 88-98 outer tie rods connect to the spindle from underneath and caused interference with the sway bar. I do not know if this would be a problem with the stock sway bar. Since the tie rod joint is smaller then a 73-87, what I did was get a taper reamer from summit and reamed it from above and used the stock tie rod.
The brake hoses are from a 88-98 and they connect to the frame differently. If you clock them just right, they will fit into the hole in the frame and use a horseshoe shaped clip to hold it in.
The spindle, rotors, bearings, calipers, pads, ball joints and hoses I used were from a 1994. The rest is stock 73-87 parts, with 1 ton lower control arms.
You have to use 88-98 rotors and calipers. Since the 88-98 ball joint is bigger, it wont fit 1/2 ton arms. I'm using 88-98 Raybestos PG (formerly Spicer) ball joints.
Nice build looks good!! I have an 84' I want to do this to, did you have to do and frame mods for the a-arms? Or is everything bolt on?
1984 GMC c1500
"The Welder"
B-wayne44 is offline   Reply With Quote
Old 11-11-2014, 12:13 AM   #59
mitch_04
Wish I would have seen this a week ago! Just bought some bags to raise up the front of a 2wd.
mitch_04 is offline   Reply With Quote
Old 01-29-2015, 01:26 PM   #60
B-wayne44
Front-
What shocks did you use in te front?
1984 GMC c1500
"The Welder"
Old 01-29-2015, 02:20 PM   #61
SCOTI
SCOTI's Avatar
I would imagine they're OE replacement Bilsteins.
The lower a-arm's remain in the factory location w/a HD spring so the distance between the lower shock mount (@ the a-arm) & the upper mount (@ the frame) hasn't changed much.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
