Old 02-01-2011, 12:46 PM   #51
tech@scottshotrods
Re: Extreme Drops
heavey metal that Justin Drove 2300 miles each way from Ventura, CA to Indianapolis, IN
tech@scottshotrods is offline   Reply With Quote
Old 02-01-2011, 01:26 PM   #52
SCOTI
SCOTI's Avatar
Re: Extreme Drops
Ok, I knew what vehicle you were talking about.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-01-2011, 01:43 PM   #53
tech@scottshotrods
Re: Extreme Drops
many don't though so i threw up a few pics
Old 02-01-2011, 02:42 PM   #54
Scottshotrods
Re: Extreme Drops
That is so cool you knew that but we figured to show all people that do not know.You can drive a full blown show truck across country .
Justin
Scottshotrods is offline   Reply With Quote
Old 02-03-2011, 04:00 PM   #55
Scottshotrods
Re: Extreme Drops
What happen guys nobody wants to come out and play!
Justin
Old 02-03-2011, 04:38 PM   #56
Mkcustums
Mkcustums's Avatar
Re: Extreme Drops
Justin
Yeah, I'm surprised this thread isn't a lot more active than it is.
Mkcustums is offline   Reply With Quote
Old 02-03-2011, 04:42 PM   #57
PBFAB.COM
PBFAB.COM's Avatar
Re: Extreme Drops
It would be cool to see some "action" shots of Heavy Metal out on the Interstate! I think I remember hearing it even rained on you guys.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-03-2011, 05:11 PM   #58
tech@scottshotrods
Re: Extreme Drops
I remember seeing it in indy looked like a swiming pool and justin didnt care LOL interior was replaced i think 2-3 times due to un foreseen rain storms
Old 02-03-2011, 10:50 PM   #59
502ss
502ss's Avatar
Re: Extreme Drops
Originally Posted by bedsled71 View Post
can you explain why there would be a problem with vibrations with the driveshaft on an incline since the vibrations are caused from the angles of the ujoints working aginst eachother? or is that not correct?
This should explain it.
http://www.hotrodhotline.com/md/html..._harmonics.php
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 02-03-2011, 11:51 PM   #60
SCOTI
SCOTI's Avatar
Re: Extreme Drops
Actually, that only explains the equal but opposite need for the cancellation of the angles to eliminate the possibility of vibrations (it also states the d.shaft should be sloping down approx 1°).
My buddy also questioned how the d.shaft knows whether it's sloping up or down thus it shouldn't make a difference.
This is why I stated earlier that the 'difference' would be that when the shaft slopes upward to the pinion, you calculate the angles differently. The result is typically excessive angles that are nearly impossible to cancel thus why I feel they recommend it to be avoided.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-04-2011, 09:14 AM   #61
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: Extreme Drops
Hey Scoti how far from Dallas to Columbus....y'all only have about six months!
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 02-04-2011, 09:51 AM   #62
502ss
502ss's Avatar
Re: Extreme Drops
Then here is some more.....
http://www.drivetrain.com/parts_cata..._problems.html
Old 02-04-2011, 10:11 AM   #63
SCOTI
SCOTI's Avatar
Re: Extreme Drops
17hrs straight through..... been there & done it so I know what to expect. This truck will make that drive.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-04-2011, 10:28 AM   #64
SCOTI
SCOTI's Avatar
Re: Extreme Drops
Quoted from that source:
When the slopes are in the Same direction on two connected components, Subtract the smaller number from the larger to find the u-joint operating angle. When the slopes are in the Opposite direction on two connected components, Add the measurements to find the u-joint operating angle.
This would mean if the trans is angled down & the d.shaft slopes up, you would add the angles to arrive @ the working angle of the joint. We'll say the trans is @ 3°dn & the shaft is 2° up: 3+2 = 5° working angle.
If the driveshaft is sloping down from the pinion & the pinion is angled down, you would subtract the angles. We'll say the d.shaft is @ that same 2° up & the pinion is 3°dn: 3-2 = 1° working angle.
The numbers yield a 4° difference.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-04-2011, 10:56 AM   #65
killer71
killer71's Avatar
Re: Extreme Drops
ken, do you have any side shots of that truck so that the wheels can be better seen?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 02-04-2011, 11:41 AM   #66
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Extreme Drops
Lets see what I have...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-04-2011, 12:13 PM   #67
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: Extreme Drops
The sight of this truck makes you wanna just...
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 02-04-2011, 02:22 PM   #68
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Extreme Drops
Hahahaha- in a good way...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-04-2011, 02:31 PM   #69
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: Extreme Drops
no doubt
77' Chevy SB
5.3/4l60e combo
Old 02-04-2011, 06:11 PM   #70
502ss
502ss's Avatar
Re: Extreme Drops
Quoted from the source:
Always measure the slope of the drivetrain going from front to rear. A component slopes downward if it is lower at the rear than the front. A component slopes upward when it is higher at the rear than it is in front.
Wouldn't this phrase mean that a gearbox with it's tail shaft lower then the converter shaft would mean it slopes down(which makes sense) but the rear end which you would think if the input shaft was angled up then it would be sloped upward but the phrase says it would instead slope downward!
I would have to sit and draw this out in CAD but I am on my way out the door to do some snowmobiling for the weekend!
Old 02-04-2011, 06:56 PM   #71
OARNGESI
OARNGESI's Avatar
Re: Extreme Drops
was that truck built on tv
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-04-2011, 07:41 PM   #72
Scottshotrods
Re: Extreme Drops
Yes it was built it in 90 days and took it to detroit then drove it to
Gm in detroit in the freezing ass cold weather.lol
Justin
