12-15-2011, 04:28 PM | #51 |
Re: combo Tach/Fuel gauge cluster
i need to go to the secret dumptruck wrecking yard here and pick up a few of these then!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-19-2011, 09:04 PM | #52 |
How hard were those Camaro gauges to install? I have a set of those and i found a factory tach cluster (my second 1980+ tach cluster found in a U-Pull-It yard in 6 months!) with a trip odometer, I have NEVER seen a tach cluster, especially an '81, with a trip. It was in a 1981 C30 Custom Deluxe with a tach and delay wipers as the only options according to the SPID label.
Jay 2001 Pontiac Aztek GT |
12-20-2011, 01:30 PM | #53 | |
01-07-2012, 06:30 PM | #54 |
My tach just arrived, ordered 12/8/11 delivered 1/7/12. Heres some detailed pics I thought you guys might like to see.
John 82 Chevy Silverado 350ci/TH350 Last edited by J Knight; 01-07-2012 at 06:35 PM. |
01-07-2012, 06:32 PM | #55 |
This is the directions that come with it. Comes with the tach lead also.
John 82 Chevy Silverado 350ci/TH350 |
01-07-2012, 06:42 PM | #56 |
Looks good, Just like the one I installed. You will love it once you get it in.
01-07-2012, 06:56 PM | #57 |
Thanks for posting this last month, best option to a OEM tach cluster by far. I got to get a dremmel tool so I can get it installed.
01-07-2012, 07:31 PM | #58 | |
chevy runs deep
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
01-07-2012, 07:43 PM | #59 |
$210 shipped and it is plug and play after making room for the gas gauge part. I will also post pics of the install.
01-08-2012, 06:45 PM | #60 |
I got my tach installed today, not as bad as I thought. you can see in the last pic why some of the structure has to be removed.
01-08-2012, 06:50 PM | #61 |
I cut the stucture out with a pair of diagonal cutting plyers and needle nose plyers. I made alot of relief cuts going a little bit at a time, then drilled a 1/2in hole in the back for the tach lead.
01-08-2012, 06:54 PM | #62 |
Before and after, the tach works great. I didnt see any movement in the gas gauge but I almost have half of a tank so we will see in the next couple of days if its working.
01-08-2012, 06:57 PM | #63 |
chevy runs deep
Came out good bro cant wait 2 order mine
01-08-2012, 10:25 PM | #64 |
I just got mine on Friday. I was real excited but to be honest I'm not real happy. 1. The body is made out of molded plastic, not like the original metal. I thought I was getting metal(when I was told they use all Chevy and american parts), oh well. 2. The fuel posts were off center about a 1/16 and it wouldn't sit right inside cluster housing. I had to cut down the metal tabs for the connection because wires that were soldered on were in the way. For the price I just thought I'd get a better product....hopefully i have no other problems....Iroc gauges may be happening.....
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP [B]1972 Chevrolet K5 Blazer RIP 1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP 1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP [B] 1995 Chevrolet Tahoe 2D [B] |
01-17-2012, 12:29 AM | #65 |
ttt
01-17-2012, 01:05 AM | #66 |
Different years used slightly different fonts on the gauges, correct? Which years does this GMSports tach match perfectly?
04-30-2012, 10:17 AM | #67 |
Slots go on anything!
The gauge font matches 81-up. They also fit perfectly in the 90-91 electronic clusters.
1974 Jimmy- 5.3/4L80e/NP241 |
06-24-2012, 08:23 PM | #68 |
Those gauges from GMSports look amazing but im not a fan of the moleded plastic. Looks like im gonna start looking for a used metal tach.... hoping not to spend over 250.00
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
06-24-2012, 09:32 PM | #69 |
I never did update this but the fuel gauge works perfect as well as the tach.
06-25-2012, 07:56 AM | #70 |
I was like you when I seen the plastic also. But when installed I could not tell the diffrence. I have not had anybody look at mine and say ,hey thats plactic.I have had alot of people look at mine and even asked a couple people if it was plastic or metal.They could not tell. Mine works great.
06-25-2012, 08:43 AM | #71 | |
You really cannot tell the difference when it is installed. It doesn't look plastic at all, and the font matches the newer gauges (81-up) perfectly.
06-25-2012, 09:11 AM | #72 | |
06-25-2012, 10:16 AM | #73 | |
06-25-2012, 10:38 AM | #74 |
Agreed.
06-25-2012, 10:45 AM | #75 |
Maybe the font is a little thinner on the later cluster (91)? I thought mine looked pretty close. Since I wanted it to look somewhat original, I may not have given it the "eagle eye".
