#51 |
Garage wrench
Re: Cherubs Burban Project
Where did you get the rear bag set-up? Is it a ridetech AOL kit?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
#52 |
Did I right that you did not notch the frame? I picked up a 78 and I was noticing tonight as I unloaded it off the trailer that if I put the axle on top of the leafs there would be almost no clearance to the frame???
#53 |
oke, thanks, but what I wanted to know, is if he did the A/C lines himself? isnt only possible by special tools because of the refrigerant?
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#54 | ||
Yes thats the exact system i got.
compliments of N2TRUX Quote:
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
#55 |
![]() Join Date: Dec 2010
Man I am digging the 'Burb!!! Looks killer at that height & with those wheels & love how it's so simple & useable too! Keep the pics coming!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
#56 | |
nice build man!
#57 |
Cherub,
What did you do for the fan set-up now that the WP is rotating in reverse? I started thinking about it today & assume a mech fan from a serp set-up is req'd (which I mat/may-not still have from my swap parts). Still waiting on my brackets. They should arrive tomorrow according to tracking....
#58 |
![]() Join Date: May 2009
I liike it! Pretty impressive to drive a vehicle that old on that long of a road trip with no issues. Nice find!
Posted via Mobile Device |
#59 | |
#60 | |
#61 |
Garage wrench
Any updates on the 'burb?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 10-09-2011 at 11:15 AM. |
#62 |
Man that's a sweet burb!
That's exactly the way I want to put one together, and I agree that that the only change needed from what you've done already is swap out the mirrors. I think the wheel size is dead on man. Posted via Mobile Device
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
#63 |
Truck Nut
![]() Join Date: Jun 2007
The wheel size is perfect!!!! Lookin sweet!!!
Tony Kee Texas Square Bodies |
#64 |
no updates as of yet it needs the exhaust ran and it will be drivable again. I stalled out on working on it and been putting money into house projects.
#65 |
Garage wrench
Do you have any detailed pictures of the passenger side rear AOL mount? I am in the middle of installing my ridetech AOL kit on my flipped rear suburban and cannot quite figure it out. I am having clearance issues with the upper bag mount/axle/shock. I see the pictures of the drivers side on yours in this thread and they helped a ton. Any help is greatly appriciated.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 10-18-2011 at 12:24 PM. Reason: forgot stuff |
#66 | |
#67 | |
Garage wrench
I was thinking about grinding a little on the lower bag mount to get it the clear the shock, it's good to confirm that that's what you did too. She's just a little tight on the pass. side ![]()
#68 |
Garage wrench
Not meaning to rush, but was curious if you had a chance to get to those pics?
#69 |
Anything new with the Suburban?
#70 |
Im really sorry i never got you those pictures
#71 |
Just redid my headliner. It was an easy process found some go-bys on you tube. ill post pics of it later.
#72 |
pretty curious about this pics too...
#73 |
Garage wrench
No problem man, I got it all figured out
#74 |
hahah better late than never i guess.
Im running shock extenders with front shocks on the rear. also trimmed that plate as you can see from the pics ![]() ![]()
#75 |
came out pretty good for my first one. I used this video when finding out the process for "headliner Repair". Took me 3 cans of high heat headliner adhesive and 5 yards of foam backed headliner material. All in all about 100 bucks in materials. Eventually when time and money permit ill take the moldings down and hit them with some interior trim paint
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) Last edited by Cherub; 05-07-2012 at 07:58 PM. |
