Old 07-18-2017, 01:28 PM   #51
jchav62
1962 C-10
jchav62's Avatar
Re: 88-98 FAQ's "Is your truck running weird? Check here it could help"
I was just asked a question...
What are the different auto transmissions offered for 88-98? (half tons)
I think the first few years were 700r4, up to 1991?
Then 1992 and up were 4L60e's? Were they all the same up to the body style change?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 07-27-2017, 11:57 AM   #52
diveplane
ok need help
i just installed a full brand new exhaust system from y pipe new cat all the way down including new tail pipe, and o2 oxygen sensor.
most cases the check engine lamp stays off, but it comes on off intermittent.
code am getting is a code 44 lean mixture
how can i resolve this one?
its a bosh o2 oxygen i put on , what other o2 units work?, engine is a 1994 v6 vortec 4.3
manual 5 speed.
i tried a reset on computer , code keeps coming back.
diveplane is offline   Reply With Quote
Old 12-13-2017, 10:48 PM   #53
diveplane
bump anyone know what brand of 02 chevy slammed on at the factory?
Old 03-29-2019, 08:40 AM   #54
shifty
Questionable
shifty's Avatar
If the sticky is still going to be made, awesome write-up for how to handle air conditioning issues, replacement of compressor, AC not working etc.
http://67-72chevytrucks.com/vboard/s...d.php?t=783964
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-15-2019, 08:58 PM   #55
knifeman1
I just got my first late model crew cab project truck. Its an all original 88 TBI 350. The truck seems to run pretty well but at low idle when in gear it struggles and acts like and sometimes dies. I was going to put new fuel pumps in and new sending units and check the little hose. Did they put a pump in each tank or was it one pump outside the tanks? Has anyone had one act like it wants to die when in gear and stopped?
Thanks!
knifeman1 is offline   Reply With Quote
Old 05-15-2019, 09:02 PM   #56
mountie
mountie's Avatar
Fuel pump problem?
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 05-15-2019, 09:04 PM   #57
knifeman1
The driver side tank wont work?
Old 05-16-2019, 06:49 AM   #58
knifeman1
No the driver side wont work
Old 03-23-2023, 12:31 PM   #59
wrangler94
I have read every link in this thread so far, and it has helped me diagnose and fix several issues, but I still have one weird, and very intermittent one. 1992 Chevy 3500, with the 350. it used to randomly cut off alot more often, but replaced the distributor and fixed some other issues, and it rarely happens now, but it does still happen. I will be driving along and everything seems fine, hit a bump (but seems to happen more if i have to slam the brakes hard) and throttle response goes away for a few seconds, but I don't think it's immediately shutting off, as if i dropped to idle, and then it will shut off. Shift to neutral while coasting and recrank it, and everything is fine again.
Any thoughts on where to look for the issue?
wrangler94 is offline   Reply With Quote
