Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-16-2011, 10:28 PM   #51
PD1292
PD1292's Avatar
Re: 72Jimmy 1st attempt at rust removal
I am currently attempting to finish welding on the fender but it is taking a long time to see results so i took a break from that and worked on the inner fender well on the driver side. It had rust spots on the front in two places. I cut them out and the replaced them with another piece. Here are some pictures.
PD1292 is offline   Reply With Quote
Old 08-17-2011, 12:25 PM   #52
thor
thor's Avatar
it's looking good sir!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 08-30-2011, 11:10 PM   #53
PD1292
PD1292's Avatar
Thank you Thor.... Updates on the project. I got the patch panel over the wheel well done, and then found out I did not set up the metal very well before I welded. Turns out it had a large dip where the welds went. I tried to attach a stud (stud welder) to the side in an attempt to pull it out but I could not get it to stay in the shape I wanted. Frustrated, I decided to pull the whole back outer fender off.. I was worried about it while drilling out all of the many spot welds and peeling back the metal, but after the panel came off I felt better about it. I am now able to get a hammer to the back and have beat the damaged part back out to almost strait. (well strait enough for bondo work).
Old 08-30-2011, 11:17 PM   #54
PD1292
PD1292's Avatar
I have another question now, There is a mount on the inside of the rear bedside that attaches to the removable top, it is threaded into a nut that just spins in the bedside and does not allow the bolt to come out. Is this the way it should be or should i be able to take that bolt out. I have tried to attach some vice grips to it but it wont turn out.
thanks Barry.
Old 08-30-2011, 11:32 PM   #55
PD1292
PD1292's Avatar
The bedside was also missing the sliding nut for the single wall top. Lucky for me the frame that holds the nut was still there, and I only had to make the piece that is pictured. I made it out of a thinner piece of metal at first and then had to remake it after finding there was not enough thread to hold it tight. Second picture is the frame work under the bedside that holds the sliding nut.
Old 08-31-2011, 12:05 PM   #56
drunkbus
New Member
drunkbus's Avatar
I would just put a few tack welds on that nut that is spinning for the top mount to hold it in place. That bolt is supposed to come out.
drunkbus is offline   Reply With Quote
Old 08-31-2011, 04:03 PM   #57
thor
thor's Avatar
thanks Barry.
I've always left that metal piece attached to my hardtop when I've taken it off. I agree with Drunkbus - weld the nut and remove the bolt.
Old 09-04-2011, 11:52 PM   #58
PD1292
PD1292's Avatar
Well I could not get the bolts to come out so i had to cut them off and pull out the, i guess it was some kind of rivet nut. it left large holes where the nut was supposed to be. Ill try to weld either a nut or a thick piece of flat stock and tap it.
Old 09-05-2011, 12:05 AM   #59
PD1292
PD1292's Avatar
I had a large dent/rip on the back side of the passenger side. I tried to patch up the hole but the metal was so thin I kept blowing through it with the welder, so I decided to attempt a metal patch. Here are the results.
Old 09-05-2011, 11:21 PM   #60
PD1292
PD1292's Avatar
Sand blasted the inner back fender panel and got it painted.
Old 09-06-2011, 12:33 AM   #61
VA72C10
VA72C10
VA72C10's Avatar
Nice work! Coming along nicely!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-26-2011, 10:02 AM   #62
PD1292
PD1292's Avatar
I put the outer fender back on and after some filler work I have it pretty strait. I sprayed on some etch primer last night and will follow up with some high build primer (?) to finish it off. It seemed pretty strait but i think it still has some slight wavyness to it. I need to continue to block sand it after the build primer correct? Any way here are some pictures before and after. Also any advise would be helpful for where to go from here. Thanks Barry
Old 09-26-2011, 11:47 AM   #63
thor
thor's Avatar
nice work. looks more like you put on a replacement panel. the "before" was pretty rough looking. musta been a pain to pull it out.
Old 09-26-2011, 10:47 PM   #64
PD1292
PD1292's Avatar
Thanks Thor,
It was not easy to do. I was considering buying a new panel and cutting the outer panel off of the new panel and attaching it where the old one went, but I would have to drill and cut all the holes for the top attachment screws, and then patch the bed stake holes, not to mention the short bedsides were $440. Ouch! I guess I should re-name my thread as "1st attempt at body work" now. I bought some high build primer and shot a thick coat on the bed side. This is what i bought. 1st pic is the etch primer that was shot on first. Second is the high build primer.
Old 09-26-2011, 10:55 PM   #65
PD1292
PD1292's Avatar
I shot on a coat and then block sanded with 180 grit and it came out like this. I am pleased with the build primer. Now it went through the etch primer in some places, do I need to re-apply the etch primer and then apply the other primer or, do I need to just apply the build primer. It is only a few places where the metal is showing..
thanks Barry.
Old 09-26-2011, 11:10 PM   #66
PD1292
PD1292's Avatar
I also cleaned up the area at the top of the fender where it meets the door jam.
Old 09-27-2011, 10:41 AM   #67
jaros44sr
jaros44sr's Avatar
Looks great to me
Im not a body and paint guy, but you can drop down into the subforum for paint and ask those guys. If it is anything like the electrical or motor section, you will have knowledgable answers
Thanks for the pics, enjoyed reading so far
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-27-2011, 12:40 PM   #68
Rdrdave
Broke and still trying
Rdrdave's Avatar
Keep up the great work. Very motivating
Rdrdave is offline   Reply With Quote
Old 09-27-2011, 02:32 PM   #69
thor
thor's Avatar
thanks Barry.
Originally Posted by jaros44sr View Post
Looks great to me
I agree. I would ask the pro. I am a hack.
Old 09-27-2011, 03:14 PM   #70
jaros44sr
jaros44sr's Avatar
I would like to agree to his agree, since the back half of my jimmy is rolled on flat white enamel rustoleum lol
SAFETY FIRST
AS usual, off topic
Jim
Old 09-28-2011, 12:00 PM   #71
PD1292
PD1292's Avatar
Thanks for all the comments! It keeps me motivate as well!!
I posted on the paint and body work section as was suggested and the answer is: if the primer is DTM (i think that is what he said) Direct to metal, then you can prime over the small blow threws. Mine is not so I will have to re-apply the etch primer and then follow up with some build primer and continue to block.
Old 10-02-2011, 03:31 PM   #72
PD1292
PD1292's Avatar
OK, after many times, dont remember, mabe 5 times priming and block sanding, It looks like this. I think I am going to leave this one alone for a while and go on to some of the other body work that needs to be done. like mabe the other quarter panel on the other side. This is wet sanded to 220grit. The guys on the paint thread said i need to go down to possibly 600 grit to make it really smooth. I think i will wait till i have all the other body work done before I do that. Here are some pictures. It is primer, just wet down.
Old 10-02-2011, 03:51 PM   #73
VA72C10
VA72C10
VA72C10's Avatar
Nice work! Definitely worth the effort! I agree on going 600 before paint...makes a big difference from past experience.
Old 10-02-2011, 04:32 PM   #74
PD1292
PD1292's Avatar
And then I painted it blue, No just kidding, photoshop.
Old 10-02-2011, 04:48 PM   #75
PD1292
PD1292's Avatar
more
