Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 01-10-2012, 06:29 PM   #51
GRX
GRX's Avatar
Re: ZDDP.....Zinc.....Save Yourselves
Originally Posted by Gumby View Post
That why the "rash" of break in oils are out, the get around the laws and EPA as they can prove its needed to that level for break in atleast. Just folks will run it all the time.
And also why GM stopped selling their ZDDP rich EOS (engine oil supplement) then re-introduced is as an "assembly lube" a while later. Whatever is takes to get around the EPA.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 01-10-2012, 06:41 PM   #52
sethv
sethv's Avatar
I run Brad-Penn 10w-40 in the K10 and it seems to do OK.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 01-10-2012, 10:12 PM   #53
A.T. RockDriller
A.T. RockDriller's Avatar
Originally Posted by theastronaut View Post
I use Brade Penn Grade 1 20W-50 partial synthetic. The number one guy in all of high performance aircooled VW's reccomends it (Jake Raby), and that's good enough for me. VW's only have four lobes on the cam and eight lifters, so the cam is getting the oil "wiped" off twice as often since each lobe shares two lifters- basicly getting half of the lubrication that any other camshaft would. If Brad Penn Grade 1 will work in those conditions, then it should work just fine in anything else.
Great point....
The mutha of all scuff applications.
Brad Penn Oils are a great product...Both the break-in grade & the run products.
Most top machine shops stock it.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 01-11-2012, 10:42 PM   #54
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
the vr1 in the silver bottle-how often should you change the oil??? mine seems to get black fast
John
1999 Toyota Tacoma 4x4
