03-03-2011, 06:28 PM | #51 |
Re: Attention All Air Baggers..
jjjmm56
how long would you say it takes from flatout to ride height?also,are those gauges set up one for front and one for rear,how did you know what number to hit just try different pressures and stand back and look?
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 |
03-03-2011, 06:37 PM | #52 | |
way2lo2
I just finished a 63 pickup today, I will make a video of lifting and dumping tomorrow and post it. B
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote. 216 481-5219 office 216 481-4240 fax 216 789-1647 mobile Way2Lo2@aol.com <----also my paypal http://www.hubgarage.com/mygarage/way2Lo2 |
03-03-2011, 06:46 PM | #53 |
Same thing I plan on running. Simple and low cost.
Doug Looking for a 67-72 short bed driver..... |
03-03-2011, 07:10 PM | #54 |
pm sent way2lo2
03-03-2011, 09:56 PM | #55 |
Another setup I ran across
-M.J. 1968 Stepside |
03-03-2011, 10:36 PM | #56 |
I might go this right too... Seems cheap and simple and i am all about that atleast right now.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
03-03-2011, 10:39 PM | #57 |
I assume the upper T fittings are supply air to the bags and the lower barbed fittings are exhaust. Where is the supply air to the valves? In other words, where does the air from the tank/compressor hook up?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
03-03-2011, 10:43 PM | #58 |
Happy to be here
This is in the Suspension Marketplace now.... "Paddle Valve Special"
03-03-2011, 10:44 PM | #59 | |
way2lo2
The valve is normally closed, when moved up the valve opens between supply and delivery letting air flow to the bags. When pushed down it only exhaust the delivery side, letting the air out of the bags. Quite simple actually.
03-04-2011, 12:07 AM | #60 |
Registered Cruiser
Do most guys running these run exhaust lines out of the cab through the floor pan?
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
03-04-2011, 12:14 AM | #61 | |
I was thinking one of them had a barbed fitting for the exhaust. If so, it would be possible to 'T' them together to 1 'exhuast' line that routes to the exterior. It stinks about as long as one of your buddies farts if there's a bunch of moisture in the tank/s. If you don't jack w/the pressure often, it's definitely acceptable for the 1K+ savings .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-04-2011 at 12:14 AM. |
03-04-2011, 12:37 AM | #62 |
I'm sold on this setup, just have to figure what size line to run from the tank to the paddles, 3/8 which I have or 1/2 which I'd have to buy. I'm not looking for a fast fill or drop. Maybe spend the saved money on good filter/dryer for the system.
Posted via Mobile Device |
03-04-2011, 03:44 AM | #63 | |
Mind you if it smelt anything like some of my buddies....i'd be worried! |
03-04-2011, 04:10 AM | #64 | |
03-04-2011, 09:24 AM | #65 |
way2lo2
Maybe I just don't have a nose for it but mine don't smell!.....ah ah paddle valves I mean
03-04-2011, 10:11 AM | #66 |
From full dump it takes about 5 sec to fill, but I never go to full dump. I let the air out till I feel the truck hit the bump stops. And yes I just aired it up till I liked the ride hight looked at the pressure and go to that number every time. On my manifold I have a 1/2 feed from the tank so I know I have pleanty of supply. The 2 black Y fittings are feeding the switches. Then from the switches it goes to a tee fitting one side to the bag of choice and the other side to the guage. on the bottom side of the mainfold I have 3/8 fittings going to the bags. I also put my pressure switch into the mainfold. Yes the air does exhaust into the cab I see no way around it, but it isn't bad at all you don't even notice
03-04-2011, 10:23 AM | #67 |
The only problem I found is the line fit on the barb. When I was first building my systen I found small leak at the barb. By small it would leak down about every 4-3 days. To fix that I used some saftey wire around the hose and barb with good results. I have no smell in the cab from the exhaust. I recomend using some type of mainfold to keep the hoses from rubbing going thru the cab. If you need help with a mainfold PM me and I can get you a diagram.
03-04-2011, 11:02 AM | #68 | |
03-04-2011, 03:47 PM | #69 |
Ya that works too: I just got bord at work one night and made the mainfold. Bulkhead connectors would work also.
03-04-2011, 05:27 PM | #70 |
Here are a couple clearer pics of the MIC manual set up.
03-04-2011, 06:14 PM | #71 |
i like how that system uses push connect fittings instead of hose barbs. Where do you get something like that?
03-04-2011, 08:25 PM | #72 |
I know RideTech has them.
03-04-2011, 11:19 PM | #73 |
Would anyone be willing to post a video of these valves in action? Maybe a little run down of the install? Or if anyone knows of an existing video link out there? Thanks
03-05-2011, 03:15 AM | #74 | |
Keep It Simple S......
03-06-2011, 12:56 AM | #75 | |
