#51 |
Old member
I just want to say I have no info on this truck...YET
But it has these on it. I'm waiting on the guy to tell me he has it running so I can go buy it. ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#52 |
Re: pictures wanted of clearance/roof lights
69 CST-20.
So were these an option, part of the CST package, or what? My grandfather bought this truck new, and growing up I was always told that when a fleet of 50 or more was purchased, one was provided with lights. Sounds like an urban legend. |
#53 |
Here is my 70 Stepper with the High 5 light kit available from J.C. Whitney or LMC.
#54 |
Here are some on a truck I saw. The guy says it just about original
#55 |
![]() Join Date: Oct 2009
Great thread. Two dumb questions:
- Can these puppies be added to a non-raised roof cab? (I assume that is what some of the questions about "adding" them are attempting to do - and some of the pics look like they are on non-raised roof cabs) - Does that work? Has anybody that has done that had an leakage issues? (ok, I know that's 3 questions.. sorry) |
#56 |
Mine was not raised for them. I have had them on for about 5 years & havn't had any leakeage problems. I drilled 3 small holes for each one & put RTV around the screws & wire. I wired them into the tail lights but put a separate fuse smaller then the tail light fuse so if there was a short it will not put out the tail lights.
#57 |
great, thanks wrenchbuilder!
#58 |
here is my truck with cab lights. i will be replacing with a "normal roof skin"
#59 |
save that roof skin for posterity!
#60 |
I realize this is an old thread. But........I have a 69 with the roof lights. I didn't mind them at first, but then started to not like them. I found that Harley Davidson taillight lenses fit perfectly. They're much shorter than the stock lenses that I had (hockey puck style as described above). Just thought I'd throw that out here if anyone was looking for a change.
Mike |
#61 | |
The Older Generation
Do you you mean turn signal lenses? I don't think you can use Red lenses on the roof of a non-emergency vehicle. The Harley turn signal lenses have to be modified to work. Here is a thread I posted on the subject back in 2013.... http://67-72chevytrucks.com/vboard/s...d.php?t=598129 LockDoc
#62 |
![]() Join Date: Nov 2014
1968 c30
