#51 |
Re: just finished my front crossmember section
If I was wasting peoples time, I wouldn't care about your pokes.
My suggestion is a legitimate concern/possibility. Since I'm trying to promote awareness of potential issues & to verifiy these types of possibilities before they make the commitment on a mod like this, I'll ask you to stop now.
#52 |
My goal wasn't to start a conflict.. Just see if there was an alternative for the guy that had a bit of fab skills.
Nate builds a great product, no doubt about that! I have his trailing arms and trailing arm cross member and I think his front crossmember is a work of art. I was just thinking with the introduction of no limits rack and pinion kit that it might make it easier to notch or section a crossmember more than 1.5". Posted via Mobile Device |
#53 |
Would sectioning the crossmember make it week?It looks like it loses alot of metal.If you z'd your frame wouldnt you lose some of your scrub line?I would like to get my 66 realy low but i still want to be able to drive it and not trailer it.
#54 | |
I would check w/Rob & see what he thinks. There might be a 'max' amount even his set-up can accomodate before the bumpsteer issue returns despite the R&P (because of the units installed location). Obviously, guys w/advanced fab skills & equipment are @ an advantage & could still possibly tweak it to work ![]() Regardless, the oil pan depth still should be considered. I originally set mine up w/a sbc & verified fit/dimensions. I later swapped that x-member into another truck w/a bbc & the 6qt/9" deep pan (stock GM truck sump) was below the 'scrub-line' of the x-member. It required swapping to a 5qt 'car' pan to be flush w/the bottom of the x-member. A deep-sump/high-perf pan or greater than 1.5" of notch & the pan would be below the scrub-line.
#55 | |
Giving proof of what I did works and the pan doesn't hang below the crossmember. I think you're a little sensitive when you think someone is challenging your experience / smarts. That's not my intent. My intent is to share my experience sectioning my crossmember 2" and pointing out that I am NOT a fabrication expert, whiz, or even that skilled. I had a couple parts when I started out - just in case I goofed up, because it is a scary feeling to do something like this for the first time. I found out that with patience and a bunch of measuring, I could get by - and if can do this: ANYBODY can. ![]() I'll continue to give my opinion based on my experience, and you continue to give yours. I don't want to come across contrary to your experience while I'm sharing mine. How about this: I sectioned 2" out of my 66 and wound up being okay. I see "2"-3" mentioned several times in this thread and will concede that if I would've gone any more than 2", my pan would've been below the crossmember. If I was wasting peoples time, I wouldn't care about your condescending attitude. My experience is legitimate and worked for me. Since I'm trying to promote awareness of potential success & to verifiy these types of modifications are possible if you think through it, I'll ask you to stop now. |
#56 | |
Scoti doesn't want you doing this mod without thinking everything through and knowing what you're getting yourself into. All I want to get across is that I have limited fab skills (started less than a year ago) and I was able to do it after I did plenty of research. He's sitting on one of your shoulders giving advice based on experience, common sense and reality; I'm sitting on the other one saying "OMG! Do it! It would be so cool!". ![]() |
#57 | |||
I didn't state your methods won't work or aren't correct. Your pics prove the 2" notch can work w/your combination of parts. I stated the fact that there can be a scrub-line issue (as you also just agreed with). You originally interpeted what I said as meaning the dimension between the oil pan to x-member would be compromised: Quote:
It's fine if you're prepared to take a chance & grab more parts to do it over. My intent was to only suggest people verify the dimensions of their parts before possibly cutting it up more than their combo (not yours) can allow.
#58 |
Happy to be here
![]() Join Date: Mar 2000
Scot_Douglas- Scoti is simply trying to warn those that might attempt the same modifications of the pitfalls they might encounter. The senior members here only promote suspension mods that do not have potential for failure, or safety concerns.
Obviously you have put a plan in motion and been effective in achieving the results you were after. Your input on what you have accomplished is appreciated here. Your sarcasm is not.
#59 | |
work smarter, not harder! just my opinion
51 Chevy 3100 Deluxe Cab(SOLD) ![]() 65 **stang 6cyl 70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD]) 72 C10 Short Bed Fleetside 73 Blazer 2WD Catalina Blue White Top(Needs Love) 73 Blazer 2WD Work in progress LT1/4L60E 83 Grand National (SOLD) 94 Blazer K1500 Silverado (SOLD) 96 Impala SS All original (NEXT IN LINE 2 B SOLD) 99 Tahoe 2DR, 2WD ![]() |
#60 | ||||
And now I will concede that the whole time Scoti was stating a RANGE of crossmember sectioning, that I conveniently missed because I saw the 2" in the 2"-3" ![]() ![]() BTW, I don't have a sarcasm bit to turn off, it's always there. (For better or worse) But with that in mind - I apologize for my misunderstanding Scoti's considerations and dragging drama into the thread. This apology goes first and foremost to Darron (roofingbloke) for poopin' in his thread, then Scoti, of course ![]() ![]() |
#61 | |
HOWEVER My wife, who at the moment considers a $10,000 hot tub on sale for $8,500 a good deal, cannot see the value of any part going to the truck that doesn't fix what's broken. ![]() ![]() Someday, I'll use some correctly built parts that go together nice and don't end up taking lots of trial & error. I need your help though - my wife said I could do it when pigs fly - so if anyone can get some photographic evidence...I'd be much obliged! ![]() |
#62 | |
#63 | ||
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#64 |
I spoke with rob about the above question and he advised that I should only notch the crossmember 1.5 inches or it could open up a can of worms. However, I'm confused.. Because as gringoloco said the steering is moving up with the crossmember. Therefore I forsee that eliminating the common issues when using the factory steering box.
That being said I know that the oil pan becomes an issue (however I still havent taken a measurement to find out truly if it will be). No comes the cost.. $750 plus shipping for No Limits r&p kit with the possibility of a few extra for a spare crossmember.. And your talking about a grand without labor. Then there is porterbuilt's cross member which is roughly $1200 shipped to your door, rack and pinion for 300-350 shipped, and another 150-200 for the steering shaft. So that's about $1700. (please don't take this as me knocking any of Nate's products. They are truly awesome! However, I'm just trying to think of a safe way to get the same result for a little less coin) Posted via Mobile Device Last edited by Rochlow; 09-15-2011 at 11:50 AM. |
#65 | |
A guy with a truck
I would ask Rob what specifically is the issue with going more than 1.5". Also, be aware that with the standard 'pancake' method, you will lose the rack mounting points, so your crossmember cuts will have to take that into consideration. I think if the R&P kit was around $5-600 this would be a no-brainer. As it stands, it's too close to call...
#66 |
My tattoo artist has a sign on her wall.
Good Fast Cheap Pick two. It all depends on what your after and how much you want to work and spend. Find an avenue that your comfortable with and go with it. My burb has a rear DM, front still to be determined. Lol Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#67 |
I have about 12 hours into this plus about $20.00 and that includes the spraycan!
#68 |
That looks great!
#69 |
Quick question, I've got a 63 C10, 250ci w/ 4spd its bagged, cupped control arms, 2.5 drop spindles, notched and blocked in the rear. Just got done sectioning a spare crossmember. Right now when I'm aired out my front crossmember/control arms are on the ground. What I'm having an issue with is the trans and trans crossmember are about 1/2" off the ground. What do I need to do or what steps do I need to take to fix this issue.
#70 |
Diggin The SquareLife
Raise motor and trans or get a trans crossmember
