#51 | |
Re: Parting 72/67/81 SWB 4X4
Thanks, Ray |
#52 |
#53 |
![]() Join Date: Feb 2011
cool then it has the dust shield driver side
#54 |
1972 hays....was the question about the disk brakes for me or for ray?
#55 |
I will check to see if I have a loose dust shield. I like to sell axles complete because once I tear it down, its hard to sell the rest of it.
Thanks, Ray |
#56 |
Ray i require the border of the complete hole and it does not need to be a complete -1 piece - all i am doing is the 2 wheel hole that was hacked is now the same size as a 4 wheel hole and i am going to remove the nut and metal strip that reinforces the tunnel . i need the 2" circumferance around the tunnel in portions - the sides have strips of metal under the tunnel that have the nuts attatched to them and the top has just the nut spotwelded or heated to the tunnel . i need the total outer portion but it can be chopped to fit in a small box just dont cut the metal strips up that are used on the sides and i will remove the spot welds and atatch to my tunnel
#57 |
Kelly, I can do $25 plus shipping. If it fits in a small flat rate box, it will be around $15 to ship.
Thanks, Ray |
#58 |
sounds good and you are aware of what i need the perimeter where the bolts are and the sides have a strip it looks like that the bolts are part of - a flat piece of metal that the bolts are atatched to . and chop it up just ensure that the strips are not cut into 2 and i will detatch when i get the pieces of the perimeter pieces . anything with a nut i need and i will tack in once removed . thanks
#59 |
It sounds like your selling the connecting points for the transmission tunnel but are you selling the high hump? or do you have one? I was also looking for a clutch pedal/ pedal assembly for my auto-manual switch im doing right now. And if you do have either of these do you have a price? I live in roseville so could come pick anything up
Thank you Evan |
#60 |
Evan, I have a clutch/brake pedal assembly for $20 and a high hump for $30. pm sent
Thanks, Ray |
#61 |
it was for ray but if you have one and he cant find one or something cool thanks for looking a lot
#62 |
Sorry, I don't have any loose ones. If I come across one, I will let you know.
Thanks, Ray |
#63 |
Exhaust pipes and rams horn manifolds sold to Fesser. Frank, Thanks for coming over...its nice to see you again. I want to let everyone know that Frank is a stand up guy...A great guy to do business with. He even delivered some tires for me that were an hour away.
Thanks, Ray |
