Old 12-09-2011, 03:50 PM   #51
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Project Polar Bear
12/2/11 - Muffler installed with short turn down. Sounds wicked.
12/9/11 - Oil Filter Adapter housing resealed and oil/filter changed(NAPA Gold/NAPA 10W30). Now I dont leak a puddle when I idle. And fuel filter changed(NAPA Gold).
I found out that NAPA oil is Valvoline . $4 cheaper per quart!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-09-2011, 09:12 PM   #52
thirdstreettito
Resident of Here
Getting one of these for X-mas
http://mudflaps.com/i-7825607-engo-w...thic-rope.html
My mechanic said he wants to get more into fabrication, he is already a great welder, but wants more fab practice. He said if I buy the steel he'll build me bumpers for free
~Bradley~
Miss having a truck
Old 12-13-2011, 12:54 PM   #53
Dustinmk4
For your stuck plug use pb blaster let sit for a night then get engine up to operating temp and should come right out.
Dustinmk4 is offline   Reply With Quote
Old 12-24-2011, 12:31 PM   #54
thirdstreettito
Resident of Here
Update! Two weeks ago the truck started leaking oil like a waterfall. So I brought it to my mechanic and he said I need the gasket/o-ring kit for my oil filter adapter(for the oil cooler lines). So I bought it, got it installed. A week later it's leaking again. Long story short, the oil filter adapter was cracked so now Im just running the filter without the adapter. Truck runs fine.
I replaced all 4 belts yesterday and the PITA power steering pump/crank belt is a little loose, squeals when it's cold. My serp belt was split down the middle. No more whistling or whining now. Much quieter.
I also installed my new tailgate cables that Ive had for a month. Yay!
~Bradley~
Miss having a truck
Old 12-25-2011, 01:48 PM   #55
hipasschev94
hipasschev94's Avatar
did gm make a stock v10 in those or was that a aftermarket peice?
<><JP><>
hipasschev94 is offline   Reply With Quote
Old 12-25-2011, 02:09 PM   #56
thirdstreettito
Resident of Here
1987-1991 squarebodies went from C/K to R/V. It's got a 350, but instead of K10 its a V10.
~Bradley~
Miss having a truck
Old 12-27-2011, 10:44 AM   #57
thirdstreettito
Resident of Here
I also forgot, I got new Bosch Winter Blades on. It'll be about ten years before I need to wipers. I love these things.
~Bradley~
Miss having a truck
Old 12-28-2011, 11:01 AM   #58
thirdstreettito
Resident of Here
Here are some random pictures from the last month or so. Enjoy
~Bradley~
Miss having a truck
Old 12-28-2011, 11:03 AM   #59
thirdstreettito
Resident of Here
They're fairly small because they are taken with my phone.
Old dealership/garage
~Bradley~
Miss having a truck
Old 12-28-2011, 11:09 AM   #60
thirdstreettito
Resident of Here
I'm going to buy a DIY4X clocking ring for my NP208 soon. It hangs WAY too low. It hangs lower than my dads.
It was pouring buckets yesterday so I went down a trail for the town water dept. It was very slippy slidey. I went back today and saw I was going through 2"-10" mud/wet leaves. As long as I kept up my speed I was fine. No 4wd needed.
~Bradley~
Miss having a truck
Old 12-28-2011, 09:42 PM   #61
thirdstreettito
Resident of Here
Took my roof rack and spoiler off today. Then filled the holes with silicone white caulk. Just temporarily until I have the money for a body shop to weld the holes up. The truck looks bald!
~Bradley~
Miss having a truck
Old 01-02-2012, 02:41 PM   #62
thirdstreettito
Resident of Here
Drove to Wilmington New Years Eve to see my Aunt. 250mi round trip. Not a single hiccup. The SES light came on for 5 minutes like it does about once every two weeks. Still dont know why. I took US421 instead of I40 so I didn't have to do 75mph. Because when I go that fast everything vibrates. My next purchase is tierods and get the tires rotated to see if the vibration follows a certain tire.
~Bradley~
Miss having a truck
Old 02-19-2012, 01:04 AM   #63
thirdstreettito
Resident of Here
I got a fixed column installed to fix the wobbly tilt column for good.
Today I put a bottle of Marvel Mystery Oil in the gas tank. I used WD40 on the #6 plug and it finally came out and I put the correctly gapped ACDelco plug in. The truck definitely runs smoother. I cleaned and painted my air cleaner top and wing nut, will do the bottom next week in black. I also painted the body line below the grille black because it was blue with white overspray. Same with the bottom of the front of the fenders. Looks SO much better.
Next is plug wires, cap, rotor, and coil.
~Bradley~
Miss having a truck
Old 02-19-2012, 01:06 AM   #64
thirdstreettito
Resident of Here
Some more.
I also taped off the wheel well trim so it wouldn't look tacky.
I got my jack and measuring tape and measured the lift I want in the rear to make the truck level the way I like it. I need 2 inches. Not sure how I'll do it. Blocks, new springs, shackle flip, not sure...
While the jack was out I jacked the whole front end up to track down a weird thud whenever I hit a bump, I thought it was a bj. Yup! Drivers side wheel wiggles top and bottom about 1/32"-1/16".
~Bradley~
Miss having a truck
Old 03-06-2012, 04:10 PM   #65
Johnny G
Talking Re: Project Polar Bear
I was hoping to see a Ford or Dodge V10 shoehorned in there!!
Johnny G is offline   Reply With Quote
Old 03-06-2012, 06:59 PM   #66
1Bad65GMC
1Bad65GMC's Avatar
Haha, thats what I thought too. I kept following for the swap.
I like your rig though. Will continue to follow.
1998 GMC Suburban 2500 454 4X4
1984 GMC Jimmy - 3/4 ton axles, 5.7TBI
1990 GMC Suburban (Parts Donor) scrapped
1965 Buick Riviera - (Sold)
1999 Mercury Grand Marquis
1965 GMC SBSS (Sold)
1Bad65GMC is offline   Reply With Quote
Old 05-16-2012, 08:13 PM   #67
thirdstreettito
Resident of Here
Replaced all 4 headlights with Sylvania XtraVision. Amazing difference!
Finally got my front bumper planned out!
Also probably gonna do a 5.3, it just makes sense. It'll be a while though! :P
~Bradley~
Miss having a truck
Old 05-16-2012, 10:26 PM   #68
Cherub
Cherub's Avatar
lookin good
Cherub is offline   Reply With Quote
Old 05-27-2012, 09:15 AM   #69
thirdstreettito
Resident of Here
Changed my oil yesterday. 5 quarts of NAPA 10W-30 and a NAPA Gold filter. As always. (5W in the winter)
I picked up my rubber brake lines and got the truck jacked up on stands. I was gonna bleed the whole system too. But one of the bleeder screws on the calipers is broken. So to be on the safe side and to just do it while its apart. I ordered new calipers($19 EACH! ) and new wheel cylinders too. So it looks like I'll have new brake lines, brake fluid, calipers, and wheel cylinders. The front pads are almost new so no need to replace them.
Well, while I was under the truck I scooted to the rear and changed the diff oil. 2.1 quarts of Valvoline Full Synthetic 75W-90 W/ Limited slip and a LubeLocker gasket. Good God was there a lot of RTV on it. Took 25 minutes to clean the cover and housing of just the RTV. I'll never need RTV again!
~Bradley~
Miss having a truck
Old 07-19-2012, 04:56 PM   #70
thirdstreettito
Resident of Here
Been doing trail rides a LOT lately. 2-5 times a week. Just driving power lines and abandoned development projects, subdivisions etc. Some hardcore stuff too. One place is apparently call "Red Dirt Road" because it's all red clay. I drove 3 miles back on it, only about 1/2 mile of road type. Needless to say I almost flipped a few times from the pitches, got the front wheels off the ground, fully flexed a LOT. Dragged the t-case skidplate a million times. I've hit my hitch even more times. Lots of fun! Unlike most guys, I try to stay out of the mud. Too much cleanup and risk of getting stuck far from home or finding something in the mud, or breaking stuff. Plus it helps you lose traction.
I ordered skyjacker H7058's for the front this morning. Next is steering box brace, then NP208 clocking ring, then rear bumper/hitch/tank skidplate combo.
EDIT: I have yet to put her in 4wd. All done in a stock suburban on 31's in 2WD! Many of the trails are ATV trails too. Nobody around here will even take their modded jeeps or yota's into the places my burb has been.
Long Live The Polar Bear!
~Bradley~
Miss having a truck
Old 07-22-2012, 07:08 AM   #71
thirdstreettito
Resident of Here
Going to look at a set of axles Tuesday 7/24. 3/4 ton set. As far as I know it's 4:10 14BSF 9.5 and a 10 bolt front. $250 for the set. I'll grab the set of 16" wheels too while I'm there.
~Bradley~
Miss having a truck
Old 07-22-2012, 01:20 PM   #72
WarBeard
WarBeard's Avatar
Get the u-bolts and spring plate's as well since they are different for the 14 bolt.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 07-22-2012, 09:31 PM   #73
thirdstreettito
Resident of Here
They wont be going in for a while, but yes things like that will not be overlooked. Gonna go through them. New seals, bearings if needed and lockers/posi plus a rear disc brake kit. Minus traction unit's i'll have about $1000-$1200 in them. Then when I find one tons I can sell these to my dad for the 83 or keep them for a future project.
~Bradley~
Miss having a truck
Old 07-24-2012, 10:57 AM   #74
thirdstreettito
Resident of Here
Got my shocks about 20 minutes ago. Some dish soap and the bushings are all in. VERY happy they are poly instead of rubber. I wont be using the boots because; I dont like the look, they hold dirt, and when bottomed out they get all jumbled up. Going to go pick up some new grade 8 bolts at NAPA and put them in this afternoon after seeing the axles.
~Bradley~
Miss having a truck
Old 11-23-2012, 02:09 PM   #75
thirdstreettito
Resident of Here
So, being lazy I havent updated. I cant use the shocks. The rear shocks have a 5/8" top mount and the fronts have 1/2". I ordered front not knowing. Ugh.
Anyway here is what will be done in December.
88 V10 Suburban
22-402 (3 leaf 1400# Front springs with bushings) $237.10 shipped (Generalspringkc.com)
Brake Lines $112 (ORD)
2.5" Flip - $189 (ORD) + SHIPPING
17701 Ubolts - $40 (ORD)
H7043 SKyjacker - $75.61 (Carparts.com)
Calipers - $28.80 (NAPA)
Wheel Cylinders - $13.50 (NAPA)
Shackle Mount Bushings $22.86 (NAPA)
Total - $718.87
Im saving up for a motorcycle too. That way I can save buttloads of money on gas. The next on the list is 14B and 8-lug front hubs.
~Bradley~
Miss having a truck
