Old 08-28-2011, 04:32 PM   #51
grs
Re: What did you do to your truck this week?
Tried to install a pair of aftermarket horns on my 87. I will work on it again tomorrow.
grs is offline   Reply With Quote
Old 08-28-2011, 05:20 PM   #52
Finished making brackets to mount my 92 seat in the 83. Worked on dash pad pieces and remounted the dash pad.
Old 08-28-2011, 05:26 PM   #53
bigwheel15
bigwheel15's Avatar
Spent the eleventy billionth day cleaning years of dirt and grease from my engine bay and painting everything. Still not done but getting close.
bigwheel15 is offline   Reply With Quote
Old 08-28-2011, 05:27 PM   #54
StepAside
StepAside's Avatar
Roasted the tires a few times!!! Gotta breaker in! ha
StepAside is offline   Reply With Quote
Old 08-28-2011, 09:14 PM   #55
HotRodScottsdale
HotRodScottsdale's Avatar
cleaned it and tried again to tighned the rad hose, some what worked, dam she blinds me when the sun hits it
HotRodScottsdale is offline   Reply With Quote
Old 08-28-2011, 09:53 PM   #56
my4by2
my4by2's Avatar
Well, can't exactly say that I got it done as I am over 7,000 miles away from my truck, but it did get done this week never-the-less...
my4by2 is offline   Reply With Quote
Old 08-29-2011, 08:21 PM   #57
grs
[quote=baclay9;4831682]
Originally Posted by CaliDude76 View Post
Sorry, just saw this. I bought them a local auto accessory place called Massy's. They have lots of older school stuff like that. Best part is they bolt on through the center of the center cap.
I mocked my front clip up this week to see how she would look. I still expect the front end to drop another inch or so after fluids are added and the coils settle.
By claypool782 at 2011-08-04
Do you have the phone number for Massy's ?
Old 08-29-2011, 08:30 PM   #58
baclay9
Here you go. They are 3 bar spinners.
Massey's Accessory Shop
(405) 239-2010
baclay9 is offline   Reply With Quote
Old 10-30-2011, 07:43 PM   #59
redblazerx
I lost a exhaust manifold bolt some how.........LOL
redblazerx is offline   Reply With Quote
Old 10-30-2011, 08:32 PM   #60
81chevylongbed
Just got done putting in a new th350 tranny after my old one was trashed.
81chevylongbed is offline   Reply With Quote
Old 10-30-2011, 08:46 PM   #61
85burb
85burb's Avatar
I set my a/f ratio, timing, idle speed. I also installed a used seat belt in the passenger side rear that has ben sitting in my closet for a year. Tryed to to install the driver side rear but i could not get the bolt out. I broke a craftsman tourqs bit and twisted a snapon bit and managed to strip the bolt head out. So it is going to take some kind witch craft to get it out.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 10-30-2011, 08:52 PM   #62
scotties truck
scotties truck's Avatar
tinted the glass new dual exahust new edelbrock carb ordered the cam heads intake and changed oil
scotties truck is offline   Reply With Quote
Old 10-30-2011, 09:17 PM   #63
bluex
bluex's Avatar
Hey buddy!
bluex is offline   Reply With Quote
Old 10-30-2011, 09:35 PM   #64
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Put a new Starter in the Jimmy.. It's ALIVE!!
87Lowrider is offline   Reply With Quote
Old 10-30-2011, 10:41 PM   #65
87Lowrider
87Lowrider's Avatar
That's a long way! Be safe!!
Old 10-31-2011, 03:51 AM   #66
grs
I put the front bumper on, the rear window in, the cowl in, the rear tail light lenses in, and the out side mirrors on the truck.
Old 10-31-2011, 11:55 AM   #67
Reziel_1983
Reziel_1983's Avatar
Worked on building my engine a little. Got the pistons, cam/lifters, timing chain and heads on!
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD
1998 Trans am, mostly stock with magnaflow catback
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329
Reziel_1983 is offline   Reply With Quote
Old 10-31-2011, 03:17 PM   #68
motornut
78K & 79C Jimmys
motornut's Avatar
grind it to a bolt head?
me.... got it running after finding a broken dizzy cap
new plugs ,wires,cap
still running with no inner fenders....makes for an ez tune up lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-31-2011, 03:23 PM   #69
camshaftgsxr
camshaftgsxr's Avatar
me and some buddies used the hood as a table for labeled baggies as we ripped apart a yamaha RD-200B. and it still starts like a champ after sitting for 3 months
camshaftgsxr is offline   Reply With Quote
Old 10-31-2011, 07:55 PM   #70
bikes&bowties
bikes&bowties's Avatar
Originally Posted by 88bagedntaged View Post
Took a 1993 Short Bed to be lowered !!
Man I dig your crewcab. But no dually front end?
bikes&bowties is offline   Reply With Quote
Old 10-31-2011, 08:42 PM   #71
sethv
sethv's Avatar
Broke a few leaf springs, busted what was left of my passenger side cab mounts... Remind me why it's important to look things over before going out in the woods.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 10-31-2011, 08:54 PM   #72
TDS-MN
I actually get to be part of one of these threads for the first time in a while.
My task for the weekend was to replace a leaky and plain WORN OUT radiator. Thing had barely any fins left. Found a LOT of rust rot and a multi-piece core support, I will likely need to replace that some time next spring. Should get me thru the winter at least.
Did get the radiator in and secured pretty solid, surprising enough. Found today that I have to slap a new radiator cap on, my old one is leaking now. This new radiator has plastic ends, where the previous was still metal. Was proud of myself that I remembered to add a short length of hose to the radiator drain, which will definitely help control the flow of coolant next time I have to drain it out.
Also got my fiberglass camper shell back on the truck after my DIY paintjob. Truck and topper all the same color now, been years since I've been rolling in THAT much style, LOL! Bed rug back in place, but still need to re-connect the wiring for the topper interior light.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 11-02-2011, 10:25 PM   #73
grs
Got my truck back home from being painted. Then I bolted the spare tire in the bed. Will post picks in a day or two.
Old 11-03-2011, 02:53 AM   #74
Kerlijah
Kerlijah's Avatar
Truck started chugging and generally running really rough, so last night after work I checked the plugs, found one that was really gross and replaced it, problem solved. Was on a roll, so I went ahead and adjusted my timing because it was a little off, fiddled with the carb a little, fixed an exhaust rattle, and had a beer...all in all, a productive night =)
~Wooden Indian~
1979 C10 SWB, shaved bed rails, drip rails, tailgate handle. 350 w/ Comp cam, hydraulic lifters, Edelbrock Performer intake, Edelbrock 650 carb, Flowtech headers, Flowmaster 40s, turbo 350 w/stage 2 shift kit...so much fun!
Kerlijah is offline   Reply With Quote
Old 11-03-2011, 11:40 AM   #75
ky_kid
ky_kid's Avatar
Sounds like an issue I'm having. How do I adjust the timing? And what "fiddling" did you do on the carb? Thanks
84 K10 Custom Deluxe: 350 crate engine w/ 4" lift
ky_kid is offline   Reply With Quote
