#51 |
Re: 64-66 Chevy Stock Gauges - Voltmeter vs Ammeter (Batt)?
i did it kinda the same in my 60-63 gauge panel. wanted a vac gauge for the left side (my K10 has the vac brakes) but haven't found one yet that i liked. so i put a $9 volt gauge there temp. tack is an old dixo--didn't want a 8k but the price was right.
1961 chevy K10 my build is------------61K10 build |
#52 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Is that an aftermarket voltmeter or is it an OEM gauge?
#53 |
Capt--if asking about mine, its a chevy blazer i think. it's like the one showed earlier in this thread. i cut it into a round circle and mounted it on the org. blank plate. looks ok---not show Q.
#54 |
I want to thank you for posting your process for Amp to voltmeter conversion, I followed it worked perfect. I modified my dash replaced it with the voltmeter and it works great. Here is a picture of it.
#55 |
![]() Join Date: Aug 2008
1966chevy,
What car was that voltmeter originally from?
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#56 |
1980 chevy truck Silverado, using the same/stock gauge face from the 1966 deluxe gauge.
#57 |
JUST A LITTLE UPDATE: FINAL RENDITION INSTALLED BATOMETER AND SUN TACH 66 GMC.... ![]() http://kieth.smugmug.com/Trucks/66-G...WmmMg&lb=1&s=A IN THE TRUCK: ![]() ![]() http://kieth.smugmug.com/Trucks/66-G...PBQ7f&lb=1&s=A |
#58 |
I went to a junk yard and got the volt meter, have it installed in the cluster cutout thing and ready to install, but how do you hook up the wiring harness to the voltmeter? Did you cut the factory plug and install ring terminals? Any pictures? This is a great writeup, and I tested my gauge before installing. Just hope it all works when I get it back together, haha.
